Very impressive and always good to see an EA grapple working hard.Moving on to the far side of the rock, let's take what's left of the top off by drilling holes and wedging around the perimeter:
Then give it a push so it tips over the edge and the grapple can get under it:
The bottom is going to have to be split into thirds, let's pull 1/3 out of the hole:
I don't know if your tractor is like mine but filling the front axle with oil takes a long time. I've found that if I fill it until oil comes out the full plug hole and I wait a while the oil level will be low and will take more oil. Takes a while and a few checks to get it full. I asked about this on OTT and others confirmed that this is normal.Today was getting ready for winter maintenance. Oil filter, oil change, fuel filter(a PIA trying to not cross thread it as the diesel is pouring out) must of tried it four times before I got it on. Then greased everything.
And one thing I hadn't ever done since the tractor arrived here new in May of 2013- and that's change the front end fluid. Ive watched a couple videos over the yrs of people changing it. I just never have. Today I did, the fluid looked just like the engine oil. So I'm guessing it was time or slightly over do. Haven't looked in the owners manual for recommended time.
But its done now.
Thank you SGR!@Gaspasser the step is about 3.25" past the rear tire and about 4.5" past the front tire.
You're welcome! If I can find my six foot level, I'll double check the measurements.Thank you SGR!
Nice shelter. Make/model please?Swapped out the halogen bulbs for led's
Then moved the totes
Got it at https://www.princessauto.com/en/12-x-20-ft-poly-round-roof-shelter/product/PA0009027301Nice shelter. Make/model please?
