Pulling logs
Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
I’m not sure what the “ best way” would be, but with my BX I just wrap a chain around the log and then run the free end through a shackle on the back of the tractor (installed in the middle where you could put a hitch ball) and skid them out.
BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Mar 20, 2016
95
188
Evansville, IN, USA
You may want to add a 3 point hitch adapter and pull off that. This way you can raise the front end of said log(s) to keep them from digging into the ground as you drag them.
6,571
Several ways to do it already mentioned work swell. However you do it, do try to get the tractor end of the log lifted if possible. 2” is as good as 2’, just needs to be off the ground. Much easier on your tractor and your ground that way.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
Any number of ways you might pull/skid logs with your tractor.
But first and foremost....consider the 'safety' factor.
Just how big are these 'Logs' and over what type of terrain will you be moving them?
Can you drive right up to each of them and lift the butt end (slightly) or do some need to be skidded out first?
Hitch Point: IF you elect to connect a chain/cable/rope to your tractor at any point above the centerline of the rear axle be forewarned:
If a log snags on something and you have suffcient traction at the rear tires, the tractor will rotate about the axis of the axle shaft(s). This results in the front of the tractor lifting and in some cases the tractor going completely over backwards.
So keep your loads light enough for the tractor to easily handle and go SLOW!
Without a description of the logs you plan to move...it is difficult to suggest the 'BEST' way to it. Please be careful.
Shawn T. W
Dec 9, 2024
781
1,415
SW Missouri Ozarks
Maybe something like this? (I've never used one) https://www.portablewinch.com/products/skidding-cone-for-logs
Be aware that if you hook to the three point somehow, that it has a float feature, as in it can raise on its own, but not go lower than you set it, if your worried about it rising too much, you can chain the arms down so it wouldn't come up on you ...
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
However you decide to do the job, keep in the back of your mind that the term speed kills should be first and foremost. If you are skidding rather fast and the log gets hung up on something you won't have but a split second to get stopped before the tractor would flip over on you. I've seen those YouTube videos where they are using a standard farm tractor to pull a heavy load and there are three idiots hanging off the front of the tractor as counterweight. :cautious:
g_man
Feb 3, 2023
379
1,773
NE Vermont
Like others have said - it is easier and safer if you can get the end of the log off the ground. Do you have an implement with a grab hook on it. Or you could bolt one on (Ken's Bolt on Hooks) maybe or weld one on. Like a box blade or rear blade.
You could also get a cross-draw-bar at TSC and make a rig to lift the logs. This is one I made but you could use it w/o the A-frame to keep it simple.
If you end up just dragging the logs on the ground from your draw bar wrap the chain on the log as close to the end as possible. If you have a lot of log in front of the chain and the log snags on something it is possible that the log will stand upright and come over on you especially if it is a small log. That is why they all said go slow and easy.
gg
g_man
Feb 3, 2023
379
1,773
NE Vermont
To add to the above ^^^^ If you go with the cross-draw-bar you use a tractor hook with it also available at TSC. Or you can put it on your lower draw bar.
gg
Hoserman
Aug 1, 2022
210
339
Grayling, MI.
I don't know if it would help or be applicable for this, but if you are pulling very large logs there may be an easier tool to use that may make it safer and a lot less stress on your tractor. When I was a power lineman, we had a pole changeout that was in a swampy area in Michigan's upper peninsula. Dragging these 70-80' cedar transmission poles a chore to say the least. What we came up with is a small chain on two-wheel dolly on the far end of the pole like a tail wheel on a plane. we had a Bombardier track for skidding. Once we put the "tail wheel" on the far end and picked up the butt end with the tracks winch it made moving those poles so much easier. Doing this where there is a lot of stumps or other things that could catch the dolly may not be a good choice. Just a thought.
5,514
Well maybe the easiest way would to take a 30 or 55 gal plastic drum, cut it in half so the big bung is on the bottom , then run a chain through the bunghole,,, ( OK you pervs ) and toss the chain around the log, the other end to your draw bar as you pull forward the log will pulling to the half barrel and you can drive away with out worrying the end will dig in the ground. The plastic barrel will slid over the ground. Back in the day we used an old car hood same way.
Or do like this guy did
Tim Horton
296
70
Lake Superior
Yes... Depending on the log, a 5 gallon bucket, 20-30 gallon plastic barrel will help keep dirt and such off the log as you skid them..
I used to do a lot of skidding by raising the end of the log with a 3pt trailer mover attachment and pulling the log from the braw bar... You never want to skid with the 3pt raised..... Trust me on that advise..
texican
L3000F, FEL
Oct 12, 2023
105
22
East Texas
thanks so, probably with my 30hp, just chain up the draw bar?
Snowman7
May 20, 2020
401
309
Boyne Falls, MI.
Very good point!
Sidekick
Jul 29, 2023
1,246
1,794
N.Y,
I designed and built a log arch to keep them clean for sawing. Let's a small tractor move larger logs.
Reactions: 6 users
