Looks like the pup is all grown up now!did 2 of my driveways and the horse farm. Old rear blade did fine on 5-6" of snow.....brrr
Thanks! I have R1 tires - not sure if that affects it. Would you recommend chains all around or just for the rear tires?I'd start with some chains for this year. Won't hit your pocketbook too hard.
Thanks! I haven’t slipped yet but it’s been packed snow and fresh snow no ice that I can tell. My main concern was if I got a snowblower or heavier back blade that I would be able to get up the hill and still clear snow or if I would run out of traction or power.I have the same tractor with R1'S. I have a long steep driveway with loaded tires.
I have no need for chains and would give it a go without them and see how that works.
Loaded tires give them more bite.
Not sure if the loader and snow blade are posed for the photo, but something looks off. Are you running it in that orientation with the loader raised up?Not a lot of snow but enough to start learning with this thing (from Homestead).
I think maybe I had just pulled forward from a back drag from an area I pushed more gravel than I intended. When pushing want to say lift arms were more down and dump / tilt plane was more upright. Open to input on proper use. First time using and was creeping around turtle speed trying not to wreck the gravel but still get some snow off.Not sure if the loader and snow blade are posed for the photo, but something looks off. Are you running it in that orientation with the loader raised up?
OK ... just checking. Don't want you to damage that nice tractor.I think maybe I had just pulled forward from a back drag from an area I pushed more gravel than I intended. When pushing want to say lift arms were more down and dump / tilt plane was more upright. Open to input on proper use. First time using and was creeping around turtle speed trying not to wreck the gravel but still get some snow off.Mostly successful (after a few high angle back drags) but no speed records were in jeopardy!
Looks like a hallmark movie almost in there. Very nice.Used the snow blower for the second time to clean about 10" of fluffy stuff. I need to work on my strategy around the round about close to the house... It's pretty inefficient for now.
Here are the temporary winter quarters. Hopefully just for this winter...
Doubt if I will be putting in more than 100 hrs/year. Last few years with the NH were closer to 50hr/year. I think I spent almost as much time doing maintenance on it than seat time. Way too many zerk fittings. More so when the old Lincoln battery powered grease gun died. Forearm workout. Who needs a gym membership. Made the annual oil and filter change a bit costly/hr. Changed the coolant from a Rotella brand to supposedly a long life Yanmar brand to extend the maintenance period for at least the coolant.Tractor is now at 654 hours. This means I've put 100 hours on it since getting it last January.
You didn't mention how long the driveway is. Ours is only about 100 yards. Couple of thoughts. If it isn't too long, can you move the banks back with the loader? I got by with only a rear blade for about 10 years. Next it was a combo of a rear blade and a loader. Then a rear-mounted blower and finally an 8' front blade.Plowed the driveway at the place I just moved to. It has a pretty good hill and honestly I’m thinking I may need to get a snowblower or a bigger machine. The place I am at now is in a snowbelt I guess but basically gets 130” of snow minimum per year. The old back blade works but I’m gonna run out of places to drag it to efficiently. I was looking at the land pride sbp11. It’s the pull behind snowblower where you can drive forward. If anyone has any feedback on that model or advice for snow in general (with steeper grades) with a smaller tractor I’m all ears. Won’t be getting anything new till next winter probably.
