Kubota B and BX series salvage yard
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
181
Attalla Alabama
mossycreekoutdoors.com
B7100 4wd manual tranny front driveline appears to have a cover with a rubber boot that holds it in place my cover and boot are missing slowly getting tractor rebuilt also shaft that connects to drive shaft is very loose that comes out of front diff is there a bearing or bushing in the cone shaped piece do you have these parts thanks in advance
Im sure i have the tube but have to look about the bushing. No bearing in the cone just the joint that connects the driveshaft to the pinion shaft. If its the pinion shaft thats loose then yes there are bearings that hold it. Just remove those 3 bolts fr the cone and have a look. There shouldn't be any oil in there but most of the time there is from leaky seals on the shaft
pgrovetom
BX25
Nov 21, 2025
31
Sonoma
Hello. I have a small kubota B and BX series salvage yard in northeast Alabama. Below is a list of what I have right now. Shipping available on most parts. Please let me know how I can help. Thank you
B6100e
B6100d
B7100d
B7100hstd
B7100hste
B7200hste
B7200hstd
B5200e
B6200e
B8200ep
B8200hste-p
B8200dp
B8200hstd
B1550hste
B1750e
B1750hstd
B2100Hsd
B2400hsd
B7300hsd
B7800hsd
BX1800
Bx2200d
BX2230
Bx2350
Bx2360
Bx2370
Bx2670
Bx22
Bx24
F2400
Also check out the knowledge base on my website for lots of information regarding manuals, how-to's, compatibilties, and much more. It's a work in progress and continue to post as I can.
Https://Knowledge-base.mossycreekoutdoors.com
Thank you
Daryl
Mossy Creek Outdoors
Www.mossycreekoutdoors.com
You wouldn't know where I might get a 2008 BX25 dash as seen below
B6100e
B6100d
B7100d
B7100hstd
B7100hste
B7200hste
B7200hstd
B5200e
B6200e
B8200ep
B8200hste-p
B8200dp
B8200hstd
B1550hste
B1750e
B1750hstd
B2100Hsd
B2400hsd
B7300hsd
B7800hsd
BX1800
Bx2200d
BX2230
Bx2350
Bx2360
Bx2370
Bx2670
Bx22
Bx24
F2400
Thank you
Daryl
I do have brackets for a b2400 but not for a b7100. I'll send you a message
You wouldn't know where I could get a 2008 BX25 K2771-99000 dash with Water temp and fuel gauges and RPM LCD display that looks like that below. The gauges are run on small stepper motors and the very tiny gears on the temp gauge gauge is stripped.
Messicks https://www.messicks.com/parts/kubota/K2771-99000#locator
Outside
Inside assemply
Schematic
Or have any idea where I might get one? I've scoured Kubota parts and non-official Kubota parts and nobody has one. My only hope is too find a used one from a junked 2008 BX25. I was told this gauge was used for only 3 years on the early BX25 and a few other models.
Tom
Mountainman
Jul 10, 2022
443
181
Attalla Alabama
Outside
Inside assemply
Schematic
Tom
Sorry for the delayed response. Your only option really is part K2751-99000 as far as availability. But its $850. That is the newer style with lcd but has the adapter to work with your bx25.
Very rare that they still work when they come in salvage.
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
27
Denver North Carolina
I have a BX22D I am restoreing and need the mowing deck and backhoe. I have the mounting bracket for the backhoe thanks also do you have that band clamp that goes around the air cleaner mine is broke. 20260128_075515558_iOS.jpg
3,365
…. also do you have that band clamp that goes around the air cleaner mine is broke.
My BX 2200 is the same tractor (without the loader and backhoe). After repairing a broken air cleaner strap several times over the years, a year or two ago came up with this solution which is a winner, for me anyway. KISS solution- cheap imported bungee cord (picture taken about a month or two ago):
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
27
thought maybe getting a aluminum or metal thin flat stock and bending it thanks for the insite that it will break so dont buy one
3,365
Initially I took the two ends of the broken strap and bent them back into hook shapes.
Made a rubber loop using a bicycle inner tube to hold them together and it functioned for a while, but the metal strap broke again in a different place.
Part of the issue is that the BX engine shakes rather violently when you turn it off. I’m not sure if this is the main contributor or not.
TommyBX24D
BX24D Serial #: 57415, Engine Code: D902-ES02, Frontloader: LA240 Backhoe: BT601
Mar 14, 2026
Woodbury, CT. USA 06798
Outside
Inside assemply
Schematic
Tom
Howdy, I'm also looking for the K2771-99000 kit for my BX24D.
My understanding is the kit contains the following:
K2771-62502: The new Meter Panel/Cluster.
K2771-91112: The Adapter Wire Harness (required for the new plug).
K2731-57160: A panel stopper/mounting hardware.
Instruction Manual: For modifying the dash opening (slight trimming).
Messicks states the part has been discontinued, and eBay doesn't seem to offer the entire kit.
Would greatly appreciate any guidance from the forum. Thanks.
rattub
Tractor
Mar 14, 2026
17
NJ
B6100e
B6100d
B7100d
B7100hstd
B7100hste
B7200hste
B7200hstd
B5200e
B6200e
B8200ep
B8200hste-p
B8200dp
B8200hstd
B1550hste
B1750e
B1750hstd
B2100Hsd
B2400hsd
B7300hsd
B7800hsd
BX1800
Bx2200d
BX2230
Bx2350
Bx2360
Bx2370
Bx2670
Bx22
Bx24
F2400
Thank you
Daryl
Hi looking for 2 vintage Goodyear 20.5 x 8 - 10 trailer/tractor tires, wondering if you by chance would have a couple in stock either nos or used any leads would be
B6100e
B6100d
B7100d
B7100hstd
B7100hste
B7200hste
B7200hstd
B5200e
B6200e
B8200ep
B8200hste-p
B8200dp
B8200hstd
B1550hste
B1750e
B1750hstd
B2100Hsd
B2400hsd
B7300hsd
B7800hsd
BX1800
Bx2200d
BX2230
Bx2350
Bx2360
Bx2370
Bx2670
Bx22
Bx24
F2400
Thank you
Daryl
rattub
Tractor
Mar 14, 2026
17
NJ
B6100e
B6100d
B7100d
B7100hstd
B7100hste
B7200hste
B7200hstd
B5200e
B6200e
B8200ep
B8200hste-p
B8200dp
B8200hstd
B1550hste
B1750e
B1750hstd
B2100Hsd
B2400hsd
B7300hsd
B7800hsd
BX1800
Bx2200d
BX2230
Bx2350
Bx2360
Bx2370
Bx2670
Bx22
Bx24
F2400
Thank you
Daryl
Hi looking for 2 vintage Goodyear 20.5x8-10 trailer/ tractor Tires either nos or used in stock, any leads would be greatly appreciated. Thanks!!
johnjk
Apr 13, 2017
1,758
2,083
West Mansfield, OH
Looking for a seat belt latch that will fit my B1700. Kubota gives it part # 6c040-72252. Thanks
