Fuel injection pump query re: BX2200 & B7800
1810
BX2200D
Mar 21, 2017
25
Bonifay, FL, USA
Two different units but there is an odd link. Back in May, I received an email about a fuel injection pump issue & it turned out to be as a result of a post I made in 2017 about a BX2200. The guy who emailed me was the B7800 owner. To say I was surprised is an understatement & all of a sudden I had to go searching for information in my own files & I found what I was looking for, fortunately, & I sent it on to the guy. I didn't post all I had here because it was too much. Some things you have to do privately. What did I send, apart from detailed photos of an injection pump disassembled & itemised components, parts manual drawings & more? I offered advice from the mid fuel line lift pump to solenoid, how to test them & the pump itself down to components. The bottom dollar line was a new injection pump for £1,000 or more or could I help? He didn't bench test the solenoid but bought a new one. This is where, for all the advice I gave & all the time & effort I invested, in trying to help, was a waste of time. Why, because although I'd detailed everything from fuel tank to injectors...I missed the basic of basic things...& I'm a tech savvy guy...almost. Somehow, between us + his 14 year old grandson, during new solenoid testing his grandson asked about the fuse. We already knew the solenoid wasn't supposed to be working but this whole event turned out to be the fuse to the fuel cut off solenoid. That's how easy it is to miss the simple & get things really complicated. If there is a moral to this tale...start with the basics of both mechanical & electrical, if electrics are involved, & think what they are or can be before you make a mountain out of a mole hill.
torch
Jun 10, 2016
2,800
1,030
Muskoka, Ont.
Rules of troubleshooting:
1. Check the simplest possible cause first: it's cheap, fast and usually the problem.
2. What did you do just before the problem occurred? Again, often the cause...
Mark_BX25D
Bx25D
Jul 19, 2020
1,882
1,368
Bad solenoid is the number one cause.
Yes, absolutely! But occasionally, fuses just... fail. No real reason.
That happened more often with the old glass fuses. Modern plastic ones are built on machines that have better quality control, but still, it does happen now and then.
I'd look at a bad solenoid first, but never assume!
kessary
B7800
Oct 3, 2025
Tulsa, OK
All my fuses are good but I have no signal going to either wire on the solenoid. Any help you can give me would be appreciated. I've had the tank and guage cluster out, only bad wriring I found was where the fuel tank was sitting on the clutch switch.
9,275
Have you looked at the wiring schematic in the WSM?
3,652
Fuse Failure Causes:
1. Electrical Over-Load.
2. Poor Mfr’g Quality (of the fuse itself)
3. Vibration
4. Corrosion (receptacle dissimilar metals, creates heat/overload)
Do not buy the “cheapest” fuses you find on the internet. Select reputable brands such as Littlefuse and Bussman which meet SAE J2077. No advantage is gained by the purchase of bargain safety items. (Throw-away that cheap “Happy-Joy” brand chinese fuse assortment you bought. They are hazardous to your equipment And Yourself. They are often improperly constructed/rated in order to mimic “reliability” which, in fact, hazards you and your equpt. <edit> By “improperly constructed, I mean they are built heavier-amp than actually labelled so as to not “blow” prematurely…. which means they will allow equipment damage and fires before they perform the safety-function for which they are intended. Actual Test: I tested three 5A off-brand chinese fuses and all three actually passed 10A before opening/blowing. A 20A from the same assortment passed 35A before opening, and two others passed 30A. It is as-if the mfr’r used a ”Minimum Current-Capability Scale”…. rather than a Maximum Current rating.
Be aware that a circuit which has suffered repeated fuse-failures may have seriously damaged wiring. Each time the fuse “blows” due to actual circuit overload subjects the circuit components to design overstress. If any component of the circuit is minimally engineered it may be permanently compromised. Be especially vigilant if the circuit serves a safety-system.
kessary
B7800
Oct 3, 2025
Tulsa, OK
Don't know what's going on with mine but it won't start until I apply voltage to the shutoff solenoid, if you leave voltage on so it can run it'll smoke the solenoid. It runs fine if you remove the solenoid but then you can only kill it manually at the pump.
9,275
There were mutiple wiring variations on the B7800's.
You more than likely have a variation that has 2 signals that feed the stop solenoid.
One signal is the pull in signal that comes from the starter.
The other signal is the hold signal which comes from the OPS controller.
If you apply voltage to the pull in coil too long it will fry the solenoid
There is no relay for the stop solenoid on the US models (non OPC models used a relay), the pull in signal is direct from the starter and the hold signal comes from the OPC via a 5amp fuse.
You can use a simple test light to confirm signals and operation.
