B2714C SnowBlower Compatibility
northermi2650
2014 Kubota b2650hsdc
Feb 17, 2025
northern Michigan
Question before I get my hopes up too high. I'm currently running a B2782B 63" front mount snow blower on my B2650. My current snow blower is unsettlingly worn out. There's a BX2750D for sale in my area that looks to be in better shape for a really good price. does anyone know if the female hitch on the BX2750D would match up with the male end of the B2714C subframe? the pictures appear to be close, but I figured id come here to see if anyone else has had any experience with running a BX series blower on that subframe or if they're universal at all. Thanks!
number two
B3030HSDC L2501HST
Mar 26, 2021
408
194
Northern Lower Michigan
If your B2782B is worn out,you will will not be happy with a lesser quality blower that you are asking about!
Witch most likely won't work for you without much money spent.
Good Luck!
Spam Bot
Windows Computer
Aug 3, 2024
174
128
Austin, Minnesota/Key West FL
What is explicitly worn out on your snowblower? I know this isn't the time to start rebuilding snowblowers unless there is no other choice, but when spring comes, price out the parts to repair your current blower. If you need a new case, they are expensive, but compared to the cost of a new blower, it might be a good alternative. As an example, you can make a BX2750 snowblower into a BX2816 snowblower by changing out the hitch and the drive on the rear of the blower. I learned this when a local person had a worn-out BX2750 blower and purchased a used BX2816 and swapped the two parts. I bought the old BX2750 for spare parts for my BX2750 blower. I sold that tractor, and I still have the parts from that blower. The only thing that was wrong with it was that the case had rusted out. Snowblowers are not particularly difficult to work on if you have patience and warm weather.
northermi2650
Feb 17, 2025
northern Michigan
Appreciate the input! I’ve already talked myself out of the other blower (and it sold already) I’ve spent some time on Messick’s and I’m getting a list of parts I’ll pick away at replacing hopefully in the spring.
northermi2650
Feb 17, 2025
northern Michigan
Good Luck!
yeah I already bailed on the idea of it. The plans to spend the money on parts for the b2782b, and just do a big service to it. Fingers crossed that service will be done in the spring not in a snow storm
Spam Bot
Windows Computer
Aug 3, 2024
174
128
In the spring, I would tear it down and examine all the parts, with particular attention to the gearbox that drives the augers. The gears in that are brass, and they no longer sell service parts. You have to purchase an entirely new gearbox. You can find some YouTube videos for assistance; however, after doing the job and watching the videos, I have found that some of them have mistakes in the process, never acknowledge that they made an error, and continue on as if it never happened.
