20 hours on new Machine, Hydraulic Pump Failure, Advice needed.
swervomotor
US
I purchased a new machine from our local dealer a few weeks ago and with less than 20 hours on the machine, the hydraulic pump failed (per the dealer who has been great to work with and came to pick it up the same day) They have placed an order for a new pump (backordered for 3 months) and offered a loaner machine.
Now here is my concern, hydraulic pumps are usually gear pumps, and with the failure like this I'm very concerned about metal shavings/debris has now circulated through the valve manifolds, cooler, tank, etc. Contaminating the entire hydraulic system.
My concern is now a future lifetime of early failure of valve seals, cylinder seals, and other components from this debris on the pressure side of the hydraulic system.
Obviously the machine is under warranty now and we do have KTAC insurance but what about when it is out of warranty? What would you do with 20 hours on the machine?
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
175
183
The hydraulic system has a filter. I understand your feeling of being snake bit, but I think it will be fine.
Your dealer sounds like he's on top of it and will get it fixed right.
What equipment is it?
5,506
2,214
That is a legitimate concern.
Unfortunately, of the two hydraulic pump failures I've deal with in the ~30 years of kubota work, Kubota never paid to do a full system flush. Believe me, I have tried to get em to.
Trash Panda
L2501
Feb 18, 2022
Wyoming
Obviously a completely different machine, but when the pump went on our 299D skid steer, both drive motors followed shortly after.
Hopefully you can convince them to do a full system flush.
6,343
A lot depends on how it failed. My bigger concern would be why...
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
What kind of machine we talkin about here?
Old Machinist
May 27, 2024
586
688
NE FL
I would not want that machine back. In fact,,,,, if I was told it would take 3 months to get a part for a brand new machine I would be asking for a refund and looking at other brands.
Trash Panda
L2501
Feb 18, 2022
Wyoming
Sadly, this is the new norm for a lot of things.
Brand new Ram trucks with failed DPF’s and replacements unavailable are commonplace as well.
whatsupdoc
L3302
Jul 9, 2024
134
153
Multiple pumps on excavators, what pump failed?
Go to the machine with a suction gun with a long tube take a couple
of oil samples and send samples for oil analysis to at least two different labs.
John D 2
Jun 6, 2023
175
183
A friend of mine bought a new Dode 2500 diesel. The power steering pump went out 6 months after buying it.
The dealership did a nationwide parts search with no luck. The service manager then called the factory to try and expedite one. The factory said it would be at least 6 months before they had any available.
In the end the dealership bought the truck back and put them in something else.
  • Sad
Trash Panda
L2501
Feb 18, 2022
Wyoming
Stellantis is a clown show.
BAP
Dec 31, 2012
3,089
1,226
Ford is no better. Friend with a 350 and 6.2l engine cracked manifold and head this spring. Was 8-12 weeks to get parts. He ended trading the truck because he needed it.
  • Sad
3,812
I hope you are not implying that the dealer removed the pumps from a new unit and installed them on this unit.
Seems like a good solution to me.
I bought a new Ram 2500 out of state …(my truck was wrecked in KY while on a trip) ….and the transfer case output (tailshaft) seal was leaking with less then 3K miles on the truck. I took it to the local (Marble Falls, Tx) Ram dealer who kept it for 3 weeks claiming no parts available.
I found another dealer only 50 miles away who (online) had ten (10) of them in-stock, for sale online. I called the local dealer and told him…. He replied that dealers are not allowed to sell to other dealers parts for warranty…. the new part must come thru the warranty system. :sneaky:
He predicted another several weeks.
This pizzes me because in the meantime my warranty period is decreasing while they keep my truck outside in the weather and I can’t use it.
I bought the part online planning to pick my truck up and fix it elsewhere.
Two days later I have the part and the dealer says they have the part “arriving in the next day or so”.
Next day the dealer calls and says it’s ready.
When I picked it up, the dealer (svc mgr) tells me “That place you referred to us doesn’t actually have the seals.“
I responded, “Yes, they do. They have EIGHT of them...because I HAVE ONE which arrived yesterday…and YOU GOT ONE from the SAME PLACE…because THEY TOLD ME!” :mad:
It’s my belief that sometimes dealer svc-depts will place a warranty-job on the back burner while they work on retail-repairs….and the “parts on backorder” excuse is used just for that…an excuse.
They perform the warranty work when they’ve got mechanics standing around without retail-repairs available.
(As a former new car dealer mechanic myself, it’s my experience that dealerships are paid reduced labor-rates on warranty-claims…and they make Zero on the parts. It’s much more profitable to perform non-warranty repairs.)
It’s the sort of modern-day-mentality and business-practices which are pervading the economy.
ibbuckhunter
MX6000
Dec 20, 2021
17
Did you get this resolved yet? I was considering a new 40-5 or a 900 hour 40-4 for 20K less. I'm not sure if I want to go with the 40-5. I hear there are a lot of problems so I'm researching now.
Old Machinist
May 27, 2024
586
688
NE FL
I had a "fix as fails" transmission TSB performed on my tractor and they wouldn't even pay for fresh fluid or filters. I asked the dealer if they were draining the fluid if I could just pay for the fluid and filters and they wanted to charge me an extra $550. I spent $250 for the parts and changed it myself as soon as I returned home with it.
I talked the service advisor into sending me the service instructions for the operation and it actually said to reuse the drained fluid.
swervomotor
US
The dealer was great and they took it back, it was a really nice tractor but I'm going to wait until they get a few years under the belt to buy one of the 40-5 again.
