Slow FEL and 3Ph
Jake9000
M9000DTC
Aug 4, 2025
Ny
I have a m9000 with about 3400 hours on it. Some reason the fel and the 3ph won’t raise without reving up the engine. I’m not sure where to start looking for issues.
Jake9000
M9000DTC
Aug 4, 2025
Ny
Start by looking at the loader hydraulic connections to the tractor. Is this new behavior?
I switched the dump/curl with the raise lower/quick connectors and there was no difference.
This tractor was just purchased this spring. I haven’t been able to use it hardly at all yet. The loader appeared to operate normally when purchased. It would raise at a good speed at idle.
5,349
Put it back.
Make sure ALL your rear remotes are in neutral. Dont rely on the levers - double check at the valves.
Jake9000
M9000DTC
Aug 4, 2025
Ny
Put it back.
loader hoses are in the proper locations. Both remotes are in neutral. I should add it also has a third function coming off of the loader valve.
5,349
the third function is working slowly like the FEL and 3PH
If it were me I would start by checling flow and pressure at the loader inlet hose.
If that is good I would start eliminating parts oc the downstream circuit.
How are you fixed for extea hose.and a pressure gauge?
Jake9000
M9000DTC
Aug 4, 2025
Ny
Ok. I have the means to check pressure there but not flow.
Jake9000
M9000DTC
Aug 4, 2025
Ny
5g bucket + stopwatch = flowmeter.
All we need is a rough estimate.
Were and how are you going to test pressure?
I never thought about doing the bucket trick.
I put a “T” in and a gauge between the feed hose and the loader valve. I’m getting 400 psi at idle and 1500 psi at max rpm if I dead head the dump function.
It took 56 seconds to almost fill a 5 gallon bucket at idle.
5,349
Good work - thats perfect!!!
Five GPM and 1500 PSJ at idke is a bit anemic. Do you know what the rated flow for the pump is? I found 25 GPM but I dont trust the source.
Assuming the oil is at operating temperature the 400 PSI @ 5GPM is considerably more than I would expect but its not fully deadheaded. Move the gauge to the outlet side and see what you are getting there. Pressure drop across that valve should be in the 10's not 100's of PSJ.
I dont have a WSM but deadheaded pressure should be closer to 2500 PSI. That suggests a weak pump or something amiss with the relief in the loader valve. Disconnect the tank return hose and see if you are getting flow when the boom spool is deadheaded at 1500 PSI.
We are maKing progress.
5,349
I found a factory specification sheet for the M9000.
Flow: 17 GPM @ 2600 RPM
Pressure: 2846 PSI.
So that flow looks decent but pressure is way low.
Jake9000
M9000DTC
Aug 4, 2025
Ny
I attached the specs for the pump. All I’m finding is 15.6-16.5 gpm at 2600 rpm’s. Mine is the combined flow type.
I will check outlet pressure this evening.
Thanks for helping me try to figure this out.
5,349
What is combined flow type? Does thst mean the PS is supplying some flow to the implement circuit? Looking at the parts diagrams I cant see how that works.
