Your Battery Maintainer/Charger choice?
Trustable
l2501HST
Jul 5, 2022
397
411
I need to still get one for the equipment but I can speak to the battery tender brand. My father has had a couple for a while now and they work very well
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
472
268
Randolph county N.C.
I have Battery Tender Jr, CTEK and NOCO 2a,5a,10a. All work fine. NOCO has several sales per year on Amazon and the price is much less expensive on sale than Battery Tender and CTEK.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
As I said rough math and numbers will vary . Mr. Sun still isn't up ,so feel free to tweak the numbers.
When you connect the battery maintainer after running the tractor the battery is full. So it only has to provide the battery self discharge which is typically 1% per day for a new battery and possibly a bit higher when the battery is older. For a 12V 60Ah battery we are talking 7.2Wh/day.
So I think your electricity supply calculation is too pessimistic. What the maintainers really draw from the grid pretty much depends only on how good the power supply designers were and how low the no-load standby power is.
5,522
I don’t recall the name brand of all of mine.
But it don’t really matter anyways, cause I never remember to plug them in. :sneaky:
BX23-S,57 A-C D-14,
6,322
I used the worst case scenario based upon the MFRS claim they draw, without knowing operating temperature and windage, their SMPS efficiency,condition of battery, parasitic loads and of course whether you left the key on or not.There's dozens of factors to account for when doing a 'cost analysis'. having designed/built battery backed power supplies for remote energy control systems, I posted a 'worst case' as an example.
mikester
M59 TLB
Oct 21, 2017
4,143
2,833
www.divergentstuff.ca
Has anyone ever figured out the cost benefit of running battery tenders? Comparing the cost of buying a tender, paying for electricity to run it versus having to buy a new battery on a more frequent basis.
$120 for my motorcycle battery and 2 hours to remove the plastic tupperware, replace the battery, and then to replace the tupperware. $48 for the battery tender that doubles my battery life.
Payback is pretty quick IMHO, just in terms of frustration saved.
Vlach7
L47 305DT JD500C
Dec 16, 2021
452
329
Frazier Park Ca
Forgot about the off gassing of lead acid batteries. I guess a spark would have been a bad reminder.
OT: Friend has a huge solar array on his now hobby farm. Actually more of a very large veggie and fruit garden with a few acres of grass that he just mows for "fun" and compost. Net positive solar electricity generation. He is a retired electrical engineer. Loves to "tinker". Decade or longer ago he decided to install a battery storage system. Pretty much limited to lead acid batteries. Dedicated room in basement of his house. Had to add a ventilation system. Otherwise. BOOM! Gave up on the battery idea after one or more life cycles and when electric utility company had to pay for excess into the grid. So he purchased the hardware needed to reconnected to the grid. Less hassle and overall would have been more cost effective. But recently the utility companies are allowed to eventually pay less than 100% of wholesale electrical acquisition cost. Time for vanadium redox flow battery bank just to stick it to the utility company. I don't think net cost has ever been a high priority
Jay Leno uses CTEK.
Deleted
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,524
554
I have a bunch of different brands and my complaint with all of them....when used in an unheated barn, the wires are so fine and unpliable in the cold, the insulation cracks on the wires and they short out.
I usually have to replace mine every year or two.
BX23-S,57 A-C D-14,
6,322
Replace the wires with 'lamp cord' or 'test lead' wire ! I used to make 100s of test leads and yes Virginia, there IS a special wire for them. Very flexible and nice 'rubber' insulation. I finally used up the 2 500' spools a few months ago ( Belden mfr )
11,757
Since this thread is about batteries and chargers, I'll share a little F-250 project that I wrapped up (pun intended) a couple of days ago.
I bought new batteries from Costco recently, specifically Interstate 65 AGM batteries that use gel mat technology. I also bought a battery wrap kit on Amazon which comes with enough insulated sheet to wrap a 65 sized battery as well as a piece to go under the battery. I cut and fit some 3/16" neoprene sheet for the top of the batteries, and then got everything wrapped up with some quality tape.
The intent here is to protect the batteries from extreme cold over the winter months. I don't use a battery tender on this truck since I drive it regularly.
BruceMc
BX25D LX2620
Sep 27, 2014
54
122
Fairbanks, AK
I'm just happy that in 20 years, I'm still using the original battery from 2005!!!! :love:🥰
Since I bought the LX this fall the BX25 has been sitting unused outside for a couple of months now. We've had a very cold December, even by Fairbanks standards. Day after day of -40ºF. It warmed up enough yesterday that I pulled the battery and brought it inside. Surprised to find it was still sitting at 12.5V and, after putting it on the charger, it's sitting at a stable 12.8V today. 100% charge. This is the original factory battery from 2014. Impressive. It's never had any sort of trickle charger/maintainer on it.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
435
303
Bayview Township
Have you load tested it or used it to start your tractor. First Optima noted 12.? volts under no load. Put it on the load tester. Not good. Depth of discharge with each start would be significant. It's days were numbered. Bit of sticker shock when purchasing #2 Optima. No longer made in the USA. Origin was Mexico. Purchased the Optima branded charger/maintainer with the replacement Optima. Only two batteries used on the NH since '01 until #2 needed replacing the Autumn of '24. Of course then I go trade the NH in for a BX next April. Tractors sit around unused for long stretches sometimes.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
Bit bummed. The Noco Genius 5 purchased last late November for the truck stopped working. Stuck in standby mode. Cannot even switch it into force mode. Checked probably every possible cause. Fuse, connecting cable, contact surface condition, connection to battery, battery voltage.... Finally tried the spare set of Noco branded alligator connectors. No go. Last check was I switched it out with the Genius 5 that is attached to the BX's battery. No go. Still stuck in standby mode and mode button is unresponsive even after holding it down for over 30 seconds. Guessing it is a voltage sensor or some other electronic component that has gone bad.
Submitted a warranty request to Noco. Relatively fast initial response (one working day). They basically outline trying everything I did and noted on the warranty request. Since then. Nothing for Noco. The maybe good is I also submitted to Amazon a return request for a defective product. They accepted. But pending their determination for full, partial, or no credit/refund. Window for return closes in a few day. Waiting to here from Noco until close to that date. Worst case if returned to Amazon is it will be one less piece of garbage at our regional landfill.
Now a days with who knows what type of QC no matter where a product is manufactured products of marginal quality slip through. Anyone ever submit a warranty claim at Noco? Or is their 3 year warranty pretty much BS?
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
I have a neco charger and pigtail connectors on my generators and on my ranger. On my kubota I put a neco on board mounted maintainer. I bought my tractor may of 2013. Still has the factory battery. Its amazing how long the factory battery lasts whither in a car truck or other. Its impossible to find a replacement thats half as good. In my ranger the factory battery lasted four years. I replaced it with a Odyssey, at the time $220. Was ridiculous. Ten yrs later still working. When my kubota battery finally gives up im probably going to look at a odyssey for it.
Blue2Orange
Apr 3, 2025
435
303
Bayview Township
Received a RMA for Warranty Service today:). Hopefully Noco will replace or repair. If not will probably just replace the Genius5 with the Genius 1 for a truck maintainer. 1AH is fine for maintenance.
Was going to use the eye connectors on the truck battery like the BX battery is set up. The Chevy Silverado battery has a cover over most of the battery. Guessing it is what keeps it in place. The "remote" positive terminal is hexagon shaped and too large for even the 10mm eye option. Alligator clips have been just as fast to connect and disconnect. So I haven't bother removing the cover and attaching the eye connectors to the battery.
