Hydraulic Issue
Kubotadad
B1550
Jan 31, 2026
10
Ontario, Canada
I inherited a Kubota B1550 and know absolutely nothing about tractors. The current issue I am experiencing is with the front loader lowering. Raising and tilt work absolutely fine, but it takes forever to lower down...absolutely no pressure at all.
HELP!
6,372
HELP!
Whats the make and model of the loader?
Tilt works in both directions or just one?
Will the loader lift the front wheels off the ground?
6,372
HELP!
Are you sure you have the bucket and lift hoses connected to the correct ports on the valve? Sounds like you might have bucket and boom reversed.
6,372
Dont see anything obvious in the (excellent) pictures.
Do you see the two rods that come out of the valve body? Those are the "spools" that control hydraulic flow.
Move the joystick handle back and forth from raise to lower several times while watching the leftmost spool. It should slide in and out of the casting and stop in the mid point when you let go of ths handle.
Now compare that movement to the movement of the right spool when you move the joystick back and forth between dump and curl. Both spools should move the same (more or less) amount and automagically center when you release the levef.
2,612
You might want to check that the three point control lever is in the fully down position.
That effects the FEL in some cases since it can be releasing pressure from the system.
10,054
Well sort of,
Just not in the full up position
Because if the three point feedback is not adjusted properly it will put the hydraulic system into relief.
6,372
More precisely when for any reason the 3pt valve does not center it blocks the neutral circuit. Since most Kubita valves have serial spools on the boom that blocks the return flow from the lift cylinders preventing the boom from going up or down. That does not appear to be the case here.
6,372
The OP reported early on that the problem started with the boom spontaneously lifting.
Now, for the analytically inclined - what can cause that?
AFAIK not a bad coupler or a neutral circuit problem.
AFAIK that could only happen if the spool is shifted out of neutral or does not return to neutral. That might also be related to a problem getting the loader tobraise.
Hence my initial focus on the joystick linkage.......
10,054
Or the detent section.
Kubotadad
B1550
Jan 31, 2026
10
Ontario, Canada
3-point hitch is fully down
