Box Blade
5,190
I don’t have time to read the replies right now, but one thing that concerned me was the way the ripper teeth are attached.
Personally, I would not have one that takes “special clips” to hold the shanks in place. I would only buy one that uses simple “pins” to hold the teeth in place.
I passed on a Landpride model for this very reason.
(Unless you can weld and could convert it…)
..just my .02
Shawn T. W
Dec 9, 2024
755
1,375
SW Missouri Ozarks
What should I be looking for? I'm a newbie so take it easy on me.
I just need something for driveway and trail work that is functional.
While you have been given good advise, I'll throw a monkey wrench in the gears with a question ... Are " maintaining" or "building new"?
For maintenance, which I'm guessing is what you really want to do ... I'd consider a "Land Plane" ... 60" - 72" some have rippers too, if you want them ...
Branch Collector
B2650
Sep 29, 2025
23
26
North Carolina
It's been a long time since I was looking for implements, they seem to have dried up. But I did get a 6 footer, box blade (no name that I could find). It's been really good and helped build a road to my creek. Got it for $250 and I'm sure I could sell it for more, now...
You have to be really quick since resellers will buy it cheap and just mark it up... It's hard to find good deals nowadays....
You could definitely make money on that now, especially if you have the rippers.
Branch Collector
B2650
Sep 29, 2025
23
26
North Carolina
Yes maintaining. I'll add new trails over time but primary goal is maintenance for now.
I've looked at land planes briefly. Not as many for sale and more expensive but would definitely be nice to have one day.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
188
257
Hardy, VA
I echo many of the arguments above. Keep an eye on FBMP and CL and you'll find one. Decide up front if QH compatibility is important to you and buy accordingly. Buying heavy is also good advice as I have had to add weight to mine to get it to work well in certain situations. Make sure that the BB is wider than you rear wheel width so you can use it to cut into a bank for a sidehill trail or just get up close to objects. Pins for the rippers is a great heads up suggestion. Once you get a rear blade, you WILL WANT a rear hydraulic toplink to make on-the-fly adjustments so much easier. I have a ton of trails - or "Kubbie roads" as we call them - here that I have made. For maintenance... the box blade is great for the heavy work but I have found a 5ft wide drag harrow with 3/8in tines to be the easiest for grooming them clean and smooth.
5,190
"Amen" to this.
And if you want to avoid "leakdown", get a DPOCV on the cylinder BEFORE you buy one.
Damn near impossible to retrofit one. (ask me how I know ;))
nbryan
Jan 3, 2019
1,415
934
Hadashville, Manitoba, Canada
..just my .02
The BB1560 has the round pins, which are spring clip held.
I somehow lost a pin once and subbed a heavy bolt until it showed up again.
Branch Collector
B2650
Sep 29, 2025
23
26
North Carolina
They sell so fast. I've had a lead on 2 that were gone in 12 hours before I got a reply to my message.
Tractor supply is an option. I assumed they were lighter weight 'cheap' model compared to something higher priced, but I could be wrong. Has anyone used one? I would like QH capable for future options even though I don't have one yet.
BAP
Dec 31, 2012
3,148
1,272
Agrisupply sells box blades too. Similar to Tractor Supply or Running’s.
Blue2Orange
Apr 3, 2025
405
283
Bayview Township
..just my .02
Purchased a used LandPride when I downsized to the BX. Couldn't pass up the price for the few scratches and one of shanks showing a bit of rust. QH compatible. The clips stink. Replaced them with a set of L style shank holders. Simple and inexpensive fix to the poor system LP uses.
JonM
Nov 29, 2024
252
638
wisconsin
The best reasons to NOT buy a used box blade: 1. You like new things. 2. You are not concerned about cost.
3. you dont want to go immediately into emergency repair mode part way through the first use....
price out a new one before you buy a used one. ESPECIALLY if you have to rent a trailer or drive a long distance. if you dont know current cost of new its easy to "get a deal" and spend a hundred more than new in transport cost if you dont know current pricing.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
While any purchase should be researched, the box blade (for me) wasn't very involved. Didn't need something to pass along to the grandkids or something that weighed 1,200#. The intended use was transforming 1-1/2 acres of corduroy textured cornfield into more grass to mow around 2013. Found a used 5' King Kutter and resold it when finished. That was the only time I needed a box blade in the 35 years since we built here. It was used for a few weeks and resold without losing much if any money when the work was finished.
Simplemike
Indiana
I have one from Rural King that's 48" wide and a tiller from there that's
also 48" for my BX2380 and they both work great.
Tim Horton
294
69
Lake Superior
UM..... The box blade I had was the cheapest local auto, farm store, China built option I could find.. It was cheap, a bit crude, but worked very well for the things it was intended to be used for...
If I needed one again, I would buy cheaper used in a hot minute, refurbish as needed, make it any color I wanted and be more than happy with $ saved... I had used attachments that I painted red, black, white, yellow, green, orange, blue and pink... All depending on what paint I had available.. One color never worked better or worse than another...
My 5 cents of opinion and experience...
Good luck...
Blue76
L2501 / L3600 / Yanmar YM2500 / Various implements
May 30, 2025
38
12
Thanks. Yes I have a truck and access to a trailer so I can go get it. I'm not willing to travel 8 hours for a box blade, my time is worth too much it'd be cheaper to buy new at dealer.
Would love to have hydraulic remotes added one day. That's way down the list though, for now I just need something for driveway and trail work that is functional.
Looks like 700-950 for one used in decent shape. What does the Landpride 1260 go for at the dealer these days new?
Not trying to muddy up your plans but I have two box blades... 5' and a 6'. Both are sub par compared to the land plane for leveling up a driveway or other uneven ground. If you are trying to move dirt or gravel then the box blade works well. If you want to fill in ruts or put a crown on a gravel driveway, the land plane it the ticket. I was super skeptical until I bought one.
11,754
I almost bought this Land Pride HR3584 from the local dealer a few years ago. Kind of wish I had to be honest but at the time I didn't think it was particularly affordable which in hindsight was a mistake given the current cost of implements. I have a 7ft EA box blade, 7ft EA land leveler and an 8ft Buhler/Farm King rear blade with 3-way hydraulics, but this thing sure would be nice. The EA method of adjusting the height of the scarifiers on the the box blade and land leveler are ok but still annoying compared to moving a lever in the cab.
Branch Collector
B2650
Sep 29, 2025
23
26
North Carolina
I've got a slope that gravel washes down regularly so I feel a box blade would be better but maybe I'm wrong. There are even fewer land planes than box blades for sell used, and of course they cost more, so I may have to wait until I find the deal or can afford new. I'm definitely open to a land plane though.
