1984 L345DT Refurbishment
DSDispatch
L3800, L345DT
Apr 22, 2020
66
37
Longview, TX
Just picked up a 1984 L345DT from an estate sale.
The good:
> both passenger tires are new
> fresh battery
> was purchased by original owner in '84, stored under cover, and used to bushhog a 5 acre property
> hours show as 498, but these units are notorious for the cable breaking and hours reading low (still, it doesn't say 5000)
> strong hydraulics
> came with a 5' bush-hog - will work on that along the way too
> engine seems to run smooth and strong
> high and low speed pto seem to work well
> all levers and gears seem to operate and shift smoothly (pto high low, high low gear, 1-4, R, 4wd, etc.)
The bad
> solenoid must be "jumped" to start it, but ignition switch just spins, so seems to be a $51 fix
> oil leak of some sort
> clutch seems to engage at the last second, so not sure if that needs to be replaced or the linkage needs to be adjusted
> step welded to left side is sagging the left side footrest a bit
> exhaust pipe broke off the muffler, but i have the piece
> wires sagging, but operational
> headlights presently don't work
> seat needs to be refreshed or replaced
> paint on fenders needs help
> couple dents in the hood need attention
> bumper that holds suitcase weights is bent
> right-rear marker is broken
Photos for your enjoyment:
Oil leak
Use two screwdrivers to arc these two connectors and she'll start!
Fenders and seat are a bit rough
That side-step has got to go...
I have never refurbished a tractor before, so follow along as I document my learning and ask lots of questions. Thanks in advance.
I am updating this post with useful links I find to part suppliers, paint information, and how-to articles:
Kubota Paint Codes & Color Chart (Oranges, Blues & More) | Messicks
Parts Suppliers
Thread on sourcing parts, etc. - https://www.orangetractortalks.com/forums/threads/must-have-websites.19438/
New Suitcase weights - https://tractorweights.com/product/front-weight-usa-aftermarket-bl8060/
11,025
#1 that's not a stock start solenoid, someones added it.
pigdoc
G1800S L2500
Aug 19, 2022
403
349
SE Pennsylvania
Nice looking machine! Creampuff! I'm envious.
When it was running, did the RPMs register? if so, hour-meter is probably working.
Front tires look much larger than the stock 6.00-16s. And, the LF tire is a Carlisle, so it's been replaced too. Looks to me like LF has been replaced recently. But, lugs on that tire are fairly torn up, so it's been used (a lot?) in 4WD. I'd check rolling circumferences before driving it in 4WD on a grippy surface (like pavement).
Rears should be 13.6-28.
Easy fixer-upper. I would probably have paid at least $4000 or $5000, at auction.
-Paul
DSDispatch
L3800, L345DT
Apr 22, 2020
66
37
Longview, TX
Yessir, rears are 13.6/12-28. Fronts are 9.5 16's., listed on sidewall as 9.5-16 or 240/90-16. They both match with RH front being very new.
I paid $4300 and got a similar vintage tractor supply 5' shredder, 3-pt pallet forks, and a boom.
Will be in 2wd on grippy sufaces - 4wd is for when stuck. :)
11,025
Thanks for the note - wondered about that.
Is this to fix an issue with the existing starter or to replace one that existed there before?
Its someone's "fix" for an issue.
You shouldn't need it.
pigdoc
G1800S L2500
Aug 19, 2022
403
349
SE Pennsylvania
Well, I'd be shopping some 6.00-16s for the front VERY aggressively. Don't know the earlier model series very well, but on my L2500, that front driveshaft is not very beefy. 15mm. Mine was tore up when I bought it, splines stripped off both the shaft and the front coupler. Reason: mismatched front and rear tires.
Don't know where you are, but I would bet that there are a couple of nice used ones sitting about 20 miles from where I live in southeast PA.
-Paul
11,025
-Paul
He can NOT switch to 6.00-16s that would be the wrong size.
He has the right size tires on it now.
pigdoc
G1800S L2500
Aug 19, 2022
403
349
SE Pennsylvania
The seat on my L2500 was torn up badly also when I bought it with 1400 hours on it.
The faded paint your L345 makes it look like it's spent quite a bit of time outside, too.
I got a generic seat off eBay, and the stock bracketry bolted right up. Metric bolt holes in the seat, too!
I can try to post some pics. Did that right away after buying the tractor in 2023.
Nothing worse than a wet ass when you're blading snow...
-Paul
11,025
This is one time that they are correct.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
37
Longview, TX
I'm wondering if i need a new starter (which would have a functioning solenoid). From Messicks and an earlier conversation with my local Kubota parts counter it appears the solenoid is discontinued, but the entire starter is still available. Wondering if this would eliminate this "extra" part. Would make sense that the previous owner jerry rigged this to avoid this $500 part.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
37
Longview, TX
I'm already starting to look for fresh rubber for the drivers side - gotta match'em.
Ordered an ignition switch and new set of filters. You two are awesome - great advice on this thread and a host of others.
The story with this unit is that it came with a front end loader and is "already plumbed for one", but the owner stated that he had it removed the day he got it. It has a weird loop in the hydraulics in the back covered with pipe insulation. Is this something I could set up to run rear remotes?
Left rear view...
Looking from the drivers side backwards:
3,082
You can probably get a rebuilt starter from some local starter repair shop. There may be some available online.
But the wiring is now probably somewhat hacked up.
I looked at the illustrated parts list and the starter is part number 15601-63010 (but you need to verify that is correct). The illustration looks nothing like the pictures that come up searching for the part number!
3,082
And yes that looks like the block used to add hydraulic valves to the system.
See this thread for some information on how it works on the hydraulics. Good thing it is looped!
11,025
You would be far better off getting an aftermarket starter.
$183.99
The start circuit is super simple it will go from the ignition switch, through a switch on the clutch and then to the starter solenoid.
Yes that's a Hydraulic block to tap into the system, and yes you could use it to run remotes.
DSDispatch
L3800, L345DT
Apr 22, 2020
66
37
Longview, TX
$183.99
Thanks for this link - they're even having a 20% off Labor Day Sale!
DSDispatch
L3800, L345DT
Apr 22, 2020
66
37
Longview, TX
Any guidance on the correct suitcase weights for the front of the L345DT? This will obviously need some work. Is there a bolt kit to secure them as well?
3,082
I have a similar L185 that is smaller. The front bumper looks exactly like yours. I bought the 55 pond weights for mine from the dealer. I think that 70 pound weights might fit.
There is a place to bolt them down, I just used a common bolt, nut and two flat washers.
I’ll try to post a picture later, can’t find one now
11,025
I missed this post.
Someone could not have bypassed the solenoid, as that is required to engage the bendix (gear Drive) for it to start.
What they have done is added a second solenoid that is more than likely feeding power to the first solenoid.
You can very easily check the starter and the starters solenoid and jump it like you are doing to the top solenoid.
Just jump from the battery cable on the starter to the small solenoid terminal.
