What size wrench. Large locknut on adjuster bar for boxblade
ken erickson
Nov 21, 2010
1,301
2,280
Waupaca Wisconsin
OR is it the adjustable side link he is asking about?
From his description of the size of the nut, close to 1 1/2" I would have to say my best guess is the top link. The jam nut on my L2501 for the adjustable lift arm/rod is much smaller. If not mistaken 24mm.
5,281
I’m guessing the whole problem could be eliminated with a hydraulic top link and side link. 😉
JonM
Nov 29, 2024
127
266
wisconsin
the only thing kubota i have on all my implements that is standard is the lock nut on my sa20 auger bit which is 1 1/8 i woild guess its metric
9,484
Implements are notoriously not metric, as most Implements are made in the US.
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
I don't think I ever tighten that nut back in the day, (before I switch over to hydraulic Top-N-Tilt....)
I haven't tightened that nut in 50 years of tractoring...
It's called the top link snug nut in my experience.
And I don't have a top or tilt hydro...
All this for that.... snug nut.
Put a pipe wrench on the tube or round side and pop it free with little or no force on the top link From the implement.
And have him grease the threaded rod ends!! Big time.
couleedude
Kubota L2502 Tractor Package
Dec 17, 2024
39
34
Grand Coulee, WA
So, what is happening is that this nut is coming loose while doing bumpy work, then my boxblade goes to an angle that is less than satisfactory for my work, and worse, the frame hits my brake light when I bring the box all the way up. Already broke the light once. Trying to keep it from happening again.
ken erickson
Nov 21, 2010
1,301
2,280
Waupaca Wisconsin
I am with you , both my tractors , depending on what implement and what conditions will rotate the top link adjuster if I do not tighten the nut. More than just finger tight is necessary at times.
I will be down at my land and have my calipers and will measure that nut. I have been meaning to pick up a dedicated wrench also. My adjustable always seems to be some other location when I need to tighten it! LOL
NorthwoodsLife
Oct 15, 2021
1,411
1,470
Wisconsin
ken erickson
Nov 21, 2010
1,301
2,280
Waupaca Wisconsin
I did get to my tractor. Mine, on my L2501 is 30mm.
They must have changed sizes when they went to your L2502.
