Missing u-joint Zerk
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
im assuming this is here it went. Where do I start? There's no model number or branding on the pto to try to research the right zerk thx
bird dogger
Feb 24, 2019
1,804
1,779
North Dakota
Is there a zirk on the other end of the shaft? If so, pull it and most likely its a match for the front end of the shaft.
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
If no marking on the PTO probably metric. So go down to your nearest Harbor Freight, buy their metric zerk variety pack and it will probably have the right one in it (thread pitch and style). Some are straight some are angled for better accesss.
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
thanks for reply...didnt even know HF had them...how do they pack so much in that small store..thanks man
4,238
^^^^^^^^^THIS^^^^^^^
It’s all made out of compressed rice-hulls so it doesn’t take up much room. 🤡
pigdoc
G1800S L2500
Aug 19, 2022
403
350
SE Pennsylvania
Just a potential word of warning.
I had to replace a couple of zerks on a RC54 mower deck. Metric would not fit, SAE would not fit. Had to get a couple of Kubota zerks. As I recall, they were like, $2-$3. Each.
Paint on ujoint looks original, so you might be in for a parts chase also.
Good Luck.
-Paul
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
The ones on my Kubota were M6x0.75mm thread. Bought them on Aliexpress.
7,325
Good Luck.
-Paul
Possibly BSPT.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
Just remember, before you screw in the zirk that fits, you clean out as much of any old lube and dirt that is in the hole before pumping in any more grease. For me, if I was in this situation a blast of brake cleaner in the hole to clean out any old grease with grit in it would be my first priority. Good luck.
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
Good Luck.
-Paul
yep it was a parts chase...finally found some.
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
I took your advice..the brake cleaner def cleaned up some gunk. Thanks
