L4400 fel not working
bsamot69
M9000, m9540, m6060, L4400, SVL 97-2
Jul 31, 2018
152
Grapeland, Texas
We just got a l4400d recently and the bucket neither goes up or down, does not tilt either. The 3 point in back didn't move, however, turned the flow valve under seat and it went up after a few minutes. When push lever down it drops very slowly. Power steering works .
I changed the hydraulic fluid and filter. I shouldention the tractor has 151 hours and has been sitting for a long time. The fluid I drained out was dark and hideous.
New fluid and still no actuation. Disconnected hoses going to block under right side to verify there is flow. Then checked the quick couplers on joystick ...there is oil flowing. I have not seen any trash or debris at this point. With tractor running, now, moving lever for up the bucket moves an inch bit no further. The tilt up worked but did not hold. I cracked the lines at the t for rams and when raising had good squirt of fluid. Same with t for tilt , there is pressure. On the joystick, the covers over springs on plungers I removed. The larger spring was rusted and corroded. I cleaned it up so it moved freely. I checked all the inlets outlets in joystick and saw no debris . Put it all back together and the same issue. No up or down on fel. Hoses vibrate at each position but no movement. The tilt up no longer moves up. There are no external leaks. I'm not sure where to go from here. Is there a way to check pressure from.pymp? Or what have I missed on the hydraulic system?
Any advice or suggestions are appreciated. I have not done much work with hydraulics.
5,833
Let me see if I have this right. Neither the loader nor the 3pt work. Is that correct?
Do you know the model number of the loader?
Do you have a backhoe
2,434
Get a few (5?) posts so you can post pictures.
What is “the flow valve under seat”? Is it the speed control knob or something else? Speed control is to limit the down speed only of the three point hitch (TPH). Open it to fast and the arms will move down faster with less weight on them. There are some tractors that have a valve that must be turned to a certain position for both the FEL and TPH to work.
There is an operations manual at this site if you need it. I didn’t see a WSM but you may find it if you look closely (I just scanned the list). A similar tractors WSM might help you with troubleshooting steps.
If the fluid was terrible then you may need to get flow out of the hoses in steps to help clean out the hoses. By steps I mean get flow through the hose to the FEL inlet. Then out go the Power Beyond hose, then out of the hoses to the FEL cylinders. You have done some of that already it sounds like.
You may have a pressure problem but flow is OK so you may want to gather a method to measure the pressures on the tractor and FEL. A 3000 PSI gauge and some adapters will be needed. There are suggestions on other threads and @TheOldHokie will be able to give more suggestions as he gets into this more. He will give you good help if you will provide good information and feedback!
bsamot69
Jul 31, 2018
152
Grapeland, Texas
I will get loader model...the tph functions, however, when I move lever up it takes 5 minutes or so for the hitch to move up. Lever down same thing, slow response. By backhoe do you mean implement for the tractor ?
We have a Cat backhoe machine also.
5,833
By backhoe I meant attachment for the tractor.
The 3pt lowering speed is controlled by the knob under the seat. Sounds like you have it mostly closed. Open it and lowering speed should increase. That knob has no effect on lifting speed or power.
Off the the top of my head sounds like you have a pump delivery problem of some sort. There are some simple tests that can help pinpoint the source of the problen.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
The knob under seat is turned open all the way. From what I can gather the model is Ansung NT 2834 loader.
I'm all ears on performing pinpoint tests. I do appreciate your help with this!
5,833
The first thing I would suggest is a pressure and flow rate test. You will need a clean 5 gallon bucket and a 3000 PSI pressure gauge ($20).
  1. Disconnect the delivery hose at the loader valve. That is the top right hose (B) on the tractor outlet block.
  1. To test tractor outlet pressure connect the pressure gauge to the hose, start tractor and record pressure
  2. To test tractor outlet flow rate place the open end of the hose in the bucket, set throttle position to max, start tractor, and time seconds needed to fill bucket to the 3 gallon mark. Immediately shut tractor off at 3 gallons and record elapsed time.
Factory specification is 2560 PSI and 3 gallons in 20 seconds.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Okay, I have to get gauge. I'll be back:)
5,833
To verify, should I tee the gauge into the hose..or, connect it directly?
If you used a tee all you would see is the neutral circuit pressure which is maybe 100 PSI. Connect the gauge directly to the port. That will deadhead the circuit and force the relief to unload.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Well I'll be darned, Amazon gauge 10 bucks, delivered in a day, today .
Though , the fittings were not compatible. I went ahead with the flow test. I read the instructions and I read to disconnect hose, stick in a bucket and run tractor. The fluid streams out of fitting on block:)). So, the few seconds it took to shut off tractor were a bit messy, lol.
I'm going to tractor supply see if I can find an adapter to do pressure check .
With this latest discovery, I should attach gauge to port on block? Or is there something wrong with the hose routing?
5,833
Your goal was to measure flow. Disconnect the hose at the loader vakve - not at the block That way you dont make a big mess.
To measure pressure leave hose connected to outlet block and connect the gauge to other end of hose.
I would guess the hose has a JIC-08 female swivel end and the gsuge is 1/4 NPT. If so this is the adapter.
bsamot69
Jul 31, 2018
152
Grapeland, Texas
Thank you for your patience. I'll get the appropriate adapter and move forward mess free, LOL. The loader valve being the joystick assembly, yes?
5,833
The pressure jumps up to just over 2600 psi. I shut off tractor pressure immediately drops to 0 psi.
I ran tractor at 1800 rpm for 20 seconds. About 1.5 gallons of fluid in bucket.
Pressure is good but flow should be double that. Remeasure flow at max engine RPM.
