Round amber haz light disassembly?
Sodark
2018 B2650 HST ROPS, BH77 Backhoe
May 15, 2018
171
11
Pacific Northwest US
Sorry, I'm sure this has been addressed but I can't find mention of it. I'm replacing lamps with LED bulbs on a new B2650. The others were easy but I'm stuck with these rear amber, round lights. How do they come apart? I'm hesitant to pry, they seem apt to crack, and I don't see any screws or twist-locking function. I expect to feel stupid after it's explained but I'd rather that than feel stupid after breaking one without just asking. Appreciate any help!
jryser
427
Plainfield
On my L3560 they come apart along the edge - I found that out when I was cutting around trees and lost half. I was able to retrace my track, find the front, and snap em back together!!
11,245
Under the bottom edge is a weep hole opening use a pick and pull straight out to pop the lens off, works on either side. ;)
Sodark
May 15, 2018
171
11
Ah, yet again, brute force (with a touch of finesse) is the solution to the problem. Thanks guys!
(For future reference for others, attaching photo of the separated unit, as I had hoped to find).
And now for the tail/brake light reversed polarity debacle... This shall require rum.
johnjk
Apr 13, 2017
1,816
2,236
West Mansfield, OH
Many of my issues wrenching are solved by a timely beverage.....
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,357
876
under a rock
Just go bashing through the woods with the tractor..... They come off real easy... :ROFLMAO:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
It's been a long time since I looked at LED's for replacing standard bulbs. Back then it mattered how the LED would be mounted. For example, if the lamp would be mounted as in your lollipop it would be made to shine more through the sides of the bulb. If it would be in a tail light where the base pointed forward, it would shine more light out of the end.
TimP
B3000
Jan 16, 2012
68
Baltimore, MD. USA
TimP
B3000
Jan 16, 2012
68
Baltimore, MD. USA
I have a B3000 and need to replace the bulb in this same light.
But I don't see any wep holes at all.
So, did you just sort of pry it off with your hands/fingers?
Or, can I use a screwdriver along the edge to pop it off?
Thanks.
Mark_BX25D
Bx25D
Jul 19, 2020
2,112
1,616
I have an old Craftsman 1/2" flat blade short screwdriver with a full size handle. I'm sure I've used it more often to pry things apart than to tighten or loosen a screw. It's been VERY handy over the years.
5,552
I always get a laugh when I see that “Caution do not use as a pry bar” warning sticker:ROFLMAO::ROFLMAO:
I mean come on……..Who the hell doesn't use them as pry bars…..
I would probably have a hard time finding 5 “flat blade” screws in my entire shop, but I must have 100 “flat blade” screwdrivers laying around……..
Probably some sort of “legal protection” thing………….
Trustable
l2501HST
Jul 5, 2022
397
411
Nothings worse than having to use a flat bar screwdriver to actually tighten a screw, much easier to just get under it with the screwdriver and pop it out. 😆
I need to figure out where to get electric outlet plate screws that are torx so I can forever be done with slotted/flat.
Trustable
l2501HST
Jul 5, 2022
397
411
Amen!
Let it die, along with the Philips!
I hope I get to see both those get phased out in my lifetime, but seeing as flathead/slotted screws have been around since before North America was even known to exist by most of the world, I don’t have high hopes.
