4x4 Front Differential not Engaging
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
First, thanks for letting me join.
Last March I purchased a lightly used (107 hours) 2020 M6060. I cannot get the front axle to engage. I've tried pulling up the 4x4 handle up in neutral, slow, front wheels lifted - nothing. Front wheels just won't turn (other than just rolling). The 4x4 indicator light does not come on either, so I checked the transmission control fuse and it looks new. Next I'm going to check the front differential/axle fluid level. Please let me know if I've missed a step or anything else I can check. TIA, Joe
6,484
The differential is always engaged. You are engaging the driveshaft going to the differential. I dont know the specifics of an M6060 but thats typically a sliding mechanical clutch of some sort.
Go to Messicks website and lookup rhe online parts drawing for your tractor.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
420
475
NE Ohio
Since there's a fuse for it, is there maybe a solenoid that engages the 4WD?
Firefight100
MX5200
Apr 3, 2021
101
79
63379 troy mo
a common fail is parts 10 &20. The pin fails and the splined collar slides, disconnecting the drive shaft to the front diff.
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
That would be an easy fix. Too bad it’s behind the fuel tank.
Exactly. Can't get my hands in there. Laid underneath and couldn't see anything disconnected. I just can't believe the pin would already be broken with so few hours, but on the other hand, I don't know how it was previously treated. I guess that should be the next spot to look. Seems easier than dropping the fuel tank.
JasonW
625
388
Al
If the 4wd lever doesn’t have any resistance, that’s where I would start. Probably just lost the cotter pin #220 and it came loose.
I would definitely try to see the linkage with a mirror or something before just dropping the tank. Dropping the tank isn’t too bad though.
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
Yeah I need to get my neighbor over to move the lever while I watch the linkage from underneath. If it was the linkage or even the driveshaft pin, would that cause the indicator light to not come on as well?
JasonW
625
388
Al
The switch for the light is on the mechanism that the linkage is supposed to be connected to.
10,193
Linkage being disconnectted or maladjustted would make the indicator not come on.
The front coupling being bad would not effect the light.
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
OK, I took some time off to do some land clearing, wood splitting/stacking, etc. Got back to the tractor this morning and the 4x4 pull lever linkage all seems to be intact. Actually, I can lay on the ground and move the link that goes into the transmission by hand, and move the pull handle up and down from there.
So next I loosened the telescoping tube on the front driveshaft. Couplers appear to be in good condition, and with flathead screwdriver holding output shaft, I can't turn the coupler (in neutral). Same on the front input shaft to the axle, coupler won't turn.
Next, I raised the front wheels up with the bucket. I can get out and turn both front wheels independently of each other. Turn one and the other does not turn. Does this sound like a broken axle? Or does the 4x4 need to be engaged for this to work?
Lastly, I believe there was some confusion with the switches and solenoid comments. Mine is the F8/R8 model (mechanical 4x4 shift lever), and not the F12/R12 with the 4x4 electric switch on the dash.
10,193
If you jack up the whole front and spin one tire and the other doesn't spin, does the propeller shaft spin at the same time?
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
OK, I just went out and tried it again. 1st try there was some ground friction on the tire when I said I could turn each wheel independently. This time I got the wheels all the way in the air. Now they turn counter to each other which seems more normal. And the propeller shaft spins when I turn the right wheel. But if I hold the coupler with a big channel locks, neither right front or the propeller shaft will spin.
But when I turn the left wheel, the shaft somewhat spins and seems to pause or skip here and there. If I hold the coupler with the channel locks, I can still spin the left wheel. I'm I narrowing down the issue?
I was discussing this with my brother and we think it may be in the 010 bevel gear assy of this diagram. Obviously not the best case scenario.
10,193
If you can stop the movement of the propeller shaft and get movement out of one tire or the other without the other one moving.
You have an issue somewhere in the system.
It's not very likely to be in the Pinion and ring gear if only one side is having an issue.
It's more likely in the Gears, shafts, or bearings for that the wheel.
Have you confirmed that the rear powers the proppeller shaft?
It's not easy to do because you would need to lift at least one rear tire of the ground, and turn that tire and see if the propeller shaft turns with the tire turning.
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
Do the test with it disengaged and with it engaged.
I raised both rear wheels up, and they turn counter to each other. Propeller shaft does not turn while spinning the rear wheels in either direction, with or w/o being in 4x4, nor in neutral or in gear. I have a feeling this is not good. Does it make a difference whether or not it's running or even just key on? Both were off.
Also, I noticed the heel pedal to lock rear wheels doesn't seem to be working. Starting to think this tractor was abused by the previous owner.
10,193
You must stop one rear wheel from spinning in order for the front propeller shaft to spin if it's going to spin.
You should not need it on or running for this to work.
Transmission might need to be in neutral.
