Land Pride RFM (1672 Vs 2572) behind a B2650
5,309
Looking into picking up one (used) of the two listed mowers. I have several in the area that look to be in good shape. 1672 for 2K, 2572 for 2.5K.
I'm note exactly sure what the differences are between them other than approx 100-150 lbs.
Both of these models are rear discharge. What say you?
GrumpyFarmer
3,999
I glanced at LP website and at a glance I really did not notice a difference other than the pic, in which the frame of the 25xx looked heavier duty…but they were not in pic together so that could be BS.
I like LP branded implements and I would not hesitate to buy more from them. that being said, if it were my money, i would want to know between the two models if there were any difference in the serviceable areas / touch points to the user (wheels, grease zerks, etc). Maybe check the 3 point top link touch points…do they both have the floating top link? Maybe that matters or not?
if those things check out I think it comes down to do you want a heavier (potentially more robust) implement or not.
if you have hills to go up with your B (I do) then I would opt for the lighter unit if you have HST…assuming you don’t feel you would be better off with the heavier unit.
following your threads and pics it looks like you are careful with your machines and vehicles so I think you pay attention to what doing.
short answer, there’s not a bad choice.
share some pics what you get👍
BBFarmer
Jul 12, 2024
565
1,132
Terry, MS
The 2572 is the HD version. I've never seen one in person but it must have a fairly thicker frame or something.
Otherwise by pics it looks exactly identical to my 1672. Tires might be different to.
The 1672 is one tough mower. I have put mine through some pretty bad stuff since late '19 reawakening our property.
I reckon the 2572 must be dang near indestructible.
8,743
A 72" finish mower is a lot of mower behind a B2650.
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,147
PEI Canada
If your on flat ground you may be fine. I run a LX3310 and FDR2584 and it handles it fine on flat ground. I did have it on a LX2610 and low range and slow was my friend. I can mow in medium with the 3310. The 25xx also comes with solid tires. That mower showed the limitations of 19 pto hp of the 2650/2610 for me. That being said, I'm moving on to a L5460 shortly.
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
40
21
Va
I run a 1660 behind my B2650. And it handles it fine. I can cut grass 8”-12” and it goes through it fine just low and slow with the thick grass
PHPaul
Apr 2, 2015
1,145
1,254
Downeast Maine
www.eastovershoe.com
Another 1660 behind a B2650 here. With sharp blades and a new belt, the B2650 will run it through pretty much anything but I think it's about the limit, power-wise.
After several years of messing with pneumatic tires, I ponied up for a set of solid-tired casters. Now it's just hook up and go.
It has greaseable spindles, caster shafts and axles and the deck and frame are plenty rugged.
kcs 61
Apr 8, 2024
40
21
Va
Yup mine came with soils tires. I grease it twice a year and change the gear box oil at the beginning of each season. I have 2 sets of blade. I put a sharp set on at the beginning of the season and then change them about have way through with another set I just put a new belt on mine this year. Not cuz it needed it. The old one was 10 years old.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,583
1,823
Near Lancaster, PA, USA
I expected to see a thicker deck on the 2572. They look remarkably the same on their respective spec pages. The 2572 gear box takes 3.5 pints of lube where the 1672 only takes 2.5 pints. The 1672 hitch is noted as being QH compatible.
I've had LandPride 5 and 6 foot RFM's. The 6 footer was a 1672 that was used on my L3200. They are built well but heavy. I don't think the L3200 would have been so happy dragging another 100# unless the yard was flat.
5,309
Thanks all for the replies...Maybe need to go with a 5 footer instead as I certainly don't want to be mowing in low range. Even medium range is painfully slow to me.
chim
Jan 19, 2013
2,583
1,823
Land Pride quality has never been an issue in my experiences. I also have quite a few years of pulling Caroni RFM's. While i can't claim Caroni is equal to Land Pride they're pretty good. They are also much lighter than Land Pride. I've mentioned before that my Ford 1210 handles a 5' Caroni well, but when I tried using the 5' Land Pride from a B7500 I had, the little Ford struggled. The Caroni RFM's weigh in as follows: 5' at 404#, 6' at 497# and 7-1/2' at 710# make them a lot easier for the tractor to handle.
I bought a 5 footer and it was the only mower here for 10 years. It was used hard. I whacked an old cultipacker wheel in a meadow and damaged the "quill" as they call the spindle assembly. Agri Supply has parts available and cheap.
My current RFM is a 7-1/2' Caroni that I bought very used about 7 years ago and re-furbed. If anything awful happens to it I'd go for a new one. The manufacturer recently made a design change, making the shaft of the wheel yokes a little beefier at 1-1/8"Ø.
The photo below is from yesterday. #3 Son & family were here and I didn't want to mow with the kids running around. When I did get started raindrops appeared on the glass. Determined to get 'er done, most of the mowing was done while it drizzled, occasionally needing the wiper. The deck worked well. After the mowing was complete, the underside of the deck was garden-hosed off and green slush plopped to the ground. Fortunately the deck didn't leave green turds in the yard.
biketopia
Feb 15, 2024
329
328
Warrenton VA
I ran a 72" RFM behind my B2650 for a while. Mine is a side discharge, but the B handled it well in medium range, except for the steeper parts of my property, but just throw it in L and go. Others have mentioned removing the FEL helps with unnecessary weight if you don't need the ballast in your yard. I had let about 2 acres grow up to 3-foot-tall grasses earlier this year, and the tractor and RFM did great motoring through it all. I also picked mine up for a song 4 years ago, think I paid $500 bucks, guy said he didn't like how it cut. He had the belt routed wrong, so he was spinning two of the blades in reverse and slipping like crazy.
trikepilot
B2620HSD w/ LA364 & BH65, 48SQ Bush Hog, LandPride RB1560, Woods 5ft Box Blade,
Jul 18, 2020
105
144
Hardy, VA
You won't be unhappy with this combo. I have a B2620 - still 26hp - and the FDR1660. it's a great combo! Mine has stood up to alot of hard use.
PaulL
2,570
1,534
NZ
That's a hell of a bargain!! Feel a bit sorry for him, do some maintenance, then start thinking "don't like how this thing is cutting." But not quite get the connection that maybe you wrecked it when you did maintenance.
biketopia
Feb 15, 2024
329
328
Warrenton VA
I was ecstatic to find it. I had just let a similar one slip between my fingers that was only 30 minutes from the house. Kept scrolling marketplace and then noticed this one was about an hour away, looked good in the pics, so off I went. It wasn't until after I built a driveshaft for it that I realized the belt was wrong. I think the guy must have bought it, not really knowing what he was getting. He had a low HP BX and then a 30ish HP Mahendra and wanted to use the BX to run the RFM. He put a new belt on but never looked at a WSM and realized there was a small 4-link section of chain missing that set the idler/tensioner. Without that, you end up routing the belt wrong and then bam...I get a great deal ha!
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
249
444
Moseley, VA
I believe you will be much happier with a 5 foot mower. A rear discharge is nice as it does not have to pass the cuttings across the other blades. It also disperses the clippings much better than a side discharge. I have a 2572 behind my 3901 and you can hear and feel it bog a bit when in really thick stuff or on a steep hill in the mid range. Good luck with your decision.
