L35 - BT900 Separation and Derusting
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
CONTINUING THE WORK
I've been delayed a bit with various things, but still making some progress.
Not all dealers stock Kubota paint and I prefer to use that even though the price is egregious.
I used Kubota Dark Grey:
--Quart Part number 70000-73358 and
--Rattle can Part number 70000-00210.
These are the High Gloss versions and not the Semi Gloss.
Here are a few pictures of the ongoing progress.
The next two photos are how rust is being converted using OSPHO.
Rust turns black as the process continues.
I don't know why that section of the axle shows as orange - it's not paint.
The result after two days was a slightly rough surface ready for primer.
Frame supports after cleaning and before/after blasting.
I decided to powdercoat these.
I used high zinc powder primer, then top coated with Dark Grey powder
I had both white and grey primers so I used both:
The first color coat turned out rather nice!
More to come...
Reactions: 7 users
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
CONTINUING.......
Here are a couple of pictures from the latest work on the L35:
I won't bore you with pictures of the painting action - just a few pictures from the now-completed frame.
I think I'll give my back an extra day to recover, then I'll start putting the tractor back together (without the rust!)
Sometimes the flash makes the paint look light grey - but I assure you it's dark grey.
Next will be reassembly of the tractor followed by removal of the front wheels and tire replacement.
I won't include that but will include the upcoming backhoe work.
Fortunately I already redid the back half of the backhoe - just need to work on the part that joins with the tractor - and those darned release levers!
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Random thoughts:
I thought that I'd use my front rims again after having them blasted.
Sounds good on paper - as they say.
Just for kicks I cut out the sidewall of one of the tires so I could see what there was to see.
Wow! Those sidewalls are thick! The rubber is much tougher than a car tire.
Cutting was horrible. I used an angle grinder with a cutting disk - which was a mistake.
Cutting reminded me of my son's drift car burning the tires around the course!
Hmmm, I probably should've used a recip saw or similar. :D
Nonetheless here is a photo.
After thinking about the costs and especially the time to dismount the old tires, sandblasting, (possibly finding rusted spots), cleaning and painting and remounting, I just decided to purchase new front rims.
3,093
You may be able to get a set of tires and rims through the sales department of your dealer through a wholegoods sale.
(and you probably already know that but you said “rims” so I thought I should mention it)
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Thanks Russel
I purchased tires about 2 years ago in anticipation of this. Today i ordered rims from my fav dealer.
When all said and done - no more worries about cracked rims and cracked tires!
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
I just pulled a wheel off the truck, blasted the rim, and took it in for zink plating and powder coat: $100
Tire: $200
Unmount/dispose of the old tire/Mount/balance: $35
Given what I bought rims and tires for from Kubota "new" makes sense.
5,381
Thanks Russel
Whatever you do, don’t use (insert name here) for liquid ballast….. JK :)
But in all seriousness, the stuff you posted about Ospho is very interesting.
I have tried using it for “very light surface rust” on some of the signs I have made, and although it neutralizes the rust, its a “bitch” to get smooth again.
For the life of me I can’t figure out how to apply it and get a “smooth surface"
I basically have to “sand it all off” to get a “nice smooth finish”.
I will have to try the “paint brush” technique….So far all I have tried is rags and spraying.
It works great on parts that you don’t really care about the “finish” though. (y)
EDIT; Excellent write up too….Keep up the good work sir!
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Ha!
Thank you.
OSPHO is a funny thing to use. It is so thin that a very little goes a long way. One thing i was told by the Ospho guy is to not get things dripping wet.
A key step in the process is to have very clean metal. Any oil residue will cause an "orange peel" effect - like when painting something. Dawn dish soap was recommended.
The Youtube vids show people spraying Ospho on and it running everywhere. Totally wrong and not needed.
Yes, it took me some trial and error but the brush needs to be quite dry. It certainly seems counter-intuitive but it works.
You want as much of the rust removed as possible too. I had so much flaky rust it took a while to get down to metal!
As you brush, you will eventually run into non rusted metal. That is where you will have the most chance to leave "brush marks" . And yes i found that the hard way!
I found that Ospho gets tacky as it cures and going over rough spots lightly with a microfiber rag dampened with Ospho or a fairly dry brush will help a lot.
PS use a good brush and not for example a "chip brush" .
5,381
Ha!
Thank you.
Thanks for the tips.
I will have to try this “dry’ish method”.
I too was kinda “soaking” it…….
I mean, if a little is good, more must be better…..right?…….:ROFLMAO::)
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
CONTINUING THE JOURNEY:
Back with some info on the project.
Unfortunately I was ill for a few days with a nasty stomach-thing. Wow!
Here are a few pics of the completion thus far on the L35.
The Rear Hub received 2 new studs. The old ones had a lot of thread ground off - I guess from bad removal habits. A torch, Induction heater, PB Blaster and vice grips were ALL that was needed!
New studs went in easy.
The Step and Loader Brace got some new powdercoating
Of course the Frame Mounts were painted
Then - I hit a snag.
Years ago when I was rebuilding, I was pretty new at this and didn't use any real rust prevention.
So from the Frame Brace forward, the machine is undergoing stripping and redo.
The rust came back with a vengeance and it needs to be stopped!
Today, I decided to work on the backhoe for a change of pace - and for some gratification.
Rust work on the tractor frame is ugly, slow, and filthy.
The part of the backhoe I never got to until now...
Closeup of the Frame after cleaning - showing lots of rust.
Left Side Release components. Rust removal very much needed.
This work with require a lot of TLC in the form of blasting, and powdercoating.
It's no wonder I could never budge the Release Levers. Everything was rusty and locked up.
This mechanism should move smoothly to be able to release the backhoe from the tractor.
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
For some of these parts you can use something that eats the rust off the metal.
Like this
Thank you Russel!
I've used EvapoRust for some time and I think it's great.
I find that if I put small parts in a container with EvapoRust and then place the container into hot water, the heat makes it work faster. I use that technique with my Ultrasonic heater.
I wish I'd known about products like that 5 years ago!
Check out this photo of the latching mechanism (Holder Mounts) on an L35 I found on the Internet.
It appears that the actual Part Number 040 "Holder Mounts" (and other parts) are unpainted - which makes sense.
One of the many issues on my L35 is that paint was randomly strewn everywhere. You can see it in the above pictures.
@PoTreeBoy and @L35 I'm assuming your holder mounts and Pin Sets are unpainted as well.
L35
Jun 13, 2010
709
828
CT
Yes bare, but zinc like coating so no rust.
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Thanks guys!
I was able to get all the parts cleaned and ready for powdercoating today.
Even fought with a snapped bolt to round out the work :LOL:
NC is still having nice days so trying to take advantage working the dirty stuff outside.
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
MEANTIME...moving along with the project...
I've got the BH parts powdercoated and ready for install, but that darn "life thing" happened again.
Fall brings leaves and dead batteries in cars and Dr. appointments!
I've been delayed a bit while replacing the battery in my wife's car and blowing leaves off - well - everything!
I welded the slots I'd cut in the release arms (to get them off the BH).
Some decisions are needed on the very front of the machine where the steering cylinder lives and the bonnet mounts. Rust removal and prevention is needed. I may end up simply replacing some of it with new metal - decisions, decisions.
The BH frame where it meets the L35 is clean, and ready for rust prevention and paint.
Here are some pictures of the parts after cleaning and initial degreasing.
And here are the BH parts and also some of the Tractor Grill support pieces after coating.
All parts are coated with zinc coating and then the final topcoat.
Funny - everything really does take longer than you think!
7,263
You are an ambitious man Nick. When finished that things going to be too pretty to put to work :rolleyes:
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
COMPLETING Work on the Backhoe...
Finally at the "end" of the journey. I say "end" only for the title of the thread since I still have some further tractor work to do.
Yesterday, the front of the BH received it's paint and is ready for the release levers and such. But I'll end this thread here.
I appreciate everyone checking out the thread and I hope it helped.
Here are some pics of the progress...
The bottom of the BH has guides to help it engage the hooks on the tractor frame. The Right side was damaged and the Left side was gone.
Here is the new Left side
The Right side received a top brace
After sanding and removing lots of rust and old paint.
Here is are the same areas after OSPHO application. You can see how rust was converted to black.
Here's another view showing the LEFT (worst) side
Primed and ready for paint
Completed
The OSPHO technique I used on this portion was to wet a towel with OSPHO (very dry) and rub the OSPHO onto the surface. The conversion began immediately and was amazing. I left it overnight, and very LIGHTLY sanded rough spots with 320 paper and then applied primer.
The tools I used are as follows:
Harborfreight (copy of Eastwood) surface conditioner. I've used this for years to remove rust, paint, and mill scale from metal. It's staggeringly good.
Air tools including an air drill with Roloc discs
