4x4 Front Differential not Engaging
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
First, thanks for letting me join.
Last March I purchased a lightly used (107 hours) 2020 M6060. I cannot get the front axle to engage. I've tried pulling up the 4x4 handle up in neutral, slow, front wheels lifted - nothing. Front wheels just won't turn (other than just rolling). The 4x4 indicator light does not come on either, so I checked the transmission control fuse and it looks new. Next I'm going to check the front differential/axle fluid level. Please let me know if I've missed a step or anything else I can check. TIA, Joe
6,384
The differential is always engaged. You are engaging the driveshaft going to the differential. I dont know the specifics of an M6060 but thats typically a sliding mechanical clutch of some sort.
Go to Messicks website and lookup rhe online parts drawing for your tractor.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
419
474
NE Ohio
Since there's a fuse for it, is there maybe a solenoid that engages the 4WD?
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
That would be an easy fix. Too bad it’s behind the fuel tank.
Exactly. Can't get my hands in there. Laid underneath and couldn't see anything disconnected. I just can't believe the pin would already be broken with so few hours, but on the other hand, I don't know how it was previously treated. I guess that should be the next spot to look. Seems easier than dropping the fuel tank.
JasonW
614
375
Al
If the 4wd lever doesn’t have any resistance, that’s where I would start. Probably just lost the cotter pin #220 and it came loose.
I would definitely try to see the linkage with a mirror or something before just dropping the tank. Dropping the tank isn’t too bad though.
TxWolfman
2020 Kubota M6060
Feb 9, 2026
Parker County, TX
Yeah I need to get my neighbor over to move the lever while I watch the linkage from underneath. If it was the linkage or even the driveshaft pin, would that cause the indicator light to not come on as well?
10,070
Linkage being disconnectted or maladjustted would make the indicator not come on.
The front coupling being bad would not effect the light.
