noisy brakes
hope to float
L3450
Feb 18, 2018
490
61
Ireland
Hi Guys,
Just what it says. The brakes are making a horrible noise when applied. It happened suddenly. Would they wear out like that? Is it a big job to replace them? I have never worked on wet brakes before. Found a YouTube video belonging to someone else
Kubota L3450 DT GST
Thanks
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
691
300
Herald Calif.
Have you changed the hydraulic oil recently? If so did you use Kubota super UDT? I have not seen this problem in the L Series but the m series it has been a common problem when not using Kubota fluids.
10,334
How would I check for this? Also, I borrowed a tipper trailer a while back and could that have ruined the oil?
Drain some out and check for water.
The bottom of the Mid PTO case is a great location for this.
hope to float
L3450
Feb 18, 2018
490
61
Ireland
No sign of water, but I think I may be the first person to open the nut on the mid pto. I left this to settle for a few days but there was no change. I think I will change the oil and filter.
GrumpyFarmer
4,865
Good call on new oil…that Looks like a proper oat meal stout with the head scraped off.
William1
BX25D
Jul 28, 2015
1,350
548
Richmond, Virginia
Yuck! That oil looks terrible for a trans. Normally will look like new oil as there is little to contaminate it (unless you rode the brakes for weeks) - You brakes do have proper travel, the pedal fully returns easily and the brakes feel applied at the 'proper' point, right?
