Aiming the forks.
Dustball
2016 B2650HSDC
Sep 15, 2023
481
347
Hudson, WI
What kind of cameras are you guys using ? I have made videos with my Panasonic DMC-ZS100 mounted on the ROPS while doing grapple work or snow plowing and the vibration makes the videos barely viewable.
gg
Watch the video linked in post #2.
g_man
Feb 3, 2023
335
1,515
NE Vermont
I did - I was disappointed he didn't show the camera being used mounted on the forks where you could see how it handled vibration. Or maybe I missed some thing. He seemed more excited about the separation distance when you only need 10' feet in use ???
Here is a video I made using my FrostBite grapple to clear a triple pine blowdown off a tractor road which shows why I am wondering about vibration.
gg
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
72
59
Lakes Region, NH
Here is a video I made using my FrostBite grapple to clear a triple pine blowdown of a tractor road which shows why I am wondering about vibration.
gg
How was the camera mounted? Vibration is mostly do to the type of mount and where on the tractor the camera is mounted. Mount it on the hood sheet metal above the engine and you will get plenty of vibration.
7,283
gg
I got this on Amazon. It does everything I need it to do and versatile so can use it other places.
g_man
Feb 3, 2023
335
1,515
NE Vermont
I have a cage with limb risers on my M5640. I have a vibration damper mount for the camera.
The camera was mounted over head center of the cross piece.
I have tried all kinds of mounts - even made a couple different vibration dampers trying to tune out the vibration. Some better than others but none good. Any help is welcome !!
gg
JonM
Nov 29, 2024
171
348
wisconsin
no cameras needed tilt the forks up so you see the tips line it all up and flatten them then raise the arms a scootch and roll forward pick up the load.
dont need to stand or do contortions or get out
bobnic
Mar 7, 2025
72
59
Lakes Region, NH
gg
That is surprising. That cage must vibrate much more than my cab. The picture from the camera I have mounted solid with a magnet near the top of my cab provides a rock steady picture. Maybe try to move your mount close to the point where the cage members all intersect and see if that provides a more steady picture.
4,618
gg
I don’t know a whole lot about cameras, but is it possible to get one that has some sort of “image stabilization” built into the camera, in order to combat some/most of the “vibration problems”?
I just used a piece of “safety wire” to bypass my seat switch and stand up.
(But I admit that taking "safety advice" from a guy whose screen name is "Runs With Scissors” is welll…….you know…….;))
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
402
625
NH
Jon... then you have a super power that I don't. Lol. I'm envious.
g_man
Feb 3, 2023
335
1,515
NE Vermont
I don't know much about cameras either. Mine actually has a jitter preventer but as far as I can tell it only works for hand jitter on still photos. Doesn't do much for videos that I can see. It's to expensive to experiment with different cameras so I have given up trying to make it work.
gg
Gaspasser
Dec 16, 2023
402
625
NH
are your forks super short?? you cant see them when they are tilted up??
I can see them tilted up. But not when they are level at ground.
Snowman7
May 20, 2020
395
288
Boyne Falls, MI.
That is what I try to do but I totally suck at it.
JonM
Nov 29, 2024
171
348
wisconsin
leveling it once you line it up is the slightly harder part. then just raise the arms off the ground a few inches and ease forward.
it takes only a few rounds of practice i would suggest using an empty pallet and getting out to look a few times while you get the hang of it. once you get it down and it clicks your moving stuff around no problem
7,283
It's a lot like learning to tilt your bucket to get the desired cutting edge without the loader angle hardware! A little practice while paying attention and you have it.
Gaspasser
Dec 16, 2023
402
625
NH
Does getting out of the cab 26 times count as a few times? Lol. I have uneven dirt and gravel terrain to contend with as we are clearing and grading after timber harvesting this winter so it makes it a bit more challenging. Once I get a level pad down, life should get easier.
JonM
Nov 29, 2024
171
348
wisconsin
if i can remember to do it ill do a movie of me moving the horse hay feeder it always sits on really uneven ground.
you kind of have to disregard the orientation of the tractor itself and orient the forks to the load
i kinda use the fork frame to judge the orientation. once you get the fork tips close you can play with the tilt as you slide forward little at a time.
it doesnt have to be 100% perfectly aligned. dont overthink it
