Camp build
5,582
Looking good! And like I said before, you will never be done with it,,, lol
8upbowhunter
L4701 FEL, Cutter, Discs and Land Plane
Dec 15, 2016
407
78
S/E Louisiana
It's a slow process Magicman when you are a 1 man crew for the most part.
Skeets you are correct but it doesn't matter, it gives me something to do and not get bored.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I understand, that plus it being remote from your home.
It took me 2 1/2 years to do mine and it was only 46 miles away.
8upbowhunter
Dec 15, 2016
407
78
S/E Louisiana
It will take a bit longer for me mostly due to the covid lumber price hikes. I pretty much didn't do anything on it for 10 months at one point. Momma is on my butt to get it finished now lol.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
I have a big framing lumber sawmilling job to do this month in Meadville.
A total of 40 Pine logs like these and all in the 22" - 26" top end category. This will save the customer a bundle of $$$.
8upbowhunter
Dec 15, 2016
407
78
S/E Louisiana
That’s not funny Skeets lol
Yea that will save a ton of money. If I had somewhere out of the weather to dry them I could have done the same. I just cut them down and burn them in the campfire. Probably have 40 or so to eventually get out of my food plots. I cut and split 4-5 a year for campfire wood.
Levant0s
Kubota BX2380
Apr 7, 2025
I had a similar setup going and found that storing the RV between trips was trickier than expected with all the snow and rain we get. What helped a ton was finding the best class c rv cover for all seasons to keep everything dry and clean without constant maintenance. It made a big difference in how much time I spent cleaning things up after the weather hit.
8upbowhunter
Dec 15, 2016
407
78
S/E Louisiana
The camp is an ongoing project lol. Being a 1 man construction crew for the most part and living a little over 2 hrs from it takes time to make progress. All electrical and insulation is done and plumbing is 95% complete. Currently installing knotty pine on the walls in the bath and kitchen, goal is to get enough done to install cabinets and have a functional bathroom.
Levant0s I don't have a BX, I have a L4701. It has performed great for every task so far around the property.
8upbowhunter
Dec 15, 2016
407
78
S/E Louisiana
Camp update….Slowly making progress as I can. Bathroom is mostly finished except for some trim and that water should be on soon. Installed the kitchen cabinets recently, countertop came in so when I get time I will cut out the sink opening, mount the countertop and install the sink. Have been putting the knotty pine on the walls also. IMG_1252.jpeg IMG_1246.jpeg IMG_1249.jpeg IMG_1248.jpeg
Reactions: 7 users
Sawdust&Shavings
Apr 25, 2023
217
256
Stafford, VA
Camp update….Slowly making progress as I can. Bathroom is mostly finished except for some trim and that water should be on soon. Installed the kitchen cabinets recently, countertop came in so when I get time I will cut out the sink opening, mount the countertop and install the sink. Have been putting the knotty pine on the walls also. View attachment 165169 View attachment 165170 View attachment 165171 View attachment 165172
Nucely done and it came with a mouser!
