Old_Paint
Dec 5, 2020
1,988
2,212
AL
Interesting discussion here on Stihl 2 cycle oil. I've been using it for decades and never given it a thought except that it must be high quality because it is Stihl ?? Never had any problem either. I have 3 saws, a forestry brush cutter, and a weed whacker (all Husqvarna) that all use the same 50:1 mix. Most of the time I run the weed whacker at low RPM working around trees and fence posts or along the foundation to save the tree or the cutting line. I will put my saws down and let them sit idle while I move brush or measure out a tree or just think. Any thing with a tunable carb I keep on the rich side (I only have 1 auto-tune saw), not rich enough to smoke or turn the plug black but I don't want lean and hot. I do mix my fuel accurately at 50:1 and use ONLY non-ethanol gas which is readily available here at a premium price. That's just what I do - so am I just lucky ??
gg
Yeah, I don't think they're intended to be mufflers so much as spark arresters. Thus the regulations in most State/National Forests. If a tiny piece of sawdust makes it through the carb and into the combustion chamber, it's coming out as burning ash, and probably resulting in a fire if the conditions are dry. This is especially true with chainsaws since they rarely have anything more than a fine screen for an air filter. In California, I'm sure they've decided any 2-cycle engine with no spark arrester causes cancer somehow, whether it runs or not. IIRC, they recently banned ALL engines under 25HP?
I wonder if sometimes folks are letting their air filters get dirty which would make them run richer too. As soon as it starts sooting up, it can only get worse unless there's some sustained high-speed operation to get the screen hot and burn off the crud, preferably before it gets bad enough to restrict the exhaust. But it probably isn't terribly noticeable until it's too late if it isn't being run hard.
The engine on my Husqvarna B-185 blower is pretty quiet. It's relatively new (though I don't remember when I bought it) so may have the spark arrester in it. Might be time to take off the muffler and see if it's getting stopped up. Now that I know about this problem, it'll probably become my nemesis. Sometimes, ignorance is bliss. Never even thought about the addition of spark arresters to 2 cycle engines. Have seen them on some 4 cycle stuff to prevent big flames from the muffler when it backfires.
I remember the ancient Poulan that we had for firewood when I was a kid. It had NO muffler, and must have weighed at least 80 pounds. I could barely lift it into the Jeep. You could actually see the piston through the exhaust port and see the still burning exhaust come out of it above the bar at full throttle. That thing was LOUD. We mixed very rich for that thing and it would slobber half-burnt oil all down the front of the crankcase. IIRC, that thing wanted something like 30:1 mix to keep it from overheating.
g_man
Feb 3, 2023
367
1,694
NE Vermont
You bought a chain saw in 1923!!! :p I didn't even know they made them back then and I'm glad to hear you are still running it. I hope I can do that when I'm over 100 years old.
OOPs - I am old but not quite that old except my brain maybe :) Your a robot proof reader ???
gg
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
373
284
NH
gg
Artificial intelligence, sucks don't it
GrumpyFarmer
4,999
gg
Trick or Treat?
Frankly speaking I enjoy your posts and pictures…that being said, if you were around in 1923, you should take a victory lap and a bow. You are doing better than most based on the pics you share of your woodlot activities. Great job regardless of age.
That being said I believe chainsaw has been around longer than that (if you believe what posted online - 18 century at least in one form or another)
Now on to real business…I’d love to see a ‘what’s happening in the woodlot’ thread. I am not much of a thread starter, but there are multiple members with winches and backwoods activities that I really like to read - if I am being honest, I am living vicariously through all your posts. I am trying to learn from all you wood meisters (don’t make it weird, I am being sincere).
For the tree lovers out there, never fear, I hug every tree before I pull the starter cord.
Happy Halloween tomorrow everyone!
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
433
691
NH
Is this too heavy for my tractor? I think I might need a bigger tractor. Yes I need a bigger tractor.
We all need bigger tractors. And more implements. And an excavator, skid steer, dozer, UTV......... ;)
biketopia
Feb 15, 2024
415
438
Warrenton VA
That's why you buy a new snow "something" every year, so your chances of having to use it are minimized. ;)
I went up to PA a few weeks ago and picked up a Kwik-Way plow to mount/rig up to my B. Won't snow this year, and I'm ok with that.
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
Spent about 2 hours yesterday working on a section of out shared private road with the L3901Dt and land-plane. I was good to get back on the tractor after not using it for so long.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,191
2,849
Near Lancaster, PA, USA
I use STIHL oil, the guidelines are don't mix it rich and run the tools wide-open and the screens shouldn't carbon up. Leaving them out adds a bit of power and seems to be fine except in California and State Forests, mostly.
Had this with Stihl oil, but since the fix is so easy i will continue to use it:
imarobot
Apr 18, 2025
373
284
NH
And a place to put them all
GrumpyFarmer
4,999
Trick or Treat?
Since no one answered…the answer is TREAT(s) for my orange monster!
I picked up some bling for my girl for Halloween.
Have fun doling’ out the candy tonight everyone!
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,673
4,335
PEI Canada
My dealer picked up the L5460 Monday for the third function install, led lights, heated mirrors, front fenders and snow blower. It just got dropped off this afternoon.
Their delivery truck had some issues and they had to get the big guy to pick him up.
Reactions: 9 users
GrumpyFarmer
4,999
Nice haul @GrumpyFarmer. What are your plans for the rake?
Good day.
For me I hope it will work out a a multi use tool.
Immediately, In the spring, I plan to use that to prepare surface for pollinator habitat planting.
Beyond that, I hope to use annually to rake small pasture, clear off garden(field plantings), groom gravel drive, storm debris and clean up in woods and along wood edges…I am also hoping it may help me windrow leaves so I can scoop and then compost them…I am really not sure I have reasonable expectation with the leaves but I am going to try it before I decide if I need to buy a blower (the listed uses will be at our second/third properties where we hope to move in not so distant future)
GrumpyFarmer
4,999
Good day.
I have to ask about your blower. Our other place is in sweet spot of the snow belt of Ohio on SE side of Lake Erie. But I don’t live there so not really used to dealing with heavy/continuous snow).
Which model blower did you get and how / why you choose that model / style (appears to be back into the snow, correct?).
I plan to live at the other place (have not moved there yet - soon) thru a winter before I buy anything new, but if I find a bargain before we move I would jump on it…however I don’t know enough about what we need…we get pounded where we are off the lake, but I am not sure I need a push box, a blade or a blower.
I really like the push box / blade combos that has actuator and tilt function but price ridiculous.
I think I will start with my ATV plow and back blade and if that no worker I have to decide I want a blower. I am just not determined enough what I need.
Anyway I am curious how you chose and which model you got.
Thanks.
JonM
Nov 29, 2024
237
600
wisconsin
dug a trench for an electric line to the back of our arena where im storing the tractor for winter and needing a block heater outlet. bh92 is a beast. might be a little deeper than needed but it was fun.
Reactions: 6 users
S-G-R
Jun 17, 2020
1,673
4,335
PEI Canada
This is a Kubota branded blower made by Rad in Quebec. It is the back up style. Some winters a pull blower would be fine but most winters we get too much snow for that style. I had the same but smaller blower on my LX2610 and front version on my LX3310. This one is a K74-24-09 Kubota 74" wide 24" high and 9" chute.
This blower and a larger commercial 80'' are sized for the L/GL. They eat snow well and throw it a good distance. Normand and Pronovost are also well built blowers.
I have a 84" HLA pusher box with black blade on order.
Old_Paint
Dec 5, 2020
1,988
2,212
AL
I have to say that I'm glad the only thing I need a blower of any kind for is leaves. In the 'kept' area of my yard, I simply bag them with the little orange 'tractor', dump them in the trailer being pulled by the LX, and haul them to the 'unkept' area where I have plenty old erosion ditches to dump them in. Been doing that for 20 years, and the ditches just keep on eatin' the leaves. Don't have nearly as many as I did in years past because we had 14 removed within 100' of the house. Most had root girdle and rotten stumps. Glad they're gone after seeing all that.
If it snows here, it's usually a very wet and heavy snow that strips cedar trees like corn cobs, and normally weather that isn't fit for man nor beast. Winter snow in Alabama doesn't usually last long, rarely more than a couple days before it warms up and rains again and washes all of it away. I just don't go out in it if I can avoid it at all possible. Too many people with way too much confidence do, and I see a LOT of beat up cars after one of our winter storms. Ain't worth the trouble nor risk. I would probably be pretty popular with the neighbors if I could clear the street, though.
7,514
I've dug many miles of trenches, and believe me, it's MUCH better to dig them deeper then required then to wish you would have!!:)
