Kubota z421
Fivepack1966
Z421
Aug 1, 2025
Illinois
I have a 2020 z421 with the Kawasaki fs730v. It’s not charging the battery. I have tested the stator, 30v ac, the battery is new, there is 2.2v coming out of the regulator going back to charge the battery. When you pull the spade connected to the b terminal on the regulator and test the line voltage it’s showing 6.4 volts. I have checked the fuses and the ignition switch. The only fuse I haven’t checked yet is the slow blow fuse. Help? Any ideas?
9,866
Your putting 30VAC into the regulator and only getting 2.2VDC out, that's not right.
Sounds like the regulator is not getting charge signal, battery is bad, or the regulator is bad.
Start by testing the battery voltage.
Fivepack1966
Z421
Aug 1, 2025
Illinois
Battery is new and fully charged, 12.7v I’m not sure why it’s only getting 6.4v signal to the regulator
5,506
2,214
the regulator has a sensing circuit. If voltage is too low, the regulator "turns off" (more or less). Also, if ground is not good, it'll also fail to charge.
do a voltage drop test. Remove the spade that goes to the regulator (from battery) and find the other end-put your DVOM probes on the ends. Read the voltage. You don't want to see more than 0.5v on the meter, any more than that and you have a significant drop through the circuit. Where is the problem? Could be a connector, switch, etc. Dig out a wiring diagram and isolate the issue.
Sidekick
Jul 29, 2023
1,131
1,602
N.Y,
On my Z726 I had that happen and it was the sol blow fuse in the main line that blew. Did that at about 50 hours and has been fine since the fuse was replaced.
