Help me Shift L3710 out of 4WD
N3BP
Sep 20, 2016
505
236
Lebanon, PA
Try placing your right foot on the treadle pedal and rock it back and forth (moving the machine slightly forward, then slightly reversed) while placing the heel of your left foot of the 4wd lever forcing it down. You should reach a point where there is no binding on the shift collar and it should release into 2wd.
When you have it in 2wd on a flat surface, how easy does it shift between 2WD and 4WD without moving the machine? If it's still problematic, then you got more going on beside a lag-lead match.
What size and type tiers to you have on the front and rear? See attached for what Kubota would have available from the factory.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
Thank you. That looks like great information.
I am having some weird symptoms at the tail end of what is probably the flu, so I will not be fooling with the tractor until at least tomorrow. At least my parts arrived.
7,075
What you think might be the flu may also be covid. It's going around. I was told it's a different strain then all the commotion was about a few years back. Dr. says it only last 4 days. Use to be they prescribed Paxlovid. Not now. They tell you to go home, drink a lot of fluids and rest. So if it's that simple one doesn't really need to even get a covid test!!
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
This one isn't covid. Our son managed to find us something else. I think the flu got around his vaccination. My wife and I were just about to get shots when he got sick and passed it to us.
It's not much of a flu, thank God.
I'm glad to hear covid is getting more mild. For us, it's no more unpleasant than a cold, but it's nice to hear good news for other people. A buddy of mine was hospitalized once.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
I should add that we already had our delightful yearly visit from the covid fairy.
Shawn T. W
Dec 9, 2024
409
743
SW Missouri Ozarks
From my manual ...
Push down to engage front axle, pull up to disengage 4X4
2,433
If you have that “small lever” it looks like you could easily loop something around it to help pull it up. Perhaps a rope or endless loop will work to help you get it out of gear?
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
That sounds like a great way put it IN gear, but I have to push it down to get it out. I am reluctant to step on it, and I only have one left foot anyway.
2,433
The manual posted above say ON is DOWN and OFF is UP. See below.
Is yours reversed to that manual? If so the use a forked stick to push it down since you have trouble with reaching it.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
It's a different model with a different manual, and the directions are reversed.
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
It turned out the problem with the loader was a defective assembly between the seat and steering wheel. I thought the loader extended farther down than it did. When I put the bucket back on, the loader lifted the front end just fine.
I really need to replace that defective assembly.
I hope this helps other people: lifting the front wheels did no good at all, but when I turned them all the way to one side, I had no problem shifting out of FWD.
7,075
Mr. Haney, I'm curious this "...a defective assembly between the seat and steering wheel". Is that the operator? ;)
Mr Haney
L3710, ZD326S
May 23, 2022
378
97
FL
All I can tell you is that it appears to be an American, not Japanese, part.
