BH92 Stabilizers drop while driving
racerboy
L6060 Cab, 1055 loader, grapple, BH92; RTV-Cab
May 10, 2021
233
208
NJ
I went to use my L6060 this morning to clear some trees that came down in the windstorm we had last night, and as I’m driving down my gravel driveway, I thought my right rear tire was going flat b/c it felt like the tractor was leaning to the right. Turns out that the left-hand stabilizer put itself down and lifted the left rear tire off the ground. I called my Kubota dealer right away, but he didn’t have a solution, other than perhaps the lever for the stabilizer got stuck. It took some time to get the stabilizer back up. I used the tractor all day and when coming back to the house the same thing happened. Only one stabilizer was down, not both. I had to put the other one down. The lever wasn’t working at first. I finally got both of them upright and got it back to its parking spot. I noticed that there was hydraulic fluid everywhere, especially on the space where your feet go if you were using the backhoe. I think the problem is either with the foot switch for the hydraulic thumb or with the actual stabilizer levers. I posted some pics below. The fact that there is hydraulic oil above all the hoses on the platform makes me believe this is not a torn hose or anything. I’m assuming this is something tgat would be under warranty and the dealer should fix (I have less than 20 hr on the tractor).
7,237
View attachment 167282 View attachment 167282 View attachment 167283 View attachment 167284 View attachment 167285
I assume you have checked for and eliminated external hydraulic leaks.
Since it hsppened suddenly I would suspect you hsve a leaking piston seal in that cylinder.
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
Doesn't sound like a "leak down" situation to me, if I read it right ... If one stabilizer is LIFTING a tire, it's getting hydraulic power from somewhere ... Strange that a leak would also happen ... And controls would be unresponsive for a bit ...
Are the control levers loose flopping around? They should have some resistance and return to "center" by themselves.
7,237
Its clearly leakdown in the extend direction. It can extend with a leaking cylinder and once extended will hold a compressive load.
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
I guess if it leaked down while that one side went over a low spot, then dragged back up to a high spot it might lift a wheel?
racerboy
May 10, 2021
233
208
NJ
Thanks for the feedback. If it was the cylinder, how did hydraulic fluid get up on the platform where your feet go? That’s what confuses me. And it does appear that the biggest puddle is by the foot switch for the hydraulic thumb.
7,237
Looling at the pics theres a massive externsl leak. That should be easy to find. If you can get it fixed under warranty great but if you snagged a hose I would not expect warranty coverage.
5,329
I also vote for cracked/split/leaking hose.
I had a “similar problem” once, and had to “chain it up” to get it back to the shop.
But mine was "very obvious".
racerboy
May 10, 2021
233
208
NJ
Ok. I I’ll investigate for a leaking hose. In the meantime, can I disconnect the hydraulic hoses (as if I was removing the backhoe) but leave the backhoe attached? I have a ton of dead tree cleaning I want to do over the Christmas holiday and want to leave the BH on for ballast.
which color hose goes where if I did this?
7,237
Why disconnect the hoses?
racerboy
May 10, 2021
233
208
NJ
My concern is that I run into the same issue with the stabilizer dropping on its own before I can get it fixed.
racerboy
May 10, 2021
233
208
NJ
But I want to continue to use my grapple in the meantime.
JonM
Nov 29, 2024
277
662
wisconsin
with the tractor off disconnect the hose that goes from the backhoe to the tractor and the hose thst comes from the tractor to the backhoe. connect the backhoe into itself and the tractor into itself.
if you do this and there is a leak the backhoe stabilizers can lose pressure as can the backhoe bucket and stick and boom.
it is not a good idea to operate it until the leak is fixed. the brush aint going anywhere.
i installed the kubota hydraulic thumb on my bh92 myself its not an easy install to plumb the hydraulics. there is a way to shortcut it that makes the job easier but it can easily lead to leaks if its done. you only got 20 hours and its coming from around the station which houses the hydraulic spools. my guess is whomever did it messed something up. its damn easy to do with a very difficult install.
racerboy
May 10, 2021
233
208
NJ
Dealer is coming to pick up the tractor on Friday. Like JonM said, the brush can wait.
racerboy
May 10, 2021
233
208
NJ
Happy New Year everyone. I heard back from my dealer last Friday. He said that they found that the o-rings in a valve for the backhoe (he didn’t say which valve) were blown due to the hydraulic pressure being too high. They were still trying to figure that part out. I’m going to call again tomorrow to see if there is any update.
7,237
There are no oring seals in the valve that hold any cylinder in position
Orings are on the low pressure tank cores and typically fail due to excessive back pressure on the tank port.
None of that explains your problem. Cant wait to hear their analysis.
