A truck and trailer thread.
11,758
I'm heading to the firewood processing place tomorrow morning to pick up the first of two trailer loads of wood. The place sells wood by weight so you drive on a scale, then get under the conveyor, get back on the scale and pay based on how much wood was loaded. There's a choice between hard and soft wood, and it's cut to length and split (mostly) and I typically get 7,500 lb to 8,000 lb in a load. I usually end up splitting a bunch of it into smaller sections. In preparation for picking up the wood I needed to do some maintenance on the 16 ft dump trailer yesterday.
Yesterday afternoon I replaced one wheel/tire with the spare since one of the tires was severely damaged. I think it happened when I was pulling the trailer with a tractor and rotated the trailer about the axles without moving forward so the shearing force on the tread was excessive.
I also greased all four bearings (wheels off the ground and spinning the wheel while pumping grease in with the DeWalt), replaced the torn and tatty rubber end cap plugs, topped off the hydraulic tank and finally hosed the trailer clean, inside and out. When I bought the trailer new in August of 2019 I ordered the 2ft extensions which were well worth the $1k or so. The front extension is a single piece and it's bolted to the side extensions, but the rear of the side extensions and the rear extensions aren't connected so that the gates can swing open. I was thinking of doing something more elaborate to prevent the wood from pushing the rear extensions outward which is what typically happens, but figured I'd try a strap first. If that works well enough I might look at welding on some hooks or similar and using a chain or something.
The empty trailer weighs around 5,000 lb and fully loaded with wood it's up around 13,000 lb. The '02 F-250 pulls it well enough but does struggle on hills, but the F-450 is going to be so much better.
Reactions: 8 users
armylifer
Mar 26, 2013
2,319
1,078
Thurston County, WA
I have seen that same thing happen to my trailer tires before. They were C rated. I changed to an E rated tire and never had another problem.
According to the weight of the wood you are getting, it should be roughly about 3 cords. How much are you paying for that?
11,758
Speaking of the F-450, I've had it for a little over 7 months and around 5,000 miles and I'm completely smitten with it. It is a phenomenal truck in every way. So far there's only one small annoyance and that's the DEF warning system. The truck thinks it's DEFCON 2 when the DEF is at 50% and it'll continue to hassle me with constant warnings telling me that all hell is just around the corner and I'm a really bad person if I let the tank volume drop to 30%.
I haven't figured out if I can change the DEF level warning settings but I sure would like to. The only other small thing is that despite providing a boost gauge in the display, as well as an exhaust brake gauge, DPF gauge, DEF gauge, transmission temp gauge, oil temp gauge, oil pressure gauge, water temp gauge etc., there's no EGT gauge and I wish there were. EGTs are handled seamlessly but I'd like to see what's going on.
I have no intentions of trying to get more power out of this truck since it is nothing short of amazing as it is, but I would like to be able to monitor EGTs. There are lots of EGT sensors on the truck from the factory so I'm loathe to drill a hole and add a thermocouple with a gauge. I've done this on two other trucks, but I'm hoping that I can find some electronic device that plugs into the OBD II port and can access this information and display it.
My good friend up here just pulled a trailer back from Texas for his brother. He has a '23 Chevy with the Duramax and Allison combination and was lamenting that not only does he not have an EGT gauge, he has no boost gauge either. He's a pilot, and manifold vacuum and EGTs are critical parameters in his world.
All in all though I absolutely love this F-450 and it's the best vehicle I've ever owned with second place going to a couple of Audi Allroad 2.7L with twin turbos that I had. Those were by far the best cars I ever owned.
11,758
I'm not sure of the rating of the tires but I would expect them to be 10-ply.
Here's the receipt from last year when I paid $0.07/lb for soft wood. In theory, the 16 ft dump trailer has a volume of 16 ft x 8 ft x 4 ft which is 4 cords. The wood is split and I tend to heap it up a bit so I bet it's close to 4 cords.
Old Machinist
May 27, 2024
692
804
NE FL
I just put 5 new tires on my little 18' car trailer. I bought the last set mounted off Amazon and never looked at the date codes until I removed them to have the new tires mounted. Damn things must have been 7 years old when I bought them. I put them on in 2015 and they had a 08 date code. I made sure the new tires had a 2025 date code.
My spare had never been on the ground but at 17 years old I figured it was due. I don't use it near as much as I use to but I do keep tire covers on all 5 when not in use. Makes a big difference in longevity.
L35
Jun 13, 2010
703
827
CT
Cheapo Chinese tires will do that after a few years. Campers get tore up pretty bad when the tread separates. Known as China bombs in the camping world.
11,758
I removed the spares from the Kaufman gooseneck and PJ 10 ft single axle dump trailer yesterday. I don't like to leave spares on trailers so I keep them in the garage and only put them on the trailer or in the bed of the truck when I'm actually using the trailer.
GrumpyFarmer
5,165
Good lord that is an awesome combination…I’m drooling’.
How old are your tires? If you have not already checked the born on mold date, I would do that before getting too happy with the throttle. (I’d check that and the speed ratings on the tires, including your spare…ounce of prevention)
I’m not aware of a good visual to predict tire construction/ remaining life in the carcass vs heat cycles they’ve been thru.
Definitely one hell of a set up you have👍
11,758
I bought the trailer on 8/8/19 and all the tires are dated 1/4/19 and appear to be in good condition. They are 10-ply with an E load rating. Can't say that I'm familiar with Goodride, but given the kind of work that the trailer has done over the past six years with a fair amount not on pavement, I think that the tires have done well.
I forgot to mention that part of yesterday's maintenance was making sure all tires were at 80 psi cold and that all the lug nuts were properly torqued.
L35
Jun 13, 2010
703
827
CT
Just fyi, 1419 date code is the 14th week of 2019
armylifer
Mar 26, 2013
2,319
1,078
Thurston County, WA
Wow, I have never seen an E rated tire do that.
11,758
Thanks for the correction! 😂😂 So they were made in mid April of 2019.
11,758
Yeah, the trailer was loaded with firewood and I remember using the tractor to back it up, and then the tread came off. I was on grass at the time.
I made a post about this trailer and how my friend trashed it when he used it to pick up boulders for a project. Maybe the tire was damaged at that time due to the trailer being overloaded. I'm not sure and will never know. It's all water under the bridge these days.
I've thought about selling this dump trailer and buying another Kaufman in the form of a gooseneck dump trailer with two 10k axles like my 30 ft Kaufman. The downside is that the dump trailers aren't available from the Nebraska facility so it would mean a much longer drive or having it delivered. Probably better to keep this one and fix the floor and call it good.
armylifer
Mar 26, 2013
2,319
1,078
Thurston County, WA
I am not sure if we are closer to you than Nebraska or not but maybe you want to check out this place? They have all kinds of trailers. I don't know if they have what you are looking for but they have a lot of trailers.
GrumpyFarmer
5,165
I am not familiar with that tire either. Out of all your trailers and miles pulled, how many treads have you separated from the carcass? I’d be gun shy of knock off tires past their age recommendation. (I’d had a blow out already with some cheap tires that came on a trailer that blew out). Maybe they are fine?🤷‍♂️
Not to quibble or anything, but Load ratings not quite the same as speed ratings. From my tire blowout, what I would be concerned with is if the carcass has lost its integrity and using the trailer above the rated speed for the tires…when those babies heat up, that’s when things get real interesting. (At least that was when i wrinkled the pleather seats in my Ruby Red)
Keep the rubber side down (and in place)
11,758
I've never had a flat on any trailer let alone a complete tread separation. These tires aren't a bottom of the barrel type, and given the cost of PJ trailers, I wouldn't expect them to be. Even Walmart wants close to $133 for a Goodride ST235/80R16. They're a 10-ply, E rated tire with double steel belt construction and a nylon cap to "further increase strength and durability". :unsure:
11,758
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
268
362
upstate, NY USA
McMXi,
Assuming your second load of firewood is equal weight to the first, that's about $1226 for annual heat.
Here at my place we burn pellets, as it's considerably less labor/effort for us vs cut/split/stacked firewood.
Last season we burned premium Canadian 100% hardwood pellets, using just over five tons.
Last heating season, those imported Canadian hardwood pellets were ~ $400 per ton.
Last year, $2000 plus the extra individual ~ 20 bags needed to finish out the heating season.
40 pound bags, 50 bags on a shrink wrapped pallet.
I didn't even bother pricing the Canadian pellets this year, I was certain the price had not dropped.
We finished out the heating season with about 20 bags procured from our local Tractor Supply store.
I don't like to store a quantity of leftover pellets during the off season and don't like more than five bags sitting around for the summer.
Space limitations and pellet deterioration, crumbling/dusty.
Those Tractor Supply heating pellets are USA manufactured, North Eastern USA trees, and have a unspecified amount of softwood. When the pellet stove comes up to operating temperature, the softwood (some type of pine due to the gentle fragrance given off by the slightly heated pellets in the stove storage hopper) and it is like being in the Adirondack Mountains on a camping/hunting trip.
Our pellet stove is a Lopi AGP. The AGP is for All Grades of Pellets.
I was initially concerned about the softwood/pine content, but when I did my annual pre heating season maintenance on the stove, there was no visible difference in the stove (deep cleaning of the stove interior guts) or the exhaust stack.
So this year, we will be using the Tractor Supply pellets at $320 per ton.
They are rated at 8400 BTU/per bag.
Five tons is $1600 plus the individual bags needed for finishing the heating season.
Assuming the quantity used per heating season is similar to prior years, but is an unknown now due to
what type of winter is coming. By late April 2026, I will know for sure if the expected cost savings for the Tractor Supply brand pellets was actually a cost savings, or not.
I use my 7000 pound rated double axle landscape trailer for hauling pallets of pellets home.
It's the trailer used for hauling the BX 25 up and back to my recreational property.
In the past, I have dragged two tons of pellets home on that trailer in one trip with my Jeep Wrangler Rubicon, but this year we used my G/F's Toyota Tacoma. It's almost zero elevation change from the pellets stores going to the house, and the trailer has four wheel brakes.
That sure is a beautiful F 450 and I am glad that you like it!
My friend and neighbor runs a pair of F 450's for hauling his well/septic business equipment.
IMG_20190711_200322180 by cee_Kamp 32ACP, on Flickr
Botamon
Mar 26, 2018
482
902
Winnemucca, Nevada
$600 for 4 cords of firewood? That's really cheap compared to here in northern Nevada. Prices I've been seeing range from $300 - $400 a cord - and that's not split, just the rounds.
But then you have a lot more trees in your "neck of the woods" than what we have here in northern Nevada!
11,758
I picked up 7,650 lb of hardwood at $0.07/lb and the total cost with the CC fee was $551.56. I might empty the trailer out and then drop it off on Friday for them to fill up and pick it up next week. They offer that service at no cost. This load of the wood is the best I've seen in terms of quality. It's really good wood and should provide a lot of heat.
There were four trucks in front of me so I had to wait almost an hour in line but no big deal. I got home without incident and the truck/trailer performed very well. There's a hill on the way home that I've pulled a loaded trailer up a number of times using the F-250 7.3L. I've pulled gravel and wood up that hill and there's no comparison to how this F-450 pulled the load today. It was absolutely effortless. The F-250 struggles on that hill, but in fairness, it doesn't have the rear end or transmission or 1,200 lb-ft to make it look easy.
The last photo shows the hill but doesn't really do it justice. There's a hill, than a flat spot then a much steeper hill.
