won’t start
4,364
What model is it,, remember the better your question the better your answer
9,394
Yea, your going to have to give us a whole lot more info to work with!
clyde stech
Tractors
Aug 27, 2025
Columbus, Texas
MX 5200
you can start it up six times in a row then maybe like the seventh time it will not start up. I dumped all the diesel out the tank put fresh diesel, and new Filters. It was absolutely the same situation.
2,419
Explain what you mean by “will not start up”
Do you mean cranks over (engine spins) but does not fire the cylinders?
Do you mean it won’t even spin the engine over?
I assume you meant the first since you have been looking at the fuel already, but please confirm that.
I would assume it is a fuel issue and probably is the solenoid that controls the fuel getting to the injection pump.
See this thread for similar problem (found by searching “fuel solenoid”)
9,394
This is a very computer controlled engine.
Any codes?
About the only logical way to approach this issue is take it to a dealer and have them put it on a computer and properly diagnose the problem.
clyde stech
Tractors
Aug 27, 2025
Columbus, Texas
Took it to the dealer in Brenham, Texas. It was a total flop. They changed the fuel filter and drained the diesel. now when I left the dealership it cranked right up. The next day it totally failed to start.
2,419
If you can easily get it back to the dealer they should be able to fix it under warranty of the fix that didn’t fix it! Heck, they may even do a field service for you.
If not get a Work Shop Manual (WSM) and investigate the fuel shutoff system. The dealer has the diagnostic test system so can do it easier than you (I assume).
If you get the dealer involved, suggest that it is something that is keeping the fuel from being injected into the cylinder. It could be some biological growth in the fuel system??
9,394
That dealer did you no favors.
Either the issue was not copyable, they did not get the proper history of the issue, or they simply just dropped the ball.
nbryan
Jan 3, 2019
1,342
870
Hadashville, Manitoba, Canada
When it doesn't start:
Are the glow plugs being energized the same as when it does start?
While cranking are there any fumes or smoke emitted from the exhaust pipe?
Does the engine cough or fire at all?
Is ALL the safety switch related gear in the same state as when it does start?
How long after a successful run does the start failure occur?
How long after failing to start before it's started again?
Has there been any large change in humidity or temperature?
In other words, what's different when it won't go?
2,419
The question above made me think of this variation on the questions:
If it doesn’t start, what do you do to get it started again? Or does it magically just start again on some multiple of attempts?
9,394
Sorry to say this, but 90% of this does not apply to a common rail electronically injected emissions controlled engine.
4,160
"Intermitent problems" have been “problematic” (to say the least) for every mechanic/service advisor/service manager/customer, ever since time began……..
Murphys Law clearly states this…...
clyde stech
Tractors
Aug 27, 2025
Columbus, Texas
this is a common rail.
my question is on this MX 5200. It has a yellow wire and a red wire going to the solenoid shut off.
yellow wire reads 3.5 V and the red wire reads 12.5 V
what the hell?
9,394
There is NO shut off solenoid on a common rail system, so I have no clue what you're measuring.
Randomly guessing at the parts and possible voltages at those parts could be very costly.
Read the WSM for possible troubleshooting, but ultimately you are probably going to need to have a Kubota dealer use a computer to properly diagnose what is going on with it.
