Cracked block - fixable?
Vanguard08
B7 100 HST
Jan 6, 2026
Tennessee
I've got a b7100 HST that had a leaky radiator that I've replaced. I haven't had issues since I put the new one in but I'm guessing I've got some nasty cold damage. I started it up a few days ago and noticed my radiator was empty so I filled it up but saw a pretty tragic drip of water underneath and traced it back to a crack on the block.
1) What did I likely do wrong or didn't do right that would cause such a crack? I can only think of running it hot or freeze damage
2) Can this be repaired with a weld or do I have to tear this whole thing down to replace?
Here's a picture: the left side shows where the crack is, it's on the backside near the fuel tank. The right side shows the crack itself.
I can take more pictures or a video or something if it's helpful. Hoping this can be repaired but guessing not so much so hopefully I can at least learn a lesson here.
Hugo Habicht
G1900
Jun 24, 2024
1,534
2,200
Ireland
Well, we had that subject a while ago: Link fixing hole in side of the block , not to be taken too seriously.
If it was frost damage there could be more than just this crack in the block. But if you want to risk the rest of the engine you can try JB weld, as Joe Smith used in the thread above.
10,866
That does not look like the block that looks like the head, more pics and zoom out a little.
If it is the head that's cracked, then you're more than likely looking at a head replacement.
Much cheaper and easier than replacing the block.
And over heat or freezing can cause that style of crack.
#40Fan
575
412
I want to say that is where the head meets the block and they are both cracked.
Vanguard08
B7 100 HST
Jan 6, 2026
Tennessee
yea... I was gonna go out and take another picture but I'm fairly sure you're spot on. The crack started below but just traveled right on up. I'm gonna try some JB weld to see how much more I can get out of it... other than hopeful duck tape limp-a-longs, I guess I'll start looking for parts and salvage rigs to see if I can rebuild it.
Mark_BX25D
Bx25D
Jul 19, 2020
2,102
1,606
Well, if you are going to go that route, make sure you clean it cleaner than you think is possible.
#40Fan
575
412
Yep, take a propane torch to it and get it hot to boil off any oils/fluids.
I doubt it will hold, though. Maybe if you pull the guts out of the radiator cap to keep it from building pressure.
10,866
This is a thermosiphon system.
Altering the radiator cap in itself will make it overheat.
BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Mar 20, 2016
95
188
Evansville, IN, USA
Likely since the radiator was leaking the PO was just adding water, assuming it would leak right back out. If you are going to use JBW, I'd at least try to grind a small V-shape into the crack. Not only gives significantly more surface area for adherence, but also a nice contaminant free zone.
Vanguard08
B7 100 HST
Jan 6, 2026
Tennessee
Curious what you mean about grinding a V-shape into the crack. I'll clean it off as well as I can and I'll torch it to make sure to boil off any remaining residue to give the JB as much of a fighting chance as I can, but what would be the point in grinding into the crack? Is that just to grind away a small surface area so to have fresh clean metal to apply the JB to?
10,866
Yes that typically would be what you want to do.
But in your case don't do it, as that metal is so thin that you will be opening a real can of worms.
If that crack is only the head, then your chance of success is possible but low.
If the crack extends from the head into the block, then your chance of success diminishes into almost nothing.
Vanguard08
B7 100 HST
Jan 6, 2026
Tennessee
Well I'm filled with encouragement now...
Maybe I'll take a Dremel and just lightly buff the area around the crack
Hugo Habicht
G1900
Jun 24, 2024
1,534
2,200
Ireland
I would not cut a groove. The rough crack has best adhesion for the glue against pressure from inside. Clean everything meticulously, brake cleaner may work well here. And then heat everything if you can. Epoxy glue get very soft then and creeps into the gap.
airbiscuit
Mar 18, 2021
400
459
NW WI
I had a Farmall H with a crack at the bottom of the rear end. I cleaned it well, touched it with an angle grinder to expose bare metal, cleaned it with lacquer thinner and applied JB Weld. It lasted for decades.
Reactions: 6 users
L35
Jun 13, 2010
703
827
CT
I hate to be a pessimist but I’m in the “don’t waste your time” camp. JB weld has its uses but in a pressurized cast iron situation with large temperature swings it usually fails due to expansion/contraction. It’s a cheap experiment and I hope to hear the end result after a dozen or so heat cycles. Don’t leave us hanging!
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,161
1,753
Pittsburgh
There was another thread around here concerning an epoxy repair on a block...
6,453
Yeah. That thread was… unusual. Some sort of comedy about a guy fixing a busted block by gas welding an old cast iron frying pan into the hole among other ridiculousnesses.
I vaguely recall posting about the JB Weld repair to a crack in the water jacket on this Ford 2N, 9N, 8N with a Ferguson hood junkyard compilation I grew up with. My father had repaired the crack with some sort of epoxy like substance when he bought the part with the engine a couple years before I was born. Whatever that was failed when I was a teenager. Started weeping noticeably. I was tasked with cleaning it up and repairing the crack with JB Weld. Job specs required it not leak; appearance irrelevant. After chipping off the old, failed whatever prior sealant was on it, a wire brush on a drill and brake cleaner got it ready for the JB Weld. IMG_9640.jpeg
If you zoom in on the side of the block in the below pic, I think you can see the side of the block looks sort of melted. That’s my not very pretty slathering of copious amounts of JB Weld over the damaged area. Would have been in the 1979 to 1982 range. Don’t recall exactly. IMG_9651.jpeg This was the last day I saw it. November 2022. Loaded up to head to a new home. Still ran perfectly well. My ugly JB Weld crack repair was still holding water.
IMG_0023.jpeg Anyway, that’s my JB Weld story.
Reactions: 6 users
