Seems like a lot of work requiring attention to details...New cylinder head, ejector bodies, and fuel filter.
I am waiting to see where he got the new ejector bodies from.
Sorry for the miss spellWell your problem is quite obvious...
You must be working on a Chinese knock off unit, because we only work with Kubota's around here!
Why did you do a Cylinder head replacement?
Does it overheat?
Did you do a compression test before or after the cylinder head replacement?
Where did you get the injectors from?
Does it smoke when it does this?
And if it does what color?
Does it bog down or just low RPM?
Have you checked the air filter and housing?
I got them from a Kubota dealer $$$$$
I connected the line from the tank to the electric inline pump.Have you checked for good fuel flow from fuel tank to inj pump???????
Is fuel tank venting? I'll advise as a test to operate engine with shop towel covering fuel tank neck.
I'm thinking it must be the hydraulics as before the water intrusion it was okYikes...
So not sure if it's the engine bogging down and not powering the hydraulic pumps
Or if it's the hydraulic pumps locking up dragging the engine down.
I'mYikes...
My monies (folding cash) is on the pumps.
thinking it must be the hydraulics as before the water intrusion it was okMy monies (folding cash) is on the pumps.
Yikes...
Yikes...
The engine is bogging down when warmed up and I try to operate the hydraulics.Yikes...
