2023 Grand L6060 3 pt locked up
OldSchool59
L6060 HSTC, Rhino Ag TW36 , American Ag 72” land plane,
Jan 15, 2023
68
20
Something new and I don’t like it a bit . A couple of days ago I hauled my tractor to my other home place to do some work and when I got there the 3 pt would not lower . It’s all the way up and completely stuck . No- the speed adjustment is not shut off or locked off . The draft lever and linkage is working all of the way to the case but Nothing after that point ! I have a hydraulic top link so I tilted it all of the way down, tied a chain on it tight to my trailer, tilted it up which put major downward pressure on it and no movement . Any help would greatly be appreciated.
Thanks
6,965
Thanks
Hydraulically the only thing holding it up is the oil in the lift circuit. Either the control valve is not opening or the lowering speed valve is closed.
SDT
Apr 15, 2018
3,642
1,372
Thanks
Bit confused but it sounds like your tractor has the optional draft control kit. If so, I would look to this linkage first.
The draft control system used on the GL tractors is a Rube Goldberg external linkage design that is rarely (if ever) installed and adjusted properly. First check that the feedback linkage has not been damaged or become unconnected.
FWIW, the troublesome draft control mechanism used on these tractors is often removed due to customer complaints.
Of course, you have already verified that the draft control lever is fully in the "off" position???
OldSchool59
Jan 15, 2023
68
20
Dangit - not the draft but the 3pt lift ! I’m sorry
OldSchool59
Jan 15, 2023
68
20
They are one and the same. Assuming the lift is hydraulically suspended the control valve is not opening.
Thank you Sir! The shaft from the linkage has a collar on it attached with roll pins. I thought one of the pins may have sheared but the whole connected shaft is turning all of the way into the case. Something isn’t connected anymore on the inside. I could tear it all apart but it’s still under warranty. I just don’t trust mechanics anymore .
Thanks again Sir, I certainly appreciate it .
6,965
Dont jump the gun. Inspect the other side of the case especially the feedback linkage.
SDT
Apr 15, 2018
3,642
1,372
Agreed, and the optional Rube Goldberg draft control mechanism (if installed) does affect the control valve in certain situations.
Need to know if the OP has two three point lift control levers (draft control has been installed) or one (no rare optional draft control system).
Still confused.
SDT
Apr 15, 2018
3,642
1,372
Agreed.
I haven't trusted mechanics ( or just about anyone) since the early 60s.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,898
2,312
Western MT
If you can pull a pin for the top/tilt, it might drop. I don't know how it connects. Then work on the top/tilt which is probably what's holding it up.
OldSchool59
Jan 15, 2023
68
20
Still confused.
1 !
OldSchool59
Jan 15, 2023
68
20
the pin could be easily pulled! The top tilt is working fine . I’ll dive back into it after I get out of my bow blind tomorrow morning and let y’all know what I find ! I really appreciate everyone’s help.
OldSchool59
Jan 15, 2023
68
20
The f
In that case, thoroughly inspect the feedback rod as suggested earlier.
The feedback rod is not moving! My bet is something is broken or has come loose inside the valving on top of the case .
OldSchool59
Jan 15, 2023
68
20
Well, it’s been a minute. I found hydraulic fluid leaking from the transmission, so I took it in after cleaning and drying everything to locate the source. They had to split the tractor due to a bad RTV seal—it showed up after 500+ hours. Thankfully, it’s covered under the extended warranty I purchased.
Now, back to the 3-point. They’re telling me both cylinders are locked up, to the tune of $1,800. This tractor is stored inside my insulated shop on a concrete floor whenever it’s not in use. They’re claiming the tops of the cylinders are rusted up. I haven’t personally inspected that yet since the tractor is an hour away, but I just don’t see how that’s possible. They’re also saying it’s because I leave the 3-point raised when not in use… hmm.
I’ve been looking at the diagram, and what they’re saying doesn’t add up to me. The three-piece shaft at the bottom of the drawing is functioning correctly with full range of motion on the right side, but it’s locked up on the left. From what I can tell, neither side should be able to rotate independently given how they’re linked together. That makes me think something is broken internally.
I’m heading back over there Monday before they reinstall the cab, and I want to have my ducks in a row. Both cylinders failing at the same time? I’m skeptical. I don’t mean to sound distrustful of the mechanics—they may very well be correct—but what I’m being told just isn’t meshing with me.
6,965
Makes sense to me but if in doubt remove the cylinders and bench test them. Or unhook one side ant test the other side on the tractor.
