Electronic torque wrenches ... are they worth the cost?
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
Isn't Lowe's a Craftsman seller ? If so ... it should be lifetime warranty ??
Read the fine print. The short answer is, not really.
Other sources are saying the same thing. The fine print is doing its thing as usual.
I don't really see a reason to buy Craftsman any more. That famous guarantee is now worth a lot less than it used to be. I expect the brand to die in the next few years, and that guarantee will be of ZERO value at that point.
5,577
Don't go BBBBBRRRRRT Brrrt Brrrt on one bolt and then just do 3 short bursts on the next one.
This was/has been my preferred method for years.
I got “torque sticks” a few years ago though……..My lips were getting sore from the constant BBBBBBBRRRRRT’ing. ;)
Never had an “electronic" torque wrench though…..Mine are all “click type” (except my inch pound one, thats a dial type)
Kennyd4110
Vendor Member
Sep 7, 2013
1,527
910
Westminster, MD
www.boltonhooks.com
I went with one of these, I find it works great and I can use it for a lot of things-plus I already have lots of breaker bars. 12-250ft/lbs covers most everything for me here.
It may not be 1000% accurate, but it will at least get all the fasteners tightened equally, and to me thats more important than if its 95ft/lbs or 98ft/lbs.
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
mechanical torque wrenches aren't maintenance free. All good ones need care and calibration from time to time to keep them in top shape.
The single most important thing required to keep them accurate is to back them off to 0 after use.
Mechanical "clicky" torque wrenches rely on accurate and repeatable spring tension. Springs will take a set over time if left compressed. Backing them off for storage prevents (or at least dramatically reduces) this.
Electronic torque wrenches utilize a pressure transducer of some sort -- and there are at least 5 different sorts, each with it's own advantages and disadvantages. But ultimately they all rely on changes to an electronic circuit to measure a variation in voltage, resistance or capacitance and all electronic circuits are susceptible to degradation over time.
Cheap mechanical torque wrenches will use cheap spring steel. Cheap electronic torque wrenches will use cheap circuits. Of the two, I believe the cheap mechanical one stands a better chance of being accurate 5 or 10 years down the road in the hands of an occasional user because they can limit the degradation by backing it off to 0 but there's nothing they can do to prevent aging of an electronic circuit*.
But that's just my 2¢, unsupported by any empirical study.
*Technically the battery and contacts form part of the circuit, so removing the battery for long-term storage might help prevent damage to contacts if the battery leaks.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
That's like $7,000 USD in dremometers you've pictured, not including wooden caskets.
Seriously? Never knew that inflation is that high :oops: .
But for personal use they are accurate for life. And you can calibrate them yourself. The mechanism does not rely on friction, as a lot of other designs do. Also torque does not depend on where on the lever you pull with your hand.
The shocking part is really that, despite the price, they come in a cardboard box so flimsy that it falls apart after opening it about three times. Hence I built the wooden boxes myself at some stage.
Seane1987
LX2610SU TLB, BX2350
Jul 18, 2021
61
54
Lafayette NY
I am a diesel tech by trade, I have the latest Snap On Techangle 3/8 and 1/2" torque wrenches. I honestly don't really care for them, they are not the most user friendly tool out there. I bought the very first snap on electronic torque wrenches when I was in college in 2005. I still have the 1/4", and it still works just has good as the day I got it. The 3/8 and 1/2" versions I traded in on the newest techangle version a few years ago. I used to do quite a bit of engine work, so I used the torque angle feature alot. I have since groomed some new guys to do my dirty work so I do mostly diag and electronics now.
I would take a hard look at split beam torque wrenches, I have a 3/4 split beam torque wrench at work for the big stuff and it is probably my favorite style for ease of use. You also do not need to wind them down to 0 when not in use to preserve the accuracy.
I am looking at these for home, tekton stuff is hard to beat for the money. Also THE FLEX HEAD ON THE TEKTON IS A MUST! Don't buy a torque wrench without a flex head!
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Milwaukee, Wisconsin, U.S.A.
Yup, they're around $2,100 USD depending on the model, plus shipping and tax, and the rachet mechanism is extra. The blow-moulded plastic box is $300, it must be a status symbol for that price. Used they're $1,200 if used hard and pitted, $1,900 if in close to new condition, $125-$300 if broken, at least for what I saw available in the USA. I know of a guy who got a non-working one for $50+S/H though that is an exception and it was in a bit of rough shape.
Maybe they're less in other countries, but they do appear to be everything you describe (and sexy looking).
WI_Hedgehog
Apr 24, 2024
1,130
1,647
....I would take a hard look at split beam torque wrenches, I have a 3/4 split beam torque wrench at work for the big stuff and it is probably my favorite style for ease of use....Also THE FLEX HEAD ON THE TEKTON IS A MUST! Don't buy a torque wrench without a flex head!
$$$ o_O
I don't like my nuts that much. :ROFLMAO:
dlsmith
BX2230, LA211
Nov 15, 2018
1,366
1,064
Goshen, IN
I have Snap-On 3/8" and 1/2" twist handle torque wrenches from the 80s, and a friend who repairs tools checked them a couple of years ago for me, since I do some engine work. Both were still with 2% over most of their ranges. They don't see a lot of use, but I am religious about backing them all the way off after use.
11,757
This morning I was watching a YouTube channel that I subscribe to, and a Caterpillar bulldozer head was being reinstalled. He was using an electronic Snap-on flex head torque wrench to tighten the head bolts. It occurred to me that being an electronic wrench, it could account for the change in angle of the head and therefore adjust for the actual torque being applied based on that angle. That's definitely a big plus for electronic torque wrenches.
The TEKTON micrometer torque wrenches I ordered don't have a flex head, which makes sense since there would be no way for the wrench to adjust for angle.
11,757
The TEKTON torque wrenches showed up yesterday along with a cryptic message from USPS and Amazon. The wrenches are typical TEKTON quality and it's no wonder that the brand has become my tool brand of choice over the past few years. They're mostly made in Taiwan and not China which works for me, they're not crazy expensive, and the quality so far has been nothing short of excellent.
I used to buy Proto and the high end NAPA stuff, but it's just so easy to order TEKTON now. I'll be using the largest wrench today to check the lug nuts on my F-250.
11,757
Here's the cryptic part, I received a text from USPS late yesterday (after I'd picked the package up) to inform me that the delivery was cancelled, and then received an update from Amazon to tell me that the order was cancelled and that I was getting a refund. I have no idea what's going on. Here's a redacted screenshot from Amazon's website.
