B7500 Tractor aprox.20 yr old
#40Fan
635
467
Is back and forth in and out as in pushing the tire towards the tractor and pulling it away? Or are saying that you can roll the tire forward and backwards as in driving the tractor forward/backwards?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
Does it make noises while driving? You should be able to see / feel the movement. Mine had loose bolts where the hub fastened to the axle. They were tapered bolts that made the hub tight on the hex axle.
3,397
I don’t know but it sounds like you mean that when you pull and push on the tire that the tire/wheel moves in and out. It sounds like this happens on both sides.
I think it would be helpful to get good answers if you are more specific in your description. For example if it is in and out movement, how much movement is there? Is the axle moving along with the tire/wheel, or is the axel stationary and the wheel moving with respect to the axle? How much is the movement? 1/16“ or 1/2” ?
Do both sides of the tire move in the same direction, or does the tire/wheel twist rather than going in and out?
Any exact details that you give will get you better answers…
scottc
1456 state rt 8 cold brook ny
Thank you for your help! Axle does not move. I can grab the tire when jacked up and rock the tire back and forth about 1/2 " Doesn't move in and out on the axle. the hub pin stops it from doing that.
11,114
When you put the new hub on it, did you tighten it to the axle?
