mdhughes
L3901DT
Dec 10, 2014
1,414
1,337
Ste Geneveive county, MO
I used the L3901DT and grapple to move logs to my bucketing and splitting area. This is the second day this week that I have worked on firewood.
I also moved some dirt to try to level out the "floor" of our lean-to where the tractor, log splitter and walk-behind tiller live.
Couple days ago I used the L3901DT and grapple to move leaves. Blow them in a big pile and pick them up with the grapple and drop them in the woods. This is one thing I don't like about living in the woods.
Reactions: 8 users
Old_Paint
Dec 5, 2020
1,959
2,150
AL
My L4060 has no back up light circuit.
I installed a proximity sensor and relay to operate back up lights.
Wonder if I could do something similar using the treadle switch on my LX2610? It senses the treadle is pushed in either direction, but dunno if it's two switches or one. It's all mine now (last payment two days ago) so I reckon I can screw it up as bad as I want to. Nah, I'm pretty careful to keep my expensive toys as close as possible to factory and limit mods to things that don't require cutting into wiring or drilling holes in places I really don't want holes.
Old_Paint
Dec 5, 2020
1,959
2,150
AL
Yup, leafing ain't fun. I use my little Husqvarna YTH22V46 to mulch and bag 'em, dump the bags on a tarp in a little trailer I built 20 years ago, and then haul that to the back with the LX. Makes for a few less trips and I don't tear up what little lawn I have with the LX. The tarp lets me empty it quick as long as the leaves aren't damp. Then they're too heavy to pull off with the tarp and I have to raise the tongue as high as possible to get gravity to help me out a little. I had 17 trees removed last year, so the leaf cleanup has been a bit easier this year. Still get some red oak and elm from a couple trees I left, but nothing like the massive loads of water oak (never mind the millions of marble sized acorns). Up until last year, I was hauling at least 8 loads of leaves 5 or 6 times a year to some old erosion ditches in the back part of my lot. Been dumping leaves in that hole for 20 years, and it still ain't nowhere near full.
Might go out today and stockpile some topsoil out of a rather large compost heap I started 5 years ago when I got the LX. I pushed tons of leaves and underbrush into a big pile when I cleared out the back part of my lot and have let it rot down. I need to see if I can find some kind of mulcher that can chew up the rest so I can use it in the mosh pits in the chicken yards. I call them mosh pits because that's where the girls party down and scratch around for worms and bugs. They love it when I put fresh mulch in the pits.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,563
3,865
PEI Canada
It was a miserable, wet day. Took out the rear finish mower out to my parents barn for the winter and moved a few skids of salt. Got home and put the blower on installed the drift cutters.
Reactions: 6 users
Old_Paint
Dec 5, 2020
1,959
2,150
AL
Put the flail mower on and crossed the boundary between me and the neighbor. I need some pine brush to feed my chipper for stuff to go in the mosh pits in my coops, and he just so happens to have at least 20 short leaf pines down over the past few years. Might take a few logs too because they’re nice straight trees. I cut a work area around one top close to the line and then got the saw out to cut it into manageable pieces to feed to the WC-68. I still haven’t cut the drive shaft that came with the flail, but the shaft for the WC-68 works well. It’s just right without the quick hitch, if not a wee bit short. I get full range on the lift without pushing the PTO shaft through the transmission, so close enough. The flail will never be QH compatible, so no point in worrying about the shaft without the QH. No photos, unfortunately. Will get some tomorrow. Pretty easy to see what I did. The grass and brush was waist deep when I started. It’s shoe top deep now. This was just my second experience with the flail with hammers on it. I’m sold. I have a set of Y blades that came with it, but they may never get used.
Gonna build up a stockpile of pine chips for the girls’ to scratch around in after I clean out the pits. The short leaf pine has a lot of resin, so hopefully it’ll last longer and smell better than the hardwood stuff I put in when I built the coop. 3 medium sized brush piles from one top so far. He’s given me carte blanche to collect what I need because he gets free cleanup while I’m getting free coop bedding. If ya want good neighbors, gotta be a good neighbor.
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
402
625
NH
Moved and built a wind barrier using firewood cages to protect the hives from the winter storms on the hill. Challenging because of the mud but took my time and maneuvered slowly. Will try to add more in morning. Nice to have the heated cab. Wish I had one on the mini-ex.
Reactions: 10 users
johnjk
Apr 13, 2017
1,727
1,974
West Mansfield, OH
Finished up brush cutting for the season. Time to take off the cutter and dig out the back blade. Great morning to listen to some music and burn a cigar
S-G-R
Jun 17, 2020
1,563
3,865
PEI Canada
Used the 5460 to move some 6x6 beams and the RTV to shunt trailers. Was looking at tracks for the rtv. Anyone on here running them?
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, Sovema 3PL rotary hoe
Jul 8, 2025
324
428
Cleared out one side of the shed so I could get the tractor through as this is the only access for the tractor to the back of the shed. Started moving a stack of about 600 old bricks that have been stacked at the back of the shed for about 15 years.
One layer of 50 bricks on a pallet weighs about 190 kg. We'll leave them stacked on their pallets until we decide where we want to use them. Every home should have a forklift.
It was also a good test for my homemade forks - they didn't even break 😀
Didn't need to but I lifted the 190 kg pallet to full height of 6' just to see if it could do it.
I also added 30 bricks to the ballast box making the total ballast box weight about 180 kg. Even with this weight the steering is still really heavy with 190 kg on the forks....still thinking I need hydraulic steering.
I want to get all the bricks moved before I start modifying the cylinders on the loader.
Reactions: 9 users
Shawn T. W
Dec 9, 2024
503
926
SW Missouri Ozarks
Try adding more bricks to the ballast box ... The steering will lighten up! :cool:
Shawn T. W
Dec 9, 2024
503
926
SW Missouri Ozarks
While I've never seen it written anywhere "officially" that I can remember ... I've always been of the belief and understanding that you should have as much weight hanging off the back, as you're trying to pick up on the front ... And usually the rear 3 point is stronger hydraulically than the loader ...
That seems low to me ... Tractor Data says it's much higher than that ... Taken from here https://www.tractordata.com/farm-tractors/001/2/7/1272-kubota-b7200.html
GrumpyFarmer
4,669
Today is a beautiful day although a bit windy here.
Before weather gets bad I did final clean up in yard and brought the waste to the compost station. The we cleaned out the chicken run, and then I made the last batch of lasagna for the year.
Looks like rain this week so will toss it a few times this week and next and call it good for the season if it cooks up nice.
Reactions: 10 users
Paul Allwood
Jul 8, 2025
324
428
Thanks for this info. Interesting that it's quite different to what's in the Kubota manual.
Ridger
L3940 HST
Nov 26, 2014
156
14
North LA
I flushed and changed the coolant in my L3940. The drain plug is plastic and I was afraid it would snap off. I noticed during the flushes that it leaked a little around the drain plug. When I went back with the drain plug for the final time, I put several wraps of teflon tape and some sealant on it. That seemed to take care of the leak. C'mon Kubota....a plastic drain plug?
Shawn T. W
Dec 9, 2024
503
926
SW Missouri Ozarks
Finished the final mowing of the season, I stepped over into my neighbor's field to take a wider view picture, mines a bit greener! 😁
Reactions: 8 users
Gaspasser
Dec 16, 2023
402
625
NH
Unloaded mafia blocks from truck with tractor and mini as neither alone could lift them from that height. Son in tractor and me on mini. Delicate operation to coordinate ( especially for father and son, lol). Once on the ground, the mini was able to lift and move them. Pushed more slash piles together and got my burn permit. Not allowed to start until 5pm so stumbled around in dark lighting piles. Wife and pup joined me and we warmed up cold, wet hands. Madeup for freezing my azz off all day,
