BX2750 Snowblower - shaft spins, chain doesn't move
BigCaddy
B7610
Jan 21, 2024
Central PA
Mine is back together and working great with a 1/4x20 coarse bolt, nut and locktite.
some helpful images. New shaft is welded.
BradJFelix
BX2370
Feb 1, 2026
Massachusetts
The solution? A broken pin where all the different schematics for a BX2750 do not show a pin! Thank you everyone for helping me with this. (A warm garage may have speeded up the diagnostic process...)
Hello, I recently ran into this same problem. Do you recall what sized roll pin you ended up using ? I can’t find the part # anywhere. Thank you!
10,078
There are 9 differnt revisions of that snow blower and they all take differnt parts.
10,078
Thank you, maybe I will just weld it. Based off the serial number it’s a 2011….. which leads me to believe it’s an earlier model. Appreciate the response!
Why in the heck would you weld it?
Just put a bolt through the hole with a lock nut, like everyone else has done.
FYI: The welded gear has a different collar design.
Welding that one could very well interfere with the bearings.
