I am working through some leaks and hydrolic issues on this old worn out B1750hstd with 3300 hours. I am noticing a steady leak out of the input shaft seal at the hst charge pump. If I start the tractor and operate the loader a touch it does not leak. But if I start the tractor and do not touch the controls I get a small stream coming out of the charge pump. I'm thinking blocked screens or a sticking release valve somewhere. Any ideas where to begin?
Other issues: At Idle the loader is barely raising. At 2000 rpm it operates but still a bit slow. This issue seems to have just started after I did work on the power steering valve. I disconnected and reconnected a quick connect fitting maybe that went bad? Also have a bad leak at the swing cylinder gland. I just received the seal kit for this. This things a basket case but it should be a handy tractor with some work. Any help would be appreciated.
