Used Snowblower Transformation
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
104
88
duluth mn
Don, you said, "I do not think rotating the auger 180 will work as the holes for the shear pins will not work!
I think you have to swop right auger for left auger end for end!"
You just unbolt one shear bolt, spin the auger on the shaft, then reinsert the shear bolt.
You are correct MY BIG MISSTAKE!!
I was reading swop 180 as moving one side to the other! And not rotating 180.
Sorry for the missinforation!!
Don
bird dogger
Vendor Member
Feb 24, 2019
1,766
1,749
North Dakota
Don
I was misreading or misinterpreting it also!! Makes perfect sense now. :LOL:
In my defense, I've never had to worry about that. My shear pins connect my chain driven gears to my augers at their ends. It doesn't matter how they get reconnected if the shear off.
A new paint job converting it to Kubota Orange would be a nice improvement after all these years, though.
ShaPow!
9
North Idaho
Ah yes! I've seen the pic of your blower/others similar and always liked them. Look like snow-eating machines. 😁 (I kind of like the yellow ;) )
11,452
I have a Land Pride SB1574 with a slightly different arrangement. There's a shear pin between the output driveshaft and gear that drives the auger via a chain, and another on the PTO driveshaft coupler. Kind of idiot proof and I've yet to have to replace them.
Tiberius
B2601HSD, BX2822A, BB1254, QH05, G5200H, G2546A
Oct 13, 2025
19
27
If the top of the "auger shaft" rotates away from the "blower impeller", then the augers are in the correct positon. They would both feed to the center and help lift the snow into the blower impeller.
I ran the augers yesterday and they appear to move in the correct direction and anything that would enter the chute would be moved to the center for the impeller.
11,452
Just for clarification ... you haven't actually moved any snow yet right? šŸ˜‚
