Heater for hydraulic fluid?
53gravely
B7610
Dec 26, 2021
Vermont
I have a B7610 with an FEL on the front and a 6’6” old manual angle snowplow on the 3 point. Vermont is lovely this time of year. It was -14 this morning. I religiously run the block heater below 10 for an hour….longer for colder temps. I’ll start it and let it run for a couple minutes with the PTO turning to “exercise” the hydraulic fluid.
She moves good and plows really well. The FEL, however, is slower than bloody death when I go to do some “snow bank management”.
It takes a solid 5-10 minutes til the stinking thing moves at a reasonable rate.
Has anyone installed a magnetic or silicone pad heater to pre-heat the hydraulic fluid so the bucket moves at a reasonable rate right from the start? I’m thinking to plug it in when I plug in the block heater.
Where would be best to stick it? (Probably should rephrase that ;)
What type did you use?
PHPaul
Apr 2, 2015
1,297
1,628
Downeast Maine
www.eastovershoe.com
B7610 is a hydrostat, right?
From there, I'd assume it uses the same fluid for hydraulics as for the transmission.
If that's true, then I'd apply the heat to the transmission housing which would likely mean a magnetic heater.
Someone more familiar with the 7610 will be along and correct me if I'm full of it. :D
53gravely
B7610
Dec 26, 2021
Vermont
Yup. Hydrostatic. I wonder why it rolls at normal speed but the bucket is so slow? I assume smaller orifaces going to the FEL controls?
nbryan
Jan 3, 2019
1,430
948
Hadashville, Manitoba, Canada
My B2650 has pretty much the same HP as a B7610, but almost double the total hydraulic flow. They're both HST units too. So likely why this doesn't affect me nearly as much.
I cover all but about a 4" square area of my rad in the winter, and that also slows the cooling for the hydraulic cooling loop right in front of the rad. Could that help you a bit for warmup time? Is your hydraulic oil cooling radiator in front of the rad dust screen like my B2650? Blocking some rad fan flow through it will speed up warmup, somewhat at least.
pigdoc
G1800S L2500
Aug 19, 2022
403
350
SE Pennsylvania
For an El Cheapo solution, I'd consider a dipstick heater.
Used to use one of those on our Ford Jubilee...
-Paul
GrumpyFarmer
5,214
Is an insulated shop (or better yet, heated shop) an option? Or maybe add a wood stove that could be loaded the night before?
JonM
Nov 29, 2024
283
677
wisconsin
in extreme cold below 20f oncevthe engine warms up i drive slow letting the hst warm the fluid after a shirt bit i start running the fel through its full motion range up down tilt and same with my remotes and 3 point after a few complete cycles it works like normal
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
Block heater and silicone pad heaters on oil pan and HST is standard equipment from the dealer here. Pad heaters are relatively cheap and seem to last forever.
11,144
A magnetic heater would do squat for you, the housing is aluminum!
A silicone heater will help a little but it's hard to find enough flat to attach it.
What Hydraulic fluid are you using?
When was the last time you changed fluid and filters?
Old Machinist
May 27, 2024
721
840
NE FL
Slide a metal pan with a few charcoal briquettes under it for a while. I used to do that with my Triumph Bonneville so I could kick start it in the winter. :)
bird dogger
Feb 24, 2019
1,802
1,774
North Dakota
I'm way up north near the Canadian border, and like @nbryan , have a B2650. The first time out in subzero temps moving snow the tractor couldn't warm up and the hydraulic oil was so sluggish it wouldn't reach normal pto rpms. Now I run a full set of winterfront covers (front and both sides) and both the engine oil and hydraulic oil stay toasty warm after quick warmups.
As @JonM mentioned, before starting out.... I fully raise/lower, curl the FEL a number of times along with the 3pt hitch to circulate the warmed hydraulic oil through the cylinders to replace the cold oil and warm the cylinders up. Then all is good.
Yooper
3901 LA525
May 31, 2015
1,747
926
NE Wisconsin
You might try doing what the loggers do with their loaders when it’s that cold. They will work one of the controls all the way until the cylinder bottoms out so the fluid goes through the pressure relief valve. Don’t know how long but they claim it heats the oil up fast.
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
106
55
COBLESKILL, NY
I have a similar setup and do not have that problem. Mine is sheltered but not heated. We had -12* last week and it behaves normally. I'm the one very slow at low temps.... SNOW.jpg
nbryan
Jan 3, 2019
1,430
948
Has anyone here tried warming their HST fluid after a cold start by placing the transmission into Neutral gear then holding down the hst pedal in F and/or R?
Asking this well versed community because someone here might know way more about any possible damage risk to the tranny this may cause.
I've done it before when in a minor rush to get going, but not as a habit. It seemed to quiet and warm the HST fluid from sub-zero temps way faster. Or am I imagining this?
53gravely
B7610
Dec 26, 2021
Vermont
i’m using the Kubota hydro fluid. The barn is far from airtight so heating it ain’t gonna work.
im going to order a silicone pad heater and see if it helps. Thanks all
6,308
Fully cycling the loader controls forces all the COLD oil back into the 'system' where it's mixed and slowly warmed up. The more cycles, the faster it'll all warm up. If you're a bodger you could build a heat exchanger, to transfer heat from coolant to the hydraulic fluid.
If your tractor has a hydrualic oil cooler, add a bypass.
You will of course have to monitor the oil temperature and adjust valves as required.
5,468
This sounds similar to how and automatic transmission in a car works.
If I recall correctly, by placing the trans in D, the fluid is then routed past the blades in the torque converter. The fluid is in turn warmed, because of the friction it sees as it passed the internal blades in the TC,….hence “warming” the fluid faster.
I have no idea if there is a similar concept involved with a HST, but I would place my money on “no” if I were in Vegas. (but this is also why I don’t gamble anymore….I suck at it… :unsure: )
nbryan
Jan 3, 2019
1,430
948
With an auto trans the torque is put under load in drive. No torque in HST, and I run it in N, not D.
A buddy in my teens blew an auto tranny in his 1965 Galaxy 500 during winter warmup by applying park brake then leaving it in drive until warmed.
So I wouldn't try that.
