A New Oil Thread
Where do you like your oil on the dip stick to read?
  • below min.
  • right at min.
  • between min and max.
  • right at max.
  • slightly above max.
Results are only viewable after voting.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,196
1,181
E.
regardless of peoples hate for oil threads... this morning I decided I would start a new one.
Most days the "old farmers club" meets at our local coffee shop (the kind the has waitresses not baristas) and that serves only the 2 approved forms of coffee in these parts (full strength or decaf) accompanied by the the only 3 approved sides (a slice of pie, a couple of eggs and maybe a couple of shingles with jam not honey).
Today's discussion was about oil changes and how much oil gets added to the pan.
It was unanimous that we all measure our used oil drained prior to refilling. The amount measured out guides the amount we pour back in.
The question then was on the dip stick, where do you like to keep your level?
Me, I tend to fill to the absolute full mark and admittedly sometimes get a smiggen above as often as I get a smiggen below. Hard to hit the exact full mark. Is this right or wrong?? I have no clue but it is what i have done since... well can't remember when I made my first oil change.
What say you about where you like to keep your fill levels or better yet argue what is best spot on the stick to keep your fill levels?
cheers and merry christmas all.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
For me, it's within the upper 2/3rds of the min/max range but not right at max.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
Between min. and max. is what is required.
After an oil change it is max though I do not top up to maximum in between just to throw out the new oil with the next oil change.
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
118
97
duluth mn
I am to damb OLD, and not able to change oil in anythinge bigger than a lawn mower, so it is between full and add lines!
Come to think about it I may not even be able to change that!
Have to get son inlaw over but will have to watch over him to make sure he does it right!
Don
11,757
It's the full or max mark for me.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
That's similar to my approach, although I do add some if it's in the lower quarter.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,475
668
Richmond, Virginia
Max. Oil never rises unless something is wrong, otherwise it always drops over time.
7,685
MLF, get your partners on a discussion on bypass filters. I've used the Frantz filters on a few vehicles and when you tell someone you use toilet paper in an oil filter they go off the rails! I bought TP by the case at restaurant supply store. Installed one factory oil filter on a Nissan Diesel with less then 20K miles on the engine and never removed that filter.
Oh, I keep an engine oil level to the top of the knurling.
MapleLeafFarmer
Dec 2, 2019
1,196
1,181
E.
MLF, get your partner on a discussion on bypass filters. I've used the Frantz filters on a few vehicles and when you tell someone you use toilet paper in an oil filter they go off the rails! I bought TP by the case at restaurant supply store. Installed one factory oil filter on a Nissan Diesel with less then 20K miles on the engine and never removed that filter.
for those that don't know.... Frantz bypass kits use rolls of toilet paper inside a canister. oil flows through the roll of TP. The claim is never need to change oil again and engine will last longer with a continuous supply of ever clean oil.
the toilet paper cleans up all the crap that the oil is carrying.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
In the past on the blue tractor. Above 1/3 but below max. But usually close to 3/4-max after an oil change. Probably stick with the same on the Orange tractor. My lazy attitude of not topping off to max didn't seem to hurt the NH.
OT: has anyone had an oil test done on their used Kubota tractor oil to diagnosis any potential bad thing that has or might happen. No options up here. So never have had an oil test on the vehicles or tractor. Just oil and filter change at least annually.
7,685
View attachment 166872 View attachment 166873
I was driving a lot of miles each week. I changed the TP roll every other weekend. I really don't remember how frequently I changed the oil, but it was never dirty.
Guys want to argue about the idea of TP dissolving and plugging up the oiling system. As an experiment, lay a layer of TP out flat and put a couple drops of water on the paper, then do the same thing with motor oil. Totally different results.
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Carefully sneak up on Max for me.
Usually, check again after the next cycle, but I have come to realize that I have an ocd problem with the number of vehicles and engines that I maintain. I always want to know whether it uses any in-between changes or on very long trips.
Is this in danger of turning into an "oil" thread? ;)
6,856
My L4701 is the first, and only, Tier 4 common rail diesel I’ve had to maintain. I don’t claim to know everything about it. I do know it’s quite a bit different from the 60’s and 70’s diesels I’ve dealt with in the past so I lean heavily toward following manufacturer instructions.
Kind of interesting to me what the OM for my L says about oil level. Under the “Daily Check/Engine Oil” section it says to make sure it’s “between the notches”. Also says the DPF (regen) process might increase the oil level slightly. Never seen that happen, but duly noted.
IMG_7349.jpeg The section on changing the oil says to fill to the upper notch on the dipstick. So I take it you’re supposed to fill it to start off with new oil right at max. After that, just make sure it’s within the safe operation range.
So I guess my SOP to keep it right at max is more a personal preference rather than a requirement. From a logical perspective, there’s no point in an operating range if it’s truly unacceptable to be anywhere except the top of the range. Also, at not quite 600 hours, so far it hasn’t lost any oil. I’ve never needed to add any in between changes to keep it at the max mark. IMG_7348.jpeg
BobInSD
L5740
Jun 23, 2020
374
129
South Dakota
In the summer I keep it (tractors, mowers, & vehicles) right at max since I figure the oil helps cool the engine. In the winter I keep it at or above halfway between min and max, figuring less oil to heat up and less oil to boil the condensation out of.
Since my kubota doesn’t yet use any oil, it stays around the max mark. Those that use some oil just don’t get topped all the way up once the cold sets in.
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
Frantz bypass kits use rolls of toilet paper inside a canister... The claim is never need to change oil again and engine will last longer with a continuous supply of ever clean oil...
If the additive package lasted forever and there was no such thing as fuel blow-by and thermal breakdown and shear force didn't exist...
...I'd look for a unicorn in the back yard and excavator key in my pocket, but so far that ain't happened.
:ROFLMAO:
7,685
I have a Frantz called "Triple Decker". It uses 3 Tp rolls. Made for over the road trucks and bigger engines. I used it to filter drained motor oil back when diesel was $5 a gallon. Then mixed that oil with diesel according to the temperature. Always used the front tank for the mixed concoction and the rear tank for diesel pumped from the station. Used it in an '86 f250 3/4 ton. Started on the rear tank and ran for a few miles then switched to the front for the rest of the day, until the last few miles when I switched back to the front.
