My L245DT has aftermarket power steering..does not have a front end loader. The power steering cylinder is connected to the control valve below the left side of the seat via an aluminum block. How do I do this? Thanks for any help.
Do you waant to do it right or half assed? We need to see what that cylinder looks likeMy L245DT has aftermarket power steering..does not have a front end loader. The power steering cylinder is connected to the control valve below the left side of the seat via an aluminum block. How do I do this? Thanks for any help. View attachment 166370
Thats ehat I was expecting - a power assist cylinder and valve.The 2nd pic is the cylinder for the power steering
You are welcome.Thanks so much Dan.
You discinnect the cylinder completely and connect the OUT port on the block to IN on the dividerHave no Idea..it was on the tractor when bought.
By the way..Do I need to connect the priority valve directly to the pump or can I tap in left below the seat? I only see one outlet at the pump and it's a steel line back to operate the 3 point?
Thanks
Just to provide you some information on how the hydraulic flow is on the tractor:Have no Idea..it was on the tractor when bought.
Thanks
