Kubota L35 putting back together.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
I am putting an engine back together after a rod keeper failure. Pistons are back in Ready to put the head on and continue with flywheel clutch etc. Question is should I be doing some bench tests to check some things before I put the engine back in and Reconnect everything. Thanks for all the previous info, and thanks for any more info.
9,299
Just make sure you lined up all the timing marks on the front gears, it's by far the biggest mistake made.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Ok yes I did have the timing cover off so I did that. Have a few questions putting the flywheel back on says about bring number 1 cylinder to tc ( top dead center). How do I know when the piston is at the top and is 1 cylinder at the water pump side? Ok I see that it is here in the manual.
also the valve clearance adjustment maybe attributed to the original faliure I think as the adjusting screw and nut were loose on that rocker arm above that push rod opposite where the keeper failed. Question is how do I get these all right part of the question is the same as the last as it mentions the piston at top dead center, then adjust with feeler gauge. Should lock tight be applied so they don’t come loose? Or I guess they should be checked periodically. I see it explains on how to do it but I’m slightly confused, or is there a different method I should use I don’t wanna screw it up ha. Ok thanks for any info
Fluke216
l35 kubota
May 2, 2021
84
21
PA
9,299
You don't need to bring it to TDC to put the flywheel on.
The flywheel only goes on one way, Just make sure all the bolts thread in by hand.
Do not use thread locker on the adjustment points on the rocker arms, you just use the nut to lock them down.
Loose rocker adjustments won't make an engine so south, it will just lose power, they don't get tighter when they loosen up.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
To me it looks like the flywheel could bolt on in any orientation. Or maybe the orientation doesn’t matter I was just thinking it needed to be on right in order to line the marks up in that window for what the manual said about adjusting valve clearance.
utterchaos
L245DT FEL
Mar 17, 2023
15
Chenango, NY
Line up the small hole on the crankshaft with the small circle “stain” on the flywheel and it will be back to original orientation.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Ok good eye, I’m thinking maybe it wasn’t in the right position the last time someone had off so maybe wasn’t right anyway. Thanks
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Ok so I spin the crank the exhaust rod goes up and comes down the the intake goes up and comes down and at that point the clearance should be adjusted for the respective cylinder that, that just occurred on and repeated the same way for the others. This is what I gathered from watching some videos does this sounds correct. Thanks
9,299
While the holes look to be the same distance apart they are not, there is a difference in distance on one bolt hole, this is why it's critical to hand thread the bolts all the way in or you can cross thread them and damage the bolt and the crank.
Put the flywheel on the crank not lined up with the small hole and the small hole mark and you will see one hole does not line up.
Yes you just need to make sure the cam lobe is not pushing the rocker up, it doesn't really matter where in the stroke it is as long as the pushrod and lifter are on the flats of the cam.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Thank you for that explanation. Makes sense I had put it on there when I saw the response from utterchaos and hand threaded all the bolts in. I did have it sitting up there before and yes a hole was slightly off . Ok I think I got it I reset them all the valve clearances the way I described in the explanation on how I thought it should be done.
On another note does anyone know what these two wires are for and what they should be connected to they were not connected when I removed the panel frame.
also one other dumb thing looking for any advice or comment. The front differential case has a pipe breather that snapped off. Pictures included I assume better just get another piece and replace. Or I could rig something up with a small rubber 90 and hose clamp.
anyway thanks for all the input guys.
L35
Jun 13, 2010
621
644
CT
Wires are for the PTO safety switch. They will go up into receiving connectors behind the plastics for the center console.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Ok I’ll check out the electrical drawings they were connected to nothing. Thanks
Fluke216
l35 kubota
May 2, 2021
84
21
PA
I would get a new one:
And 2 Orings
I went to messicks today to get snap pins for the clutch holder. I inquired about the pipe breather I knew they didn’t stock it but there is 2 versions and the one is discontinued and he said the two are not compatible. So not sure what to do about that. Unless that’s incorrect as mine is the earlier one before the serial number break.
On another note he said this was a hydraulic fluid that met super udt2 specs. https://viscosityoil.com/product/unitraction-transmission-hydraulic-fluid-coolsemi-synthetic/. not much cheaper though 129vs141 for a 5 gal.
one other thing I noticed when getting ready to mate the clutch housing back on one of the strait pins is missing, I’m pretty sure the last time someone had it off it was not reinstalled I’m assuming best practice to get a pin and install it unless for some reason it’s not critical. Ok thanks again for any and all info
9,299
I like all the alinement pins installed.
It will work without them but it allows parts to be misaligned.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Ok thanks yes I got the Pin Got it bolted up and the machine back together got fuel out of lines and got it to fire up. So a problem and a few questions. The hydraulic regulator valve delivery pipe was bent before and I think I moved it some so now it has a hole in it messicks list the part number as 32751-66210 and says it’s discontinued is the pipe repairable?I think it’s made of copper? Not sure
The manual says to bleed the power steering hoses after reconnecting, how is this done?
In my other post I couldn’t get the the u joint loose from the shuttle shift shaft and had to remove the roll pin in the bottom of it glove had it soaking in blaster since and I got it apart I marked it with a grinder so it would go back together right, but is there a way to make sure I have it set in the correct position.
One other question the throttle has a bolt apparatus governing it so it can’t be out all the way up is this how it came from the factory and should it be kept like that.
thanks for any and all info. Much appreciated
9,299
Steering will bleed itself.
Shuttle needs to be in neutral and keep the lever in neutral when you reassemble it.
That is a high pressure steel pipe, it needs to be tig welded or silver (hard) soldered.
Looks like all states might have one:
If you can
t get a new one, or don't have anyone that can fix it, you could send it to me and I can fix it for you.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
If you can
Ok yea I was looking at their website last night I called them today but they said that part is gone. I’ll see if I can find someone to repair it the pipe is smashed somewhat from before so I think someone would almost have to remove a section and weld a section back in so you think that’s possible? Or maybe that hole can just we welded shut, let me know what you think. Thanks
