Your Battery Maintainer/Charger choice?
Botamon
Mar 26, 2018
492
920
Winnemucca, Nevada
I bet I have at least a dozen of these BatteryMinder units. Motorcycle, quad, tractors, everything I'm not driving daily is hooked up. In my experience these things have doubled the average life of my batteries.
But I don't use the alligator clips the units come with. I install leads on each battery so I can plug in without having to physically access the battery. Much handier - makes it that much more likely I'll plug in when I park the vehicle.
I also have some larger BatteryMinder units for when more charging power is needed. My Miller Bobcat welder, which sits in a shed with no power, has a solar-powered BatteryMinder connected.
Old Machinist
May 27, 2024
723
841
NE FL
This reminds me. I have two machines I need to put SAE pigtails back on for the winter. I can't remember why they got removed but I have solar chargers sitting idle while two of my mowers are disconnected.
3,581
For my Optimas:
(Lil Foot, Rhino)
For lead acid:
(B7100, Mini Ex)
For various motorcycles:
LoadTrail dump trailer has a built-in smart charger/maintainer, but it's 150mi from here, so I can't check the brand/model.
(And no. I don't remember it; I have trouble remembering what I had for breakfast;))
nbryan
Jan 3, 2019
1,436
950
Hadashville, Manitoba, Canada
No battery tender/charger yet here on my 2017 B2650HSD. Original battery, still starts her up cold no block heater at -20C, with 10-15 seconds glow.
Just saying...
11,757
Just saying...
I thought about that today. I've never used a battery tender or charger on any of my Kubota tractors. The BX lived in an unheated barn all year round for 5 years, and when I sold it to the local Kubota dealer manager it went with the original battery. My current MX is four years old and the M is 3-1/2 years old and they live outside all year round at present and both have the batteries that they came with. I've never had a problem starting any of my Kubotas and the temps can be down in the -20Fs in the winter.
Once I get the sheds built I might use tenders on the batteries, but the jacketing material that I ordered from Amazon showed up today so I'll be wrapping four batteries this weekend.
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
I've use HF tender/charger for years now no issues winter or summer. Doesn't say if there is a working temp range but it does have a "Winter Mode" but does not specify exactly what that is. Does mention to never charge a frozen battery.
Temperature compensation - it incrementally increases the charging voltage the colder it is, since cold batteries don't like to take a charge.
I looked around a couple of years ago comparing the minimum temp rating of a few popular tenders/chargers. Not surprisingly, some don't eve publish those specs. I think the best I found was -4ºF.
GrumpyFarmer
5,247
I’ve been using the Battery Tender (brand) for a long time…my original single bank is still going, but I use 2 other 4 banks. (They are all more than 20yrs old).
Then I picked up some additional length of the harness so I can connect multiple machines with some reach/stretch across floor…makes for a real trip hazard if not careful but I also pipe the harness across ceiling and then have hang connector down where I park.
IMO if have multiple items in close proximity, the multi bank is the way to go, less the trip hazard🙄.
BAP
Dec 31, 2012
3,202
1,317
Has anyone ever figured out the cost benefit of running battery tenders? Comparing the cost of buying a tender, paying for electricity to run it versus having to buy a new battery on a more frequent basis.
6,323
some rough math....based on the unit in post #21 ( 12v/1A ) and tender being used full power.
It produces about 12 watts of power, so maybe 20 watts out of the wall...accounts for line losses, efficiency, etc.
My electricity costs me 20c /KwH. Change this for your rate....
1Kw/20 watts = 50 hours, round down to 48hrs = 2 days.
1Kwh costs me 20 c, so that's 10c per day, so $36.50 per year
Reality is the tender won't be fully 'on' every hour of every day , rates vary with temperature and battery condition, etc. so could safely cut the cost in half, which becomes $18.25 per year.
If you get 3 years extra life out by using it , it's cost you $55 +-.
Say new battery costs $210 ( none are cheap' anymore.... and you get 7 years out of a battery
3 years of battery is 3/7X$210 is $90.
So... it cost you $55 to save $90.
As I said rough math and numbers will vary . Mr. Sun still isn't up ,so feel free to tweak the numbers.
Daferris
LX2610
Nov 23, 2021
496
423
Mid-Michigan
Noco tender. But wired up so it's easy to connect. Only issue is the only bulkhead connector I could find was an SAE style so I had to get a little adapter cable to change to the Noco connector.
lynnmor
B2601-1
May 3, 2021
1,822
1,624
Red Lion
Edit - So if I just plug the charger up to just the battery and not start the tractor up, it will reach "Full" MUCH sooner but if I re-set the charger to charge with the engine running (with the charger on) it will not fully charge the battery until 10 or so minutes.... If that's over charging, it works and I'm fine with it...
A battery in need of a charge will not fully charge in 10 minutes, it takes much longer to do it right. A typical group 51 battery used in smaller Kubotas will take nearly 2 hours to fully charge if it was down just 10%.
hedgerow
488
479
Malcolm NE
Never have owned a battery maintainer. Any of my big equipment that sets all winter with no starts have battery disconnects on them. Most are stored in sheds with no power to them any way. Had one semi that seemed to be starting a little slow during harvest this fall and got into the shop last week for a service and checked the batteries and there were ten years old so I put a new set in. I never had a problem with a battery setting unless there is a draw. That is why I use disconnects. The newer equipment has a lot of electronics on them. My battery charger is forty to fifty years old. I put it on the fuel trailer once in a while but I just normally hook the cord up to what ever I am fueling up.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
Bad thing about lead batteries is they don't really like a deep level of discharge. Prefer to have a fully charged battery when starting.
For what it is worth. On the old NH just purchased the 3rd Optima Yellow top and then traded it in this past April for the BX. 3rd battery in almost 25 years. Last decade the NH sat sometime for more than month. Same thing will be happening with the BX. Limited need. Just trail and driveway maintenance. Harvesting firewood in the Autumn. ~ 8months old and less than 60hrs. Majority of the hours were grading and distributing the 80 tons of gravel delivered this past Spring. Guessing will be back to my ~50hr/year use. Unless winter snowfalls return to the frequency and amount of the past century. Which I doubt. The past few days, the Clippers instead of dropping inches have deposited a centimeter or so of light dry powder.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
322
147
Jefferson, Ohio
On the old NH used yellow top Optima since purchasing new in '01 . Used their "smart" charger after the first Optima died. Only issue I had with the charger was the low end of the working temperature range IIRC was -10C/14F. Not practical living in the North.
For the BX purchased the Noco Genius5(G5) and a set of 10mm eye connectors not realizing the alligator clips convert over to 10mm eye connectors. Hard wired the battery and just use the quick connect to save the need to remove the screen every time connecting. Has worked fine. Lowest operating temp is -20C/-4F. If temp drops below it auto shuts down until temp increases above the -4F. So far, no issues.
The Noco battery and load tester owned is +decade old and still works fine. Low operating temp and auto on/off function plus the luck I have had with the load tester was my reason for going with the G5.
Black F Day Sale at AMZ on the G5. Purchased another one for the truck. It sits too much.
OT: Why is it when you jump a dead battery you connect the (+) from donor and dead battery (+), but connect the (-) to grounded metal on the dead vehicle and not the (-) battery terminal. Yet on a battery tender you can connect to both battery terminals? Noco recommends when using the alligator clips to connect like you do when jump starting a dead battery for a battery in the vehicle. Yet you have the option of using the eye connectors which connect directly to the proper battery terminal? I just connected the alligator clip to (-) terminal to the GM recommended grounding flange. Bit of a reach v. just directly to the (-) battery terminal.
Jay Leno uses CTEK.
