Suspension Seat on a Zero Turn?
LarryBud
L3130
Dec 5, 2020
255
134
Cleveland, MO
Does anyone have thoughts on an aftermarket. Suspension seat for my Gravely 52HD? It’s dry, the ground is hard and it’s killing me.
Don’t want to throw money at it if it’s not going to change things much.
thanks
lynnmor
B2601-1
May 3, 2021
1,823
1,624
Red Lion
I installed a Trac seat suspension on my zero turn, it helped a fair amount. Certainly not an air suspension but the price isn't crazy.
9,118
I have a suspension seat on my kubota zero turn. Absolutely love it.
I would definitely consider upgrading your seat
4,245
Are your tires being run at the recommended pressure?
My mower had a “hard” ride….. until I reduced the tire pressure from 35 psi (as received) ..to the 18 psi the manual specified. It rides fine subsequently.
9,118
Which suspension seat do you have, if you don’t mind me asking
Mine came with one already installed from kubota 🤷‍♂️🤷‍♂️🤷‍♂️
That was actually why we went with the model we purchased. My wife has a bad back, so this way it didn't beat her to death.
mike0000
Kubota L3901, RTV900
Sep 15, 2021
84
92
Southern Indiana
I recently put this one on my ancient Great Dane zero turn. It helps a lot, but it sits quite high, I set it to the lowest position and added 1-1/2” (wood) to the foot rest deck. I’m not tall, 5’8” on a good day. I couldn’t hardly stand mowing anymore due to a bulging disc, and I cut a lot of grass. Other than the higher seating position, I’m pretty happy With it. It was about $250, Vevor.
11,268
I just did mine, a real kidney saver!
I picked this one over the one @lynnmor posted just because it clears the safety switch in the seat.
LarryBud
L3130
Dec 5, 2020
255
134
Cleveland, MO
Good Call. Should be at spec. I may take them down some.
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
I installed one of these on my Ariens IKON XL60 shortly after purchasing it. If there was any improvement in the ride it was very little. I have watched videos on comparisons between non-suspension zero-turns and suspension type like the Ferris and even they were not much better. Have come to the conclusion that I am better off trying to remove the bumps on the lawn rather than trying to improve the ride of a zero-turn.
lynnmor
B2601-1
May 3, 2021
1,823
1,624
Red Lion
Did you adjust it for your weight? It needs to be adjusted to a point where it won't bottom or top out, then it will improve things over having a seat mounted solid.
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
I sure did! Tried it at various points as well.
11,268
The model I used was night and day difference!
Shawn T. W
Dec 9, 2024
846
1,545
SW Missouri Ozarks
I have the factory suspension seat on my John Deere ... It is AWESOME! (I tried one without it, and definitely wanted the suspension!)
I also run my tires at 8 psi, down from the 12 ... Rides even better!
biketopia
Feb 15, 2024
437
469
Warrenton VA
My SCAG Turf Tiger had a solid seat. Picked up a parts mower mainly for the suspension seat, night and day difference in cutting my 5 acres. If I hadn't scored the parts mower for what I did, I was going to to do one of the options already listed in this thread.
