LX3310 cab model loader knob (grip) removal
Old Machinist
May 27, 2024
723
841
NE FL
Does anyone know if the loader lever knob (grip) on a LX3310 cab model screws off? The online parts site shows it as a separate part from the lever but the illustration doesn't show any threads.
It has resisted moderate attempts to remove it.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
Try an air nozzle at the stem/knob connection or at the pinhole at the top of the knob to inject some air in there while you're twisting/pulling.
3,153
If it is the hard plastic (hard rubber) type you might try to heat it up and then try to get it off.
Old Machinist
May 27, 2024
723
841
NE FL
I was hoping someone on here had removed one and KNEW if it screwed on or not. Push comes to shove I can cut it down and thread it or use a knob with set screws. The shaft is a shade over 1/2" / 13mm.
I'm thinking it is pressed on. Looking up the third function parts for the loader shows a shaft with threads and the parts breakdown without a third function shows it's unthreaded. I imagine if it was threaded to start with they wouldn't show a different part for the third function.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
There's no threads and the part number for the knob is the same as the one on my B2650HSDC.
31355-82522.
It is a 13mm shaft.
7,017
If you're looking for a nicer/comfy knob, here's what I used...its a KIOTI knob.
