A New Oil Thread
Where do you like your oil on the dip stick to read?
  • below min.
  • right at min.
  • between min and max.
  • right at max.
  • slightly above max.
Results are only viewable after voting.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,129
1,111
E.
I have a Frantz called "Triple Decker". It uses 3 Tp rolls. Made for over the road trucks and bigger engines. I used it to filter drained motor oil back when diesel was $5 a gallon. Then mixed that oil with diesel according to the temperature. Always used the front tank for the mixed concoction and the rear tank for diesel pumped from the station. Used it in an '86 f250 3/4 ton. Started on the rear tank and ran for a few miles then switched to the front for the rest of the day, until the last few miles when I switched back to the front.
I have never owned one.
I dispose of used oil through a boiler i have. I drip used oil through a valve onto the hottest part of the burn chamber. Seems to burn very clean but sometimes a contaminate like sand or bark that was probably in the drain pan plugs up the very small valve I use.
This TP trick would solve my valve plugging problem as sometimes drain pans kicking around my shops get stuff like sand caught in them between uses.
WI_Hedgehog
Apr 24, 2024
1,128
1,645
Milwaukee, Wisconsin, U.S.A.
....This TP trick would solve my valve plugging problem as sometimes drain pans kicking around my shops get stuff like sand caught in them between uses.
If you replaced your drain bolts with ball valves you could drain into 1 gallon milk jugs and eliminate several problems at once, plus it's so much more convenient.
