B8200 no hydraulics
MartinmMc
B8200
May 25, 2025
25
UK
TBH, I'm assuming the new pump is creating pressure & the issue is something else, what's the chances of a new pump not working, giving the same symptoms of no pressure as previous, hence me looking at the distribution block/relief valve.
I suppose I should confirm pressure at the pump, as my previous test, direct from the pump to the tank.
My procedure was run the engine with the valve open, then close it gradually to reach pressure.
6,929
Then lets stop guessing. Run your test straight from the pump. If you get 2500 PSI the pump is good.
Put the outlet block back together. Connect your test rig to the outlet block, fully close the valve and start the tractor. The gauge will tell you relief valve opening pressure.
MartinmMc
B8200
May 25, 2025
25
UK
I'll forgo my ego and reveal the issue, in my defence I have had no tractor ownership experience & I went to a reputable tractor shop for the offending item & had used it a couple of years without issue, however after prolonged used I ended up with the issue of no hydraulics,
I'm presuming the gradual increase of this product caused all the issues, but now resolved.
Thanks for everybody's input, hope this helps someone else in the future
6,929
I strongly doubt that.
