Damned if you do........Damned if you don't.......
3,666
Well about a year'ish ago, I am coming to a stop and this "very, very, very, faint" noise catches my attention........Just a "very, very, very slight whine" I hear on decel.
Now my "Spidy Sense's" are tingling.......but it's not that bad, and it's a 20 year old truck, with "a few miles" on her, so..........besides, I know a "little somethin-somethin" about Dodge axles from way back in The Day.
So, I just turn up the radio and "keep on rolling".......
Fast forward to June 2025.
The noise is getting a "wee bit" louder, but still not "concerning", but I have an "out west" Prairie Dog shoot coming up (~2,600 miles round trip)
So I decide to change the fluid in the axles, just for "kicks and giggles".
I don't feel like pulling the cover, so I just use my "oil sucker" to empty them.
The rear axle magnet looks "pretty good".......However both outboard axles are leaking "pretty good", and the oil has saturated my "Parking Brake", rendering it basically useless.
Here are some pics from about 6 weeks previous when I was replacing the rear pads and rotors, so I do know that there is some "axle servicing" in my "near future".
I dont have a pic, but the other side is equally as bad.
Well when I pull the front diff plug, this appears on the magnet......................
DAMN IT!!!!!!
M_________________R!!!!!!!!
So now I am at a "crossroads" of sorts.
Clearly something is wrong........But........What to do about it?
I have about 9 days before I have to leave for the trip, so ......
Do you "tear into it"?
or
Do you "Roll the dice", just fill it up, and hope and pray that it makes it 2,600'ish more miles?
What would you have done?
and
What does @Runs With Scissors do?
Stay tuned..........
Hugo Habicht
G1900
Jun 24, 2024
658
864
Ireland
Ahem, no, I do not think so. As a minimum I think you have to identify where the part comes from. It's not part of a tooth, is it? Bit difficult to see on the picture.
Parts manual may help without having to open up the axle.
I hope you get it sorted and that it is not major work or expense.
Orangeglow
2015 BX2370
Jun 19, 2014
350
170
Prescott, Ontario
Dig into it now, and fix it properly before your trip. If it seizes up when you are away, you will not only be paying for a tow and very expensive parts, but labor as well. Don,t put yourself in a position were you are at the mercy of someone else, especially when you know how and can fix it yourself.
BBFarmer
Jul 12, 2024
623
1,238
Terry, MS
DAMN IT!!!!!!
or
and
That blows brother!
I can't tell what i'm looking at either. Looks too large and circular to be a piece of a shim or thrust washer.
Thats not a piece of the roll pin from the carrier is it? That got whacked and bent a little.
Is this a dana 50 by chance?
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
200
318
Grayling, MI.
You have the know how and tools to do the fix so if it was me, I would do the teardown now and save yourself a lot of heartache. Last thing you want is a breakdown on the side of the road somewhere in bumscratch Egypt.
Tughill Tom
B3200
Dec 23, 2013
1,330
1,698
Turin, NY
Well that's un-good> I'd be sourcing a used one and swap it out fast or tell your better half that you taking her vehicle to shoot dogs. It sucks either way.
Hugo Habicht
G1900
Jun 24, 2024
658
864
Ireland
That depends.
Friends in the car club were travelling through North Africa and the clutch of one of their Mercedes G-Wagons burnt out in Morocco. Three guys in sandals took out the clutch right there, relined it and assembled everything while they were having their lunch. And he said the repair cost was less than the lunch (which was cheap). I first I thought he was telling me stories until he showed me the pictures on his phone.
That was a few years ago and the G-Wagon is running fine since.
MOOTS
MX6000
Jun 27, 2019
2,175
2,694
Canton, Georgia
Pull the cover and give it a visual.
Bet he’s already elbow deep into it.
I was gonna guess c clip, but you said front axle, so rules that out. I think dodge rears are c clip, unless it’s full floater. Not that it matters.
I also would say unlock the hubs so nothing up there spins, but, you know… Dodge.
4,936
I would rent something to drive if I couldn’t get that fixed before a 2600 mile trip. I like hiking, but prefer to limit it to around 10 miles these days.
#40Fan
390
267
Only thing I can think of that it might be is the spider pin bolt. If the end that threads into the other side of the carrier had come out, you'd have bigger issues. Heck, getting the rest of the bolt out will be a fun time. A left handed drill bit will be your best bet.
Part 15. Called a differential screw. 5086694AA Part Discontinued.
3,482
It’s metal (steel or iron) since it’s stuck to the magnet.
I’d be darned if I’d depart on a long trip without pulling the covers and seeing what’s going on.
BBFarmer
Jul 12, 2024
623
1,238
Terry, MS
Kind of what I was thinking.
Of course if it was, atleast a piece of the pin would have to still remain otherwise the cross shaft pin would drop immediately and the spider gears would say see ya!
image i was using #29
WFM
L3800
Apr 5, 2013
1,484
910
Porter Maine
It could be time for a good wash and wax and visit Jolly John's Used Car & Cannbis Emporium....
pigdoc
G1800S L2500
Aug 19, 2022
311
235
SE Pennsylvania
You must have full-time 4WD in this truck.
I know some Dodge differentials have a particularly bad rep. You can probably find many posts of drivers with the very same issues.
Better reserve a rental for the big trip...
-P
3,666
That was exactly what I was thinking.......at first.
But every other time I have witnessed that happening (usually on older 3 speed Chrysler FWD transaxles), that pin "walks out" and begins beating the case, and in short order, either punchs a GIANT hole in the case, or wears the case so thin that it appears as a "minor leak" .
In both cases above, the trans was "junk".
Exactly my thoughts as well.
Hugo Habicht
G1900
Jun 24, 2024
658
864
Ireland
That's it?
Because of the 24h delay of your reply we thought you were mega busy and we were expecting a detailed report of a full front axle rebuild, with pictures, the lot 🤣
So what is the plan?
And any idea what this part is? Is it possible that it was placed on the magnet by the previous owner to make your life more interesting? :giggle:
WFM
L3800
Apr 5, 2013
1,484
910
Porter Maine
Im waiting for him to post the pic of his new Ram 600 hp TRX....
3,666
I should have done EXACTLY what y'all are suggesting,..........However (and there is always a "however")
I reasoned that what ever it is, it probably has been there a "loooong time".
It's true, I have no way of actually telling if it happened yesterday or it happened a year+ ago, when I first noticed the "very, very faint" mystery noise......but I had a "gut feeling".
Damn.....the truck seems fine and I have been driving it "back and forth, 4 hours one way" to the cabin, for at least a year, towing things, plowing........ etc.......
Decisions.....decisions.......
I don't feel like working on it "under the gun".
I would rather take my time, to make sure I do it correctly.
I reason that if something happens, I will have to "rent" a truck anyway......So the only thing I am out is some"aggravation" , and that I will have to rent a truck AND a trailer.
Well in the end, I made a poor choice, based on my "gut feeling", that it would hold up, and I decide to gamble.......It's South Dakota, or BUST..........
I fill her up with new "synthetic oil" and "I'm off.....as surely as a Prom Dress"...... ;)
(and this is exactly why I don't play poker any longer.......I have no problem going "all in" on the worst hand possible......... 7-2 off suit.............After all 3-7's or 3- 2's MIGHT come up.....lol)
Stay tuned.....
