chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,020
2,517
Near Lancaster, PA, USA
I don't ever remember seeing conditions like we have this morning. The "snow" is like really bad shave ice and is serving to hold a lot of water on the driveway. If this stuff freezes it's going to be treacherous. I made some passes to clear it off but it's like running a large fire hose, although it does work.
McMXi, that sloppy stuff reminds me of what we had a few times. First one is with the L3200 that a bud shot and the second very short video is the L4240 I tried to capture from the cab. Both were at the same parking lot at church and both were to get rid of the slush ahead of an approaching freeze.
10,383
Yes! Your videos capture the stuff that I'm dealing with. I can't believe how much water it holds. It's like a gel sitting about 1-1/2" thick and it turns to water as you push or blow it. Not a fan, and if it's on the ground tonight it'll be a thick sheet of ice.
Old_Paint
Dec 5, 2020
1,959
2,154
AL
That's the normal kind of snow and weather we get in Alabama when we get any snow. Wet, heavy snow, sometimes alternateing between sleet, frozen rain, snow, and you can see the defined layers in it. Then we get a slight warming trend to get it really slushy, followed by some kind of ridiculous single digit temperature which turns it all into a SOLID 2-3 inch sheet of ice that won't melt until the temperature gets back up around 60 or so. That normally shuts down most of the state for days.
  • Sad
Hugo Habicht
G1900
Jun 24, 2024
1,175
1,705
Ireland
Yuck ...
Let me rephrase: we love pictures of light, fluffy snow :ROFLMAO:
Bearcatrp
Mar 28, 2023
1,123
743
Minnesota
Do you have any pictures? We love pictures. :)
I love to see snow because there isn't any where I live. Maybe every 20 years or so.
The 3 point snow blower I bought at a hell of a good price worked awesome. Best 2 grand I have spent on equipment.
Trustable
l2501HST
Jul 5, 2022
285
236
Cleared 9 inches of snow today. Proceeded to then hit my mailbox and bend it! 🤦‍♂️ Thankfully it’s not a super high strength steel so I could bend it back by hand. It’s got some character now! I did put it in with 100lbs of concrete so that would have been a pain to remove if it did break with how frozen the ground is right now. As usual the l2501 did great with the old back blade my neighbor gave to me a few years ago.
chim
Jan 19, 2013
3,020
2,517
It's a real shame there's no video of the precip we received some time in the early 90's. It was several inches of what looked like #8 shot made of clear glass rather than the common little white balls of sleet. It wasn't the least bit wet but it behaved almost like water because the little spheres wouldn't stick to each other. The only snow removal equipment then was the Ford 1210 and a 5' rear blade. With the blade reversed and the tractor in reverse I backed into it to push it up onto the existing snowbanks. Some of it kind of leaked around the blade while being pushed and when I stopped it ran back down the existing snow like water.
JonM
Nov 29, 2024
180
370
wisconsin
snow blower vs 50lb salt block wife left in paddock.... was clearing a spot for the horse feeder. fortunately i got all the rest of the snow done first
and no a land pride inverted snow blower will not successfully ingest a salt block. 0 out of 10 do not recomend
center impeller popped welds off three of 4 blades and twisted them before sheer pin broke.
at least i got my snow pusher till its fixed. while im a big diy this is beyound the equipment and tools i have atm.
  • Sad
Reactions: 9 users
g_man
Feb 3, 2023
336
1,516
NE Vermont
GrumpyFarmer
4,684
Amazon! I'd have a better chance of getting on a Blue Origin rocket than persuading Amazon to change their shipping policies! 😂
How long would it take to run out of intelligent conversation with the Perfect 10 crew? I bet before everyone gets strapped in you will miss the HST wine of your MX.😉
might be interesting to study silicone under g force at launch as well as in orbit?
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,564
3,867
PEI Canada
View attachment 166746 View attachment 166747
Thats a lot of carnage. My worst thing to get in the blower was a fence post. Just broke the sheer bolt but took awhile to get the post out from behind the auger.
Sawburner
L2501, Gravely 526
Dec 18, 2022
96
296
53
NY
Not pictures of plowing but I made my snow plow into a snow pusher it made a world of difference. I mostly plow with the back blade and clean up with the snow pusher works great.
Reactions: 6 users
mdhughes
L3901DT
Dec 10, 2014
1,416
1,355
Ste Geneveive county, MO
Used the L3901DT and grapple to move logs to our splitting/storage area. It was a cold one yesterday with the wind and high humidity. At least the ground was frozen and I didn't have to deal with mud.
JonM
Nov 29, 2024
180
370
wisconsin
the cost of a new auger is 6700$ so the bent one is being sent to a machine shop for bending and reweld.
told the wife we are NOT using the blower in the paddock again as her salt block picking up skills are pretty much zero.
Hugo Habicht
G1900
Jun 24, 2024
1,175
1,705
Ireland
Found time to make the lever and install the linkage to the diverter valve for the three point hitch. The original Kubota solution is very elegant but the individual parts would have added up to about $1000. So I put in a normal hand valve and made a linkage to the original handle position; a bit tricky and not very elegant, but space was tight and it works fine. I want to keep the other side free for the rear PTO clutch lever.
All that is left is a bracket for the valve to the frame and relocating the temperature alarm horn and a contactor.
Reactions: 13 users
dlsmith
BX2230, LA211
Nov 15, 2018
1,320
961
Goshen, IN
Fired up the BX this afternoon, had to haul eight bags of water softener salt to the basement door. I wasn't sure the F150 would go through the snow in the yard to do it, but the BX in 4WD plowed right through, no problem.
Reactions: 8 users
Bearcatrp
Mar 28, 2023
1,123
743
Minnesota
Another BX success story. Oversized garden tractor my arse!
Reactions: 9 users
