Building a fueling station.
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
I got a decent 30 gallon drum, a good method for getting it out of my truck once filled. So now....
I need to create a good delivery system. A 12VDC pump and good filter. Links to a quality setup? I'll figure out the plumbing and electrical fine. A switch on the motor would be nice. Fine, high quality filter and water removal. I want the diesel going into to be as clean as possible, Then a good hose and nozzle assy.
I'm not so interested in 'what you did' but what company makes the good parts for me to do my thing.
JasonW
680
433
Al
Any well known transfer pump brand will be good. GPI, fill rite and others.
Bisleybob
B7500
Aug 15, 2020
81
107
Harding Pennsylvania
Harbor freight pump and dolly, filter and housing from tractor supply, old battery from tractor, and a clean drum from washer fluid. Couple months in, probably 200 gallons through it (also feeding a sun fire heater) works well.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
411
636
NH
Fill-rite nozzle, Goldenrod filters (particulate and water trap), GPI 12v pump. Initially tried it with auto nozzle (despite pump manual saying this was not recommended). It worked 2 or 3 times then quit. Switched to manual fill-rite nozzle as recommended and has worked flawlessly since. Note pic showing hookup to car battery. Will work on PV, charge controller, and battery setup this spring. Setup is on pallet so it can be moved.
10,385
Fill-rite pump, suction tube, hose, nozzle (replace with auto stop), filter housing, battery from lawnmower and done.
Cheaper generic copy.
jyoutz
Jan 14, 2019
3,560
2,660
Edgewood, New Mexico
I’m building a very similar setup with a steel pallet and a 53 gallon tank. But I’m using a fill rite rotary hand pump with the goldenrod filter.
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
Do you think that pump will last?
I've seen pricing a of a full fill rite kit being at $700 (ouch) and I'm aiming to be under $300
That pump and what filter setup. I want to catch the finest of particles and all water Double filter is fine.
All my machines have a 20 amp SAE port where I'll be powering the pump.
Slow fill is fine 10 GPM or less should be terrific. I suspect with a fuel can I pour at about 2 gpm.
I guess my definition is great quality, least price, then do it once, do it right.
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
One other 'Generic question'. Are the filter manifolds the same, meaning you can spin on any brand filter?
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
It seems this Fill-Rite is the correct choice - Fill-Rite FR1210H @ $570
I'd prefer less GPM I think (what to gas stations pump at???)
I'll have to do a little plumbing to connect to my fuel cart
hedgerow
455
441
Malcolm NE
I have always ran Fill-Rite pumps. I have had excellent service from them one of my pumps has pumped hundreds of thousands gallon of diesel and have never put a vane kit in it. I have friends that have tried the knock of pumps and they just don't hold up. I have always ran a Cim-Tek fuel filter bases as most of the farm stores around here have the filters in stock. I run meters on all my pumps and a auto nozzle also. I think a 15 GPM Fill-Rite would be perfect for you.
JasonW
680
433
Al
We have a GPI 8GPM on a smaller 36? Gallon tank. Got it on sale at north tool I believe.
How much equipment are you filling? Just a BX25?
Don’t forget diesel foams, so the faster it’s pumped into the tank the more it foams up.
jyoutz
Jan 14, 2019
3,560
2,660
I wanted slow fill and opted for a fill rite hand rotary pump. Really, why complicate and spend more for pumping 10-12 gallons? The other thing about the fill rite rotary pump is that you can pump in reverse to drain the hose back into the storage tank when the tractor tank is full.
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
How much of a PITA is it to manually pump AND watch for the tank to top off? It forces the supply tank to be right next to the machines fill. This is my driving reason for electric.
Fill-Rite has a 8gpm which should be great for me, they say it is about the same speed as a typical gas station. My normal fill is one to four gallons so slower fill speed and being able to fill right to the neck is optimal.
Hard part might be that my caddy has a pipe welded in and not a bung. I suspect the pipe is metric and metric threaded and I may have to join the pump to the caddy with a nipple and a length of stout rubber hose with clamps.
I've sent an email to Fill-Rite.
jyoutz
Jan 14, 2019
3,560
2,660
I just wheel my tank next to the tractor, turn the key on and watch the tank fill on the fuel gauge while I turn the pump. As I stated, I prefer the ability to drain back the hose into the storage tank when I’m done filling the tractor. This is easy to do with the fill rite rotary pump; just reverse the handle turn. I’m not aware that the electric pumps will work in reverse, so that means a hose full of fuel and a messy situation.
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
Tractor fuel gauge will show full and there is still a gallons worth of space....
jyoutz
Jan 14, 2019
3,560
2,660
Yep, and I add a little more, but that’s close enough for me (11 gallons). I put my pallet with the tank on a short wheeled dolly so I can wheel it next to the tractor.
3,996
For such a small storage system….I’d keep the delivery system simple, and trouble-free, and cheap:
buy/build a rack and use gravity.
William1
BX25D
Jul 28, 2015
1,353
564
Richmond, Virginia
The issues with that is..... getting the fuel up 'on the rack' and having to have clear area to drive any machine that needs access. Hence a caddy on wheels and a pump. I can use my hoist to lift a full caddy out of my pick up and set it on the ground.
I got an email back from Fill-Rite, young lady was clues, talking about 115V pump and sizes of the output. She totally failed to see I wanted DC, and I was talking about diameter and thread pitch of the inlet side. I'll have to call I guess.
7,437
Geo, I agree. I don't use much diesel and the tractors are at different locations. I devised a system to pump fuel from the 5 gallon jugs, just didn't want to have to life them to remove fuel.
I had a battery powered (2 D cells) from Harbor Freight pump which did not last long. I removed the discharge from that pump and used it on a 12 Volt I bought. Also used the suction of the HF pump to connect to the 12V pump suction. Made a bracket to hang the pump on any tractor loader arm. Pump has a common connection like used on battery maintainers.
L4240 has a maintainer connection bolted too the battery terminals. I unplug the battery maintainer, plug in the fuel pump (it has an 8' cord with a switch near the pump) and it works excellent
I can take the pump with me to farm to fuel tractors there. I just plug in the short alligator clips to the pump wire and connect to the battery of any tractor.
I don't mind using the 5 gallon containers as long as I don't have to lift them onto the hood of a tractor. I also did not want a larger container of fuel to have to load to fill, much less transport to different locations.
